Home » Eclipse Projects » Mylyn » is sharing the mylyn BD folder between eclipse instances ok?
is sharing the mylyn BD folder between eclipse instances ok? [message #599619] Fri, 09 October 2009 05:43 Go to next message
my use case is that i have several eclipse workspaces that i need to open concurrently and i would like them to share the same Mylyn DB.
i have tried to do this yesterday and it seems to work.
so far i havent seen any side effect yet.
but is this safe?
Re: is sharing the mylyn DB folder between eclipse instances ok? [message #599881 is a reply to message #599619] Fri, 30 October 2009 05:54 Go to previous messageGo to next message
I encounter the similar case.
I use the Local repository and want to share this tasks and their context through different workspaces. These workspace has similar projects and codes, i.e, one for maintenance, the 2nd for development.
Can we have there any options such as new Local repository in eclipse instance installation dir, or even to specify a dir, i.e, c:\myRepository
At least, we should be able to export a task and its context and then import it into another local repository. Can't we do that?
Thanks.
Re: is sharing the mylyn DB folder between eclipse instances ok? [message #599886 is a reply to message #599881] Fri, 30 October 2009 14:28 Go to previous message
Simple solution is to subscribe for some free repository service :-)
For example, hosted FogBugz repository is free for 2 users
(http://www.fogcreek.com/FogBugz/StudentAndStartup.html), and Foglyn,
FogBugz connector for Mylyn, can also be used for free for this FogBugz
edition (http://www.foglyn.com/fogbugz-startups-students.html).
I think it is also possible to find free Trac hosting or some other
repository which will suit your needs.
-Peter
> Thanks.
Previous Topic:Re: Automatic changesets aren't, well, doing anything
Next Topic:[wiki editor] line end vs. long wrapped lines
Current Time: Fri Jul 25 22:53:12 EDT 2025
Powered by FUDForum. Page generated in 0.03626 seconds
