Home » Language IDEs » AspectJ » Cannot install AJDT in Eclipse Galileo
Cannot install AJDT in Eclipse Galileo [message #74225] Fri, 26 June 2009 15:13 Go to next message
Originally posted by: gaston.tonietti.teracode.com
Hi all,
I have upgraded to Eclipse 3.5 today, and I was trying to install AJDT from
the update site but I always get the same error:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.rcp,
phase=org.eclipse.equinox.internal.provisional.p2.engine.pha ses.Collect,
operand=, action=).
Multiple problems occurred while downloading.
Artifact not found:
osgi.bundle,org.eclipse.equinox.weaving.source,1.0.0.2009061 71200.
http://download.eclipse.org/tools/ajdt/35/update/plugins/org .eclipse.equinox.weaving.source_1.0.0.200906171200.jar.pack. gz
Artifact not found:
Do you know what can I do? please I need some help on this. I don't select
any source item but they are selected by dependency resolution I think.
I am using this url:
Thank you very much
Gaston.
Re: Cannot install AJDT in Eclipse Galileo [message #74246 is a reply to message #74225] Fri, 26 June 2009 16:34 Go to previous messageGo to next message
Originally posted by: andrew.eisenberg.springsource.com
Hi Gaston,
The problem is that Eclipse.org is offloading bandwidth to mirror servers
because of the increased load from the new Galileo release. However,
Eclipse.org is forwarding clients to mirrors that are not completely synced
yet. That is why you are receiving the file not found error.
For now, you can go straight to a mirror that is known to be good and
download from there:
http://eclipse.unixheads.org/tools/ajdt/35/update/
As for downloading the source bundle even when it is not selected, the
reason for that is that this is the way P2 works. If optional bundles are
found in one of the repositories, then they will automatically be installed.
Hope this helps,
--a
Re: Cannot install AJDT in Eclipse Galileo [message #74264 is a reply to message #74246] Fri, 26 June 2009 17:08 Go to previous message
Sure it helps. Thank you very much Andrew.
Gaston.
Andrew Eisenberg wrote:
> Hi Gaston,
> synced
> installed.
> Hope this helps,
> --a
Re: Cannot install AJDT in Eclipse Galileo [message #600110 is a reply to message #74225] Fri, 26 June 2009 16:34 Go to previous message
Hi Gaston,
Hope this helps,
--a
Re: Cannot install AJDT in Eclipse Galileo [message #600119 is a reply to message #74246] Fri, 26 June 2009 17:08 Go to previous message
Gaston.
> Hi Gaston,
> synced
> installed.
> Hope this helps,
> --a
Previous Topic:Cannot install AJDT in Eclipse Galileo
Next Topic:AJDT 2.0.0 + Eclipse 3.5 ClassNotFoundException
Current Time: Sun Jul 27 02:17:31 EDT 2025
Powered by FUDForum. Page generated in 0.06341 seconds
