Home » Modeling » Modeling (top-level project) » Help installing EMF
| Help installing EMF [message #381250] |
Wed, 03 October 2007 03:01  |
I could use some help installing EMF.
I've installed Eclipse 3.3.1 on Linux and I'm trying to install the EMF
plugin, but I get the following error message:
Requested operation cannot be performed because it would invalidate the
current configuration. See details for more information.
EMF Model Query OCL Integration 1.1.0.v200706071712-10-7w311817182823)
requires plug-in "org.eclipse.emf.ocl (1.1.0)", or compatible.
EMF Validation Framework OCL Integration
(1.1.0.v200706071520-10-7w311817182631) requires plug-in
"org.eclipse.emf.ocl (1.0.0)", or compatible.
I tried looking for the "org.eclipse.emf.ocl (1.1.0)" plugin and I found
and installed this:
mdt-ocl-runtime-I200709261803.zip
but that didn't make any difference.
Any help is appreciated.
Richard
| Re: Help installing EMF [message #381252 is a reply to message #381251] |
Wed, 03 October 2007 10:02   |
Ed,
Thank you for pointing me in the right direction... I'm new to the
Eclipse system. Also, I recall that when I unzipped
into my plugins directory, I was prompted that there was already an
existing file with the name that was being unzipped... to which I
answered 'no' initially... I took the '-clean' in your suggestion to
mean to answer 'yes to all'... (unzip has no -clean option in linux).
Anyway, that got rid of the error message... :).
However, I new error message has popped up
The current configuration contains errors and this operation can have
unpredictable results.
Object Constraint Language (OCL) 2.0
(1.2.0.v200709262202-3309oA55P5R_F_DAU) requires plug-in
"org.eclipse.emf.ecore (2.4.0)", or equivalent.
OCL 2.0 Binding for UML (1.2.0.v200709262202-11-7w31181_322622)
requires plug-in "org.eclipse.emf.ecore (2.3.0)", or compatible.
and I will take it up with the newsgroup you suggested (eclipse.tools.emf).
Thank you once again.
Richard
Ed Merks wrote:
> Richard,
> Please use the EMF newsgroup for questions about EMF. I've added it to
> the "to" list of the reply. I'll ask Christian to look at the specifics
> of these numbers. Note that when unzipping plugins, it's often
> necessary to run with "-clean" to refresh Eclipse's cached plugin
> configuration. It would be good to try that.
>> and installed this:
>> Richard
| Re: Help installing EMF [message #381253 is a reply to message #381252] |
Wed, 03 October 2007 10:15  |
Richard,
Be very careful to look at all dependencies of what you download to make
sure they are all for Eclipse 3.3.x. It sounds like you've unzipped OCL
1.2 which is for Eclipse 3.4 and EMF 2.4. You'll probably need to clean
up your installation and start again. Be sure to check the "Build
Dependencies" section of each download zip. I suppose you might as well
get all the stuff for 3.3.1 which was released last week. The -clean
argument is for when you run Eclipse itself, not an argument for unzip...
> Ed,
> Richard
> Ed Merks wrote:
>> Richard,
>>> and installed this:
>>> Richard
| Re: Help installing EMF [message #600097 is a reply to message #381250] |
Wed, 03 October 2007 08:40  |
Richard,
> and installed this:
> Richard
| Re: Help installing EMF [message #600105 is a reply to message #381251] |
Ed,
Richard
Ed Merks wrote:
> Richard,
>> and installed this:
>> Richard
| Re: Help installing EMF [message #600117 is a reply to message #381252] |
Richard,
> Ed,
> Richard
> Ed Merks wrote:
>> Richard,
>>> and installed this:
>>> Richard
Current Time: Wed Nov 05 03:39:02 EST 2025
Powered by FUDForum. Page generated in 0.74732 seconds
