Home » Eclipse Projects » Technology Project and PMC » Can one retrieve the keyboard shortcut bindings through the API?
Can one retrieve the keyboard shortcut bindings through the API? [message #72475] Sat, 10 June 2006 01:26 Go to next message
Originally posted by: pschlesi.NOSPAM.uci.edu
Hi all.
I'd like to be able to retrieve the Eclipse keyboard shortcut bindings -
the 178 or so keyboard shortcuts listed when you hit Ctrl-Shift-L twice
in a row. Is there any way to do that? Or do I have to manually retype
them?
Your help is much appreciated. Thank you in advance.
- Phil
Re: Can one retrieve the keyboard shortcut bindings through the API? [message #72567 is a reply to message #72475] Sun, 11 June 2006 17:18 Go to previous messageGo to next message
Philip Schlesinger wrote:
> Hi all.
> them?
> - Phil
Found it (this might come out a bit messy):
IBindingService bindingService = (IBindingService)
PlatformUI.getWorkbench().getAdapter(IBindingService.class);
bindingService.readRegistryAndPreferences( (ICommandService)
PlatformUI.getWorkbench().getAdapter(ICommandService.class) );
Binding[] bindingList = bindingService.getBindings();
PrintWriter out;
try {
out = new PrintWriter( new BufferedWriter( new FileWriter("c:/foo2.out")
out.write(
" Trigger\tcontext\tlocale\tplatform\tscheme\ttype\tclass\tpar ameterized\n "
for (int i = 0; i < bindingList.length; ++i) {
out.write(bindingList[i].getTriggerSequence().toString());
out.write("\t" + bindingList[i].getContextId());
out.write("\t" + bindingList[i].getLocale());
out.write("\t" + bindingList[i].getPlatform());
out.write("\t" + bindingList[i].getSchemeId());
out.write("\t" + bindingList[i].getType());
out.write("\t" + bindingList[i].getClass().toString());
if (bindingList[i].getParameterizedCommand() != null)
out.write( "\t" +
bindingList[i].getParameterizedCommand().getCommand().getId( ) );
else
out.write("\t" + bindingList[i].getParameterizedCommand());
/* necessary because some ParameterizedCommands are just null, so will
get a NullPointerException in those cases if one tries the command for
the "true" value */
out.write("\n");
} // end for
out.close();
} catch (IOException e) {
e.printStackTrace();
Re: Can one retrieve the keyboard shortcut bindings through the API? [message #72602 is a reply to message #72567] Mon, 12 June 2006 09:34 Go to previous message
Just a note that the above line will reset all of your keybindings ...
and shouldn't really be necessary, since the IBindingService you get
from the workbench should be the global binding service and already have
the keybindings set correctly.
Other than that, good use of the IBindingService.
Later,
PW
Re: Can one retrieve the keyboard shortcut bindings through the API? [message #600714 is a reply to message #72475] Sun, 11 June 2006 17:18 Go to previous message
> Hi all.
> them?
> - Phil
PrintWriter out;
try {
out.write(
out.write( "\t" +
else
the "true" value */
out.write("\n");
} // end for
out.close();
Re: Can one retrieve the keyboard shortcut bindings through the API? [message #600728 is a reply to message #72567] Mon, 12 June 2006 09:34 Go to previous message
Later,
PW
Previous Topic:RAP+RSP+Wicket
Next Topic:RAP & Thin-client UIs
Current Time: Sun Oct 26 16:49:03 EDT 2025
Powered by FUDForum. Page generated in 0.05180 seconds
