Home » Eclipse Projects » Nebula » FormattedText not working in JFace data binding scenario
FormattedText not working in JFace data binding scenario [message #532592] Mon, 10 May 2010 10:22 Go to next message
Hello
I am using the FormattedText widget, and to perform databinding I am using a
JFace, PojoObservables setup.
Here is the interesting code:
IObservableValue uiElement =
SWTObservables.observeSelection(field.getValueControl());
IObservableValue modelElement = PojoObservables.observeValue(modelObject,
field.getId());
IValidator validator = field.getUiValidators().iterator().next();
UpdateValueStrategy strategy = new
UpdateValueStrategy().setAfterConvertValidator(validator);
bindingContext.bindValue(uiElement, modelElement, strategy, null);
field.getValueControl() returns the text widget on the FormattedText widget,
i.e it calls FormattedText.getControl().
It seems that when I save a value which fails validation, and then reload
the model object into the UI, then I only get the first couple of digits in
the number in the text control.
Whats the correct process for binding to the FormattedText? Should I just be
setting the underlying Text widget?
Re: FormattedText not working in JFace data binding scenario [message #532700 is a reply to message #532592] Mon, 10 May 2010 17:19 Go to previous messageGo to next message
To perform databinding on a FormattedText, you can use
FormattedTextObservableValue. I added it recently (2 month ago).
Look at NumberFormatterDataBindingSnippet for an example.
Eric
> Hello
> using a JFace, PojoObservables setup.
> PojoObservables.observeValue(modelObject, field.getId());
> widget, i.e it calls FormattedText.getControl().
> reload the model object into the UI, then I only get the first couple of
> digits in the number in the text control.
> just be setting the underlying Text widget?
Re: FormattedText not working in JFace data binding scenario [message #532795 is a reply to message #532700] Tue, 11 May 2010 05:05 Go to previous message
Hi Eric
I tried this out, but I couldn't get it to bind.
I noticed the snippet uses PropertyChangeSupport (BeansObservables), I am
actually trying to use PojoObservables. I also have a ControlDecorator setup
on the widget, which doesnt seem to fire.
Any ideas off the top of the head?
Thanks again
Greg
"Eric Wuillai" <eric@wdev91.com> wrote in message
news:hs9t98$odq$1@build.eclipse.org...
> Eric
>> Hello
Re: FormattedText not working in JFace data binding scenario [message #599598 is a reply to message #532592] Mon, 10 May 2010 17:19 Go to previous message
Eric
> Hello
Re: FormattedText not working in JFace data binding scenario [message #599605 is a reply to message #532700] Tue, 11 May 2010 05:05 Go to previous message
Hi Eric
Thanks again
Greg
> Eric
>> Hello
Previous Topic:FormattedText not working in JFace data binding scenario
Next Topic:Empty Nebula DateChooserCombo
Current Time: Sun Jul 27 11:50:37 EDT 2025
Powered by FUDForum. Page generated in 0.04639 seconds
