Home » Eclipse Projects » Nebula » Are Gallery Items adaptable?
Are Gallery Items adaptable? [message #600042] Wed, 28 July 2010 08:46 Go to next message
I am just wondering if it is possible to adapt a gallery item to another type.
Here are snippets from my implementation.
I have set breakpoints in all of these methods and do not get into any them when debugging. I am working from examples in other portions of our product which do work, so am kind of perplexed as to what I might have wrong (if anything). Or if this is even supported by the Gallery.
in my plugin.xml file
<extension
point="org.eclipse.core.runtime.adapters">
<factory
adaptableType="com.xxx.yyy.results.ResultsGalleryItem"
class="com.xxx.yyy.results.ResultsGalleryItemAdapterFactory ">
<adapter type="com.xxx.yyy.results.RG"/>
</factory>
</extension>
AdapterFactory class
public class ResultsGalleryItemAdapterFactory implements IAdapterFactory
public Object getAdapter( Object adaptableObject, Class adapterType )
if ( adapterType.equals(com.xxx.yyy.results.RG.class) )
if ( adaptableObject instanceof ResultsGalleryItem )
ResultsGalleryItem t = ( ResultsGalleryItem )adaptableObject;
return t.getAdapter(adapterType);
return null;
public Class[] getAdapterList()
return new Class[] { com.xxx.yyy.results.RG.class };
In ResultsGalleryItem, which implements IAdaptable
public Object getAdapter(Class adapter) {
if( (com.xxx.yyy.results.RG)getData() != null
&& adapter.isAssignableFrom( com.xxx.yyy.results.RG.class ) )
return getData();
return null;
Re: Are Gallery Items adaptable? [message #600123 is a reply to message #600042] Wed, 18 August 2010 05:09 Go to previous message
Hi Rick,
Gallery is an SWT component so it does not use classes from RCP :
GalleryItem does not implement IAdaptable.
You can still attach your own adaptable objects to GalleryItems using
setData() / getData().
Nicolas
> type.
> <extension
> <factory
> </factory>
> </extension>
> return null;
> return getData();
> return null;
Previous Topic:Are Gallery Items adaptable?
Next Topic:[Paperclips] is possible a Print composed by a TextPrint and GridPrint
Current Time: Thu Jul 17 22:19:36 EDT 2025
Powered by FUDForum. Page generated in 0.07842 seconds
