AJDT asking to enable weaving in Eclipse [message #73887] |
Mon, 11 May 2009 09:03  |
Originally posted by: jacek.pospychala.pl.ibm.com
hi AJDT :-)
How does AJDT enable the aspects weaving support in the Eclipse it's
running? (To enable the advanced integration with JDT)
Which class does that?
Thanks!
Rational Elite Support for Eclipse
Re: AJDT asking to enable weaving in Eclipse [message #74029 is a reply to message #74011] |
Tue, 26 May 2009 14:48  |
Originally posted by: andrew.eisenberg.springsource.com
In your case, you might be better off using Equinox Aspects alone, without
using the JDT weaving service. EA is available from the AJDT update site.
Also, instructions on how to use it in your osgi application are available
here:
http://www.eclipse.org/equinox/incubator/aspects/index.php
On 25/05/09 6:05 AM, in article gve519$h73$1@build.eclipse.org, "Jacek
Pospychala" <jacek.pospychala@pl.ibm.com> wrote:
> hi Andrew,
> I was looking at how to most seamlessly plug into weaving Eclipse
> plugins. My own plug-in would just contribute aspects, and I would not
> have to worry whether weaving hook is enabled or not, but leave it to
> user to enable/disable Weaving as it is done in AJDT/JDT integration.
> I found that your code depends on JDT and the aspect that verifies
> Weaving hook installation success also requires some particular JDT class.
> I used that as an example for my own Weaving hook enabler. However
> someone could come up with solution generic enough so that it would not
> require JDT.
> In my case I wanted to weave various plug-ins and not assume that JDT is
> available.
> Andrew Eisenberg pisze:
>> That's right.
>> A description of how it is implemented is here:
>> http://wiki.eclipse.org/JDT_weaving_features
>> And org.eclipse.contribution.jdt.preferences.WeavingStateConfigu rerUI
>> provides UI support for it.
>> What are you trying to do?
>> On 11/05/09 6:27 AM, in article gu9938$eeo$1@build.eclipse.org, "Jacek
>>> Ok, I see it:
>>> in org.eclipse.contribution.jdt bundle.
>>> Jacek
>>> Jacek Pospychala pisze:
>>>> hi AJDT :-)
>>>> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #599951 is a reply to message #73887] |
Mon, 11 May 2009 09:27  |
Ok, I see it:
Jacek
> hi AJDT :-)
> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #599966 is a reply to message #73905] |
Mon, 11 May 2009 18:50  |
That's right.
> Ok, I see it:
> Jacek
>> hi AJDT :-)
>> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #599997 is a reply to message #73940] |
Mon, 25 May 2009 09:05  |
hi Andrew,
require JDT.
available.
> That's right.
>> Ok, I see it:
>> Jacek
>>> hi AJDT :-)
>>> Thanks!
Re: AJDT asking to enable weaving in Eclipse [message #600006 is a reply to message #74011] |
here:
> hi Andrew,
> require JDT.
> available.
>> That's right.
>>> Ok, I see it:
>>> Jacek
>>>> hi AJDT :-)
>>>> Thanks!
FUDForum. Page generated in 0.04658 seconds
