Home » Archived » Service Oriented Architecture Tools Platform (STP) » Re: Open BPMN model in main method
Re: Open BPMN model in main method [message #593924] |
Fri, 28 September 2007 14:10  |
Originally posted by: anders.ottosson3.telia.com
Hi, thanks for replying again ;)
It would seem to me that I need to build an RCP for the method you
suggested, since I need to add many jars, and it ends with that I can't
initialize org.eclipse.core.runtime.Platform (see below) or is there a
way around the problem?
Exception:
Exception in thread "main" java.lang.NoClassDefFoundError: Could not
initialize class org.eclipse.core.runtime.Platform
at org.eclipse.emf.transaction.util.Lock.<clinit>(Lock.java:75)
at
org.eclipse.emf.transaction.impl.TransactionalEditingDomainI mpl. <init>(TransactionalEditingDomainImpl.java:69)
at
org.eclipse.emf.workspace.WorkspaceEditingDomainFactory.crea teEditingDomain(WorkspaceEditingDomainFactory.java:83)
at
org.eclipse.emf.workspace.WorkspaceEditingDomainFactory.crea teEditingDomain(WorkspaceEditingDomainFactory.java:55)
at
com.implior.bpmn.converter.XmiBpmnConverter.main(XmiBpmnConv erter.java:19)
/Anders
Antoine Toulme wrote:
> Ed,
> Swordfish is a runtime project, while the STP project is hosted at
> eclipse.stp.
> I have already replied to this question on our newsgroup, and I added at
> the time that contacting you through the EMF newsgroup would be a good
> way to get help with EMF.
> Anders, please let us know if the code I gave you is not working in the
> thread we had began. I'll look at it again then.
> Antoine
> Ed Merks wrote:
>> Anders,
>> Isn't the BPMN modeling coming from the STP project? I think your
>> question should be directed toward their specific newsgroup. I think
>> I've added the right one to the "to" list of the reply.
>> SOA Tools Platform Webmaster,
>> Swordfish is a cool name. 8-) Could I ask that on your home page
>> your Newsgroups Navigation link that you direct your users to the
>> newsgroup you want them to use. I would suggest a page much like the
>> one we have for EMFT which will encourage your uses to search the
>> newsgroup first:
>> http://www.eclipse.org/modeling/emft/newsgroup-mailing-list. php
>> Anders Ottosson wrote:
>>> Is there a way to open a bpmn-model in a standalone main method?
>>> Since I'm a n00b at Eclipse BPMN/GMF/EMF I have tried the FAQ (from
>>> EMF) examples with no luck, the result is always:
>>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
>>> org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'version'
>>> not found. (file:/C:/src/test/BPMN/credit_report.bpmn, 2, 175)...
>>> The code I have tried with is:
>>> ResourceSet resourceSet = new ResourceSetImpl();
>>> Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap( ).put( "bpmn",
>>> new BpmnResourceFactoryImpl());
>>> BpmnPackageImpl.eINSTANCE.eClass();
>>> Resource resource =
>>> resourceSet.getResource(URI.createFileURI(fileName), true);
>>> try {
>>> resource.load(null);
>>> } catch (Exception e) {
>>> e.printStackTrace();
>>> I have added the following jars to the classpath:
>>> org.eclipse.core.runtime_3.2.0.v20060603.jar
>>> org.eclipse.emf.common_2.3.0.v200709042200.jar
>>> org.eclipse.emf.ecore.change_2.3.0.v200709042200.jar
>>> org.eclipse.emf.ecore.xmi_2.3.1.v200709042200.jar
>>> org.eclipse.emf.ecore_2.3.1.v200709042200.jar
>>> org.eclipse.stp.bpmn.diagram_1.0.0.061.jar
>>> org.eclipse.stp.bpmn.edit_1.0.0.061.jar
>>> org.eclipse.stp.bpmn_1.0.0.061.jar
>>> Any help would be greatly appreciated!
>>> Regards
>>> Anders
Re: Open BPMN model in main method [message #593945 is a reply to message #593924] |
Fri, 28 September 2007 14:30   |
Originally posted by: atoulme.intalio.com
Sorry,
I was concentrated on making it work and forgot about the stand-alone
requirement.
So you did well, I'd say maybe you should change initially to do
something like :
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap().put( "bpmn",
Resource resource = resourceSet.getResource(URI.createFileURI(fileName),
true);
try {
If that still does not work, try adding
EcoreFactory.eINSTANCE.eClass();
before the BpmnPackage registration line.
If that still doesn't work, please reply here and I'll help you more.
Antoine
> Exception:
> at
> at
> at
> at
> Regards
> /Anders
>> Ed,
>> eclipse.stp.
>> at the time that contacting you through the EMF newsgroup would be a
>> good way to get help with EMF.
>> the thread we had began. I'll look at it again then.
>> Thanks,
>> Antoine
>> Ed Merks wrote:
>>> Anders,
>>> newsgroup first:
>>>> 'version' not found. (file:/C:/src/test/BPMN/credit_report.bpmn, 2,
>>>> 175)...
>>>> Resource resource =
>>>> try {
>>>> Regards
>>>> Anders
Intalio, the Open Source BPMS Company
<a href="http://www.intalio.com">http://www.intalio.com</a>
<a href="http://bpms.intalio.com">Community website</a>
Re: Open BPMN model in main method [message #593959 is a reply to message #593945] |
Mon, 01 October 2007 08:20   |
No worries, just happy that someone takes an interest in my little
problem...
I tried the method you outlined below (see below) and it gives me the
same exception Feature 'version' not found as I got from my own tests
(also listed below).
Code:
Resource resource =
resourceSet.getResource(URI.createFileURI(args[0]), true);
try {
Exception:
not found. (file:/C://src//ibmtutorial//BPMN//credit_report.bpmn, 2, 175)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:316)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:275)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResou rce(ResourceSetImpl.java:398)
at
com.implior.bpmn.converter.XmiBpmnConverter.main(XmiBpmnConv erter.java:25)
Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.reportUnknownFeatu re(XMLHandler.java:1856)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.handleUnknownFeatu re(XMLHandler.java:1820)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.setAttribValue(XML Handler.java:2570)
at
org.eclipse.emf.ecore.xmi.impl.SAXXMLHandler.handleObjectAtt ribs(SAXXMLHandler.java:74)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectFromFa ctory(XMLHandler.java:2058)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1270)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1336)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:970)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:953)
at
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:684)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. startElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$ContentDriver.scanRootElementHook(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDriver.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(Unknown
Source)
at
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(Unknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(Unknown
Source)
at
Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown
Source)
at
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(Unknown
Source)
at
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(Unknown
Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:179)
at
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1354)
at
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1155)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:256)
at
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:271)
... 2 more
/Anders
> Sorry,
> requirement.
> something like :
> true);
> try {
> Antoine
>> can't initialize org.eclipse.core.runtime.Platform (see below) or is
>> there a way around the problem?
>> Exception:
>> at
>> at
>> at
>> at
>> Regards
>> /Anders
>>> Ed,
>>> eclipse.stp.
>>> Thanks,
>>> Antoine
>>> Ed Merks wrote:
>>>> Anders,
>>>> think I've added the right one to the "to" list of the reply.
>>>> the one we have for EMFT which will encourage your uses to search
>>>> the newsgroup first:
>>>>> 175)...
>>>>> Resource resource =
>>>>> try {
>>>>> Regards
>>>>> Anders
Re: Open BPMN model in main method [message #599906 is a reply to message #593959] |
Fri, 05 October 2007 12:51  |
Anders,
I haven't forgotten you, been very busy this week.
I'll update you ASAP.
Antoine
> problem...
> Code:
> Resource resource =
> try {
> Exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(U nknown Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> ... 2 more
> Thanks
> /Anders
>> Sorry,
>> requirement.
>> something like :
>> Resource resource =
>> try {
>> Antoine
>>> Exception:
>>> at
>>> at
>>> at
>>> at
>>> Regards
>>> /Anders
>>>> Ed,
>>>> eclipse.stp.
>>>> added at the time that contacting you through the EMF newsgroup
>>>> would be a good way to get help with EMF.
>>>> Thanks,
>>>> Antoine
>>>> Ed Merks wrote:
>>>>> Anders,
>>>>>> (from EMF) examples with no luck, the result is always:
>>>>>> 2, 175)...
>>>>>> Resource resource =
>>>>>> try {
>>>>>> Regards
>>>>>> Anders
Current Time: Sat Jul 26 23:45:21 EDT 2025
Powered by FUDForum. Page generated in 0.03047 seconds
