Home » Archived » Visual Editor (VE) » MIgrating from Netbeans 3.6 to Eclipse 3.0.1
MIgrating from Netbeans 3.6 to Eclipse 3.0.1 [message #61129] Sun, 26 September 2004 06:11 Go to next message
Originally posted by: jroman.ecua.net.ec
Is it possible to migrate forms developed with Netbeans 3.6 to Eclipse
3.0.1 ?
Thanks in advane.
jrr
Re: MIgrating from Netbeans 3.6 to Eclipse 3.0.1 [message #61401 is a reply to message #61129] Mon, 27 September 2004 07:01 Go to previous messageGo to next message
HiJimmy
> 3.0.1 ?
Can you give it a try ? Just take the .java file and import it into
Eclipse and open it with the VE ? Let us know what happens, and also
can you post the file you're trying to open and we'll take a look and it
might be just a small tweak required to make it work and it'll also help
us to learn more about code styles the VE should parse.
Joe Winchester
Re: MIgrating from Netbeans 3.6 to Eclipse 3.0.1 [message #63378 is a reply to message #61401] Thu, 30 September 2004 02:13 Go to previous messageGo to next message
Originally posted by: calschut.nospam.gmail.com
I just tried it with the "Anagrams" example that comes with the Netbeans
4.0 beta 1 and it did work too well. But it shows up correctly when you
"Run as Java Bean" and of course if you run as an app.
Heres a screen shot showing VE and the Actual version:
http://www.sfu.ca/~cschut/netbeansToVE.gif
-Cal
Re: MIgrating from Netbeans 3.6 to Eclipse 3.0.1 [message #63443 is a reply to message #63378] Thu, 30 September 2004 09:48 Go to previous messageGo to next message
> -Cal
Can you include a sample source
Re: MIgrating from Netbeans 3.6 to Eclipse 3.0.1 [message #70317 is a reply to message #63378] Mon, 08 November 2004 11:44 Go to previous message
Hi calvin,
I think the problem is how the NetBeans code is using its
GridBagConstraints. They re-use the same field, e.g.
GridBagConstraints constraints = new GridBagConstraints();
panel.add(component1,constraints);
constraints.gridx = 2;
panel.add(component2,constraints);
The VE parses code and currently does not deal with shared properties in
this way. It's a subtle thing that GridBagLayout does where in fact the
constraints are not shared (they are cloned by the layout manager),
because with any other piece of Java code objects are passed by
reference and changing the constraint and re-using it wouldn't be allowed.
We do have a bugzilla to deal with this kind of grid bag constraints
behavior as it is quite a common coding pattern, however in the meantime
try changing the source so that each GridBagConstraints is a new field, e.g.
GridBadConstraints constraints = new GridBagConstraints();
panel.add(component,constraints);
GridBagConstraints contstraints1 = new GridBagConstraints();
panel.add(component2,constraints1);
The key is that the single field for GridBagConstraints it not shared.
Once this change is done the VE should be able to open the source OK.
Joe Winchester
Re: MIgrating from Netbeans 3.6 to Eclipse 3.0.1 [message #599601 is a reply to message #61129] Mon, 27 September 2004 07:01 Go to previous message
HiJimmy
> 3.0.1 ?
Joe Winchester
Re: MIgrating from Netbeans 3.6 to Eclipse 3.0.1 [message #600181 is a reply to message #61401] Thu, 30 September 2004 02:13 Go to previous message
-Cal
Re: MIgrating from Netbeans 3.6 to Eclipse 3.0.1 [message #600210 is a reply to message #63378] Thu, 30 September 2004 09:48 Go to previous message
> -Cal
Re: MIgrating from Netbeans 3.6 to Eclipse 3.0.1 [message #602709 is a reply to message #63378] Mon, 08 November 2004 11:44 Go to previous message
Hi calvin,
Joe Winchester
Previous Topic:javaw multiple processes when working with VE
Next Topic:problem with grid layout
Current Time: Wed Sep 17 05:57:31 EDT 2025
Powered by FUDForum. Page generated in 0.04073 seconds
