Home » Archived » Eclipse Communications Framework (ECF) » JmDNSDiscoveryContainer and startup problem
JmDNSDiscoveryContainer and startup problem [message #597296] Fri, 10 February 2006 14:24 Go to next message
I am seeing occasionally that JmDNS startup will hang. I am using
1.5.0_03-b07 and ECF 0.6.0.
From the stack traces (see below) I am guessing this is a timing problem in
JmDNSDiscoveryContainer based on the order in which the API is called. My
plugin connects, adds itself as a service listener, then registers as a
service.
JmDNSDiscoveryContainer.registerServiceWithJmDNS() runs synchronized on a
lock. Before the service registration call returns, JmDNS reports in
another thread the discovery of a service (perhaps the same one it is
currently registering). This call hangs because of the lock. My guess is
that not returning from that event prevents registerService() from
completing.
Here are the stack traces I could identify that are associated with JmDNS
usage:
Thread [P2P Restart] (Suspended)
Object.wait(long) line: not available [native method]
ServiceInfo(Object).wait() line: 474
JmDNS.registerService(ServiceInfo) line: 610
JMDNSDiscoveryContainer.registerServiceWithJmDNS(IServiceInf o) line: 369
JMDNSDiscoveryContainer.registerService(IServiceInfo) line: 344
(snip)
Thread [JmDNS.SocketListener] (Suspended)
JMDNSDiscoveryContainer.serviceTypeAdded(ServiceEvent) line: 449
JmDNS.registerServiceType(String) line: 724
JmDNS.handleResponse(DNSIncoming) line: 989
JmDNS.access$6(JmDNS, DNSIncoming) line: 940
JmDNS$SocketListener.run() line: 1150
Thread.run() line: 595
Thread [Timer-0] (Suspended)
JmDNS$Responder.run() line: 1741
TimerThread.mainLoop() line: 512
TimerThread.run() line: 462
Re: JmDNSDiscoveryContainer and startup problem [message #600725 is a reply to message #597296] Fri, 10 February 2006 19:08 Go to previous messageGo to next message
Hi Bill,
Thanks for the report. Could/would you also file a bugzilla bug about
this so that it's tracked?
And just for additional context...how frequently does the hang occur?
Scott
> service.
> completing.
> usage:
> (snip)
Re: JmDNSDiscoveryContainer and startup problem [message #600733 is a reply to message #600725] Fri, 10 February 2006 19:18 Go to previous messageGo to next message
It's timing sensitive so some people run into it more often.
For me, I have seen it twice today -- maybe somewhere in the once in every
10-20 attempts.
"Scott Lewis" <slewis@composent.com> wrote in message
news:43ED2AE1.7090900@composent.com...
> Hi Bill,
> Scott
Re: JmDNSDiscoveryContainer and startup problem [message #600809 is a reply to message #597296] Tue, 21 February 2006 19:20 Go to previous messageGo to next message
I have been using ECF 0.7.1 most of the day and have not seen this problem
appear. Thanks, Scott for getting the fix in.
"Bill Joy" <bjoy@borland.com> wrote in message
news:dsip3u$iuk$1@utils.eclipse.org...
> in JmDNSDiscoveryContainer based on the order in which the API is called.
> My plugin connects, adds itself as a service listener, then registers as a
> service.
> completing.
> usage:
> (snip)
Re: JmDNSDiscoveryContainer and startup problem [message #600816 is a reply to message #600809] Wed, 22 February 2006 02:14 Go to previous message
Hi Bill,
Good to hear...thanks for the report(s).
Scott
>>service.
>>completing.
>>usage:
>>(snip)
Previous Topic:ECF 0.7.0
Next Topic:Exceptions while testing IRC provider
Current Time: Thu Sep 18 02:02:09 EDT 2025
Powered by FUDForum. Page generated in 0.04389 seconds
