ECF 0.7.0 [message #600752] |
Sat, 18 February 2006 20:26  |
Hi Folks,
Version 0.7.0 stable of ECF is now available at:
http://www.eclipse.org/ecf/downloads.html
The major new addition for 0.7.0 is an ECF 'call' API. This API is
still being developed, but the intention is to supply a generic VOIP
'call setup' API for client applications to do call setup via Jingle
(JEP-166), SIP, and perhaps other signalling protocols.
See the new API in the org.eclipse.ecf.call plugin. Javadocs for the
org.eclipse.ecf.call and org.eclipse.ecf.call.events packages already
are posted here http://www.eclipse.org/ecf/org.eclipse.ecf.docs/api/
and are included in the ECF programmers guide in the Eclipse help.
There is also a new 'call api' feature included in the set of features
available via the update site, and a new call API zip available via
download page: http://www.eclipse.org/ecf/downloads.html
Please comment on the API. The initial provider implementation will
most likely be based upon Jingle/JEP-166. Those interested can consult
this (still experimental) JEP here:
http://www.jabber.org/jeps/jep-0166.html
Scott
Re: Download problem for ECF 0.7.0 option 2a [message #600801 is a reply to message #600791] |
Tue, 21 February 2006 13:00  |
Hi All,
Note 0.7.1 stable now at:
http://www.eclipse.org/downloads/download.php?file=/technolo gy/ecf/org.eclipse.ecf.core-0.7.1.S20060220.zip
Although use of the sdk zip is perfectly fine, in postings I generally
give the whole download page: http://www.eclipse.org/ecf/downloads.html
because the preferred download/install method is the update
site...i.e. see "ECF JAR (Java Archive) Files via Eclipse Update
Manager" on the downloads page.
Scott
Christian BEZARD wrote:
> The correct link for Version 0.7.0 stable of ECF is
> http://www.eclipse.org/downloads/download.php?file=/technolo gy/ecf/org.eclipse.ecf.sdk-0.7.0.S20060218.zip
> In the download page the link is wrong.
> Thanks
> "Scott Lewis" <slewis@composent.com> a écrit dans le message de news:
> 43F7C936.6010009@composent.com...
>>Hi Folks,
>>The major new addition for 0.7.0 is an ECF 'call' API. This API is still
>>being developed, but the intention is to supply a generic VOIP 'call
>>setup' API for client applications to do call setup via Jingle (JEP-166),
>>org.eclipse.ecf.call and org.eclipse.ecf.call.events packages already are
>>posted here http://www.eclipse.org/ecf/org.eclipse.ecf.docs/api/ and are
>>Please comment on the API. The initial provider implementation will most
>>likely be based upon Jingle/JEP-166. Those interested can consult this
>>(still experimental) JEP here: http://www.jabber.org/jeps/jep-0166.html
>>Thanks,
>>Scott
FUDForum. Page generated in 0.28061 seconds
