Home » Language IDEs » AspectJ » ITDed method refers to missing type
ITDed method refers to missing type [message #73303] Mon, 23 February 2009 11:38 Go to next message
While playing along with AJDT and AspectJ Inter Type Declarations I came
across the following annoyance:
When I create an Aspect with an ITD method that returns a custom class
object (from an included dependency) and declare the necessary import
statements in my Aspect, those imports are not automatically weaved in. It
gives me the error "The method ... from the type ... refers to the missing
type ..." in my client application, without an Eclipse quick fix
suggestion :|
When I add the imports manually, everything compiles correctly...
but! a CTRL-SHIFT-F will remove the import again :(
Since we have a team rule to always format the code before committing, I
expect a lot of problems here!
Re: ITDed method refers to missing type [message #73340 is a reply to message #73303] Mon, 23 February 2009 13:56 Go to previous messageGo to next message
Originally posted by: andrew.eisenberg.springsource.com
In the past, there was a bug that if ITDs were not fully qualified *or* the
target type did not import the referenced classes, there would be the editor
error that you mentioned below. I thought that this had been addressed in
recent releases of AJDT, but apparently not.
In the short term, you can try fully-qualifying the ITDs (ie- java.util.List
MyClass.doSomething(java.util.Set set) { ... } ). See if that addresses
your problem.
Can you send the offending ITDs to me. Would be great if you can include
the full aspect and target type. If you don't want to send to the
newsgroup, you can send to me directly.
On 23/02/09 8:38 AM, in article
cf011e0db94ad43550a8e692342f0894$1@www.eclipse.org, "Filip Croes"
> suggestion :|
Re: ITDed method refers to missing type [message #73375 is a reply to message #73340] Tue, 24 February 2009 07:48 Go to previous messageGo to next message
You were right, fully-qualifying the ITDs seems to solve the "missing
type" problem! Thanks.
I've uploaded a testproject where the bug is exposed. The key to
reproducing the problem is the annotation on the IApp interface.
http://www.2shared.com/file/4946991/815703b0/aspects-example 2.html
Also include in the ZIP is a screenshot of another issue I discovered: the
extract local variable refactoring complains about undefined ITDed methods.
Filip
Re: ITDed method refers to missing type [message #73406 is a reply to message #73375] Tue, 24 February 2009 13:08 Go to previous message
See:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=265986
On 24/02/09 4:48 AM, in article
bdce88722c83393d7f7606a6aabb3a2f$1@www.eclipse.org, "Filip Croes"
> Filip
Re: ITDed method refers to missing type [message #599699 is a reply to message #73303] Mon, 23 February 2009 13:56 Go to previous message
your problem.
> suggestion :|
Re: ITDed method refers to missing type [message #599714 is a reply to message #73340] Tue, 24 February 2009 07:48 Go to previous message
Filip
Re: ITDed method refers to missing type [message #599732 is a reply to message #73375] Tue, 24 February 2009 13:08 Go to previous message
See:
> Filip
Previous Topic:'Syntax error on token "class"'-error with special package name
Next Topic:Problema class nested
Current Time: Wed Jul 23 08:44:44 EDT 2025
Powered by FUDForum. Page generated in 0.05363 seconds
