Home » Eclipse Projects » Nebula » Gallery with SWT.VIRTUAL
Gallery with SWT.VIRTUAL [message #522998] |
Wed, 24 March 2010 13:37  |
I'm trying to use SWT.VIRTUAL on the gallery widget. I look at the official snippet.
Unfortunately,
if I let
gallery.setItemCount(100);
I've got a NPE:
at org.eclipse.nebula.widgets.gallery.Gallery.calculateSize(Gallery.java:1516)
at org.eclipse.nebula.widgets.gallery.Gallery.updateStructuralValues(Gallery.java:1455)
at org.eclipse.nebula.widgets.gallery.Gallery.setItemCount(Gallery.java:233)
If I remove it, none of my Image is displayed. And in fact the listener on SWT.SetData is never called.
Any hints are welcome.
regards,
Re: Gallery with SWT.VIRTUAL [message #523218 is a reply to message #523208] |
Thu, 25 March 2010 11:03   |
I tried with release and nightly version.
I also already tried wihtout setting virtual groups.
Here you can see what I've done, th ecommentary code is code that I tried. Notice that none of my listener is called.
final Gallery gallery = new Gallery(bottomComposite, SWT.V_SCROLL | SWT.BORDER | SWT.VIRTUAL);
gallery.setLayoutData(new GridData(330, 250));
// Renderers
DefaultGalleryGroupRenderer gr = new DefaultGalleryGroupRenderer();
gr.setItemSize(150, 100);
gr.setAlwaysExpanded(false);
gr.setMinMargin(3);
DefaultGalleryItemRenderer ir = new DefaultGalleryItemRenderer();
ir.setShowLabels(true);
gallery.setGroupRenderer(gr);
gallery.setItemRenderer(ir);
//gallery.setVirtualGroups(true);
gallery.addListener(SWT.SetData, new Listener() {
public void handleEvent(Event event) {
//never go here
GalleryItem item = (GalleryItem) event.item;
int index;
if (item.getParentItem() != null) {
index = item.getParentItem().indexOf(item);
item.setItemCount(0);
} else {
index = gallery.indexOf(item);
item.setItemCount(100);
System.out.println( "setData index " + index); //$NON-NLS-1$
// Your image here
if(item.getData("object") != null){
if(item.getData("object") instanceof FormRepositoryArtifact){
item.setImage(((FormRepositoryArtifact)item.getData("object")).getImage(getShell().getDisplay()/*Display.getCurrent()*/));
} else if(item.getData("object") instanceof Form){
item.setImage(createImage((Form) item.getData("object")));
// item.setImage(eclipseImage);
item.setText("Item " + index); //$NON-NLS-1$
//gallery.setItemCount(100);
GalleryItem groupTemplates = new GalleryItem(gallery, SWT.NONE);
groupTemplates.setText("Templates");
groupTemplates.addListener(SWT.SetData, new Listener(){
//never go here
// TODO Auto-generated method stub
System.out.println("test moi");
groupTemplates.addListener(SWT.Expand, new Listener(){
//never go here
System.out.println("enfin un event qui marche?");
gallery.setData(groupTemplates);
for(FormRepositoryArtifact artifact : FormRepository.getInstance().getAllArtifacts()){
GalleryItem g = new GalleryItem(groupTemplates, SWT.NONE);
g.setText(0, artifact.getName());
g.setText(1, ((Form)artifact.getContent()).getName());
g.setData("object", artifact);
//g.setImage(artifact.getImage(getShell().getDisplay()));
g.setItemCount(2);
gallery.setData(g);
for(AbstractProcess proc : ProcessRepository.getInstance().getAllProcesses()){
GalleryItem groupProc = new GalleryItem(gallery, SWT.NONE);
groupProc.setText(proc.getName());
for(Form form : ModelHelper.getAllFormsContainedIn(proc)){
GalleryItem g = new GalleryItem(groupProc, SWT.NONE);
g.setData("object", form);
g.setItemCount(2);
g.setText(0, form.getName());
//g.setImage(createImage(form));
[Updated on: Thu, 25 March 2010 12:49] by Moderator
Re: Gallery with SWT.VIRTUAL [message #523359 is a reply to message #523218] |
Fri, 26 March 2010 03:05   |
Aurelien,
The virtual snippet works for me and SetData is tested in gallery unit
tests : you should be able to get events. Could you try to run the
snippet as-is and run the tests in
org.eclipse.nebula.widgets.gallery.tests to ensure there really is an issue.
Looking at your code, I have the following comments :
- Avoid mixing virtual and non virtual code : don't use new GalleryItem
() if you are using SWT.VIRTUAL and SWT.SetData at the same time. This
is because SetData will only be called if a visible item is
uninitialized (null) on paint.
-> mixing is supported by is likely to produce unexpected results.
- With SWT, ASAIK SetData, or Expand listeners are never attached to
items but to the container. With Gallery, listener added on items will
never be used.
Try to replace Gallery by Tree and compare the behavior. If they are
different, please open a bug.
- setData is used for linking some object to a widget. This is only for
your code and never used by swt nor Gallery.
Nicolas
> // Renderers
> gr.setMinMargin(3);
> //never going into
> int index;
> } else {
> // Your image here
> item.setImage(((FormRepositoryArtifact)item.getData("object " )).getImage(getShell().getDisplay()/*Display.getCurrent()*/) );
> g.setItemCount(2);
> gallery.setData(g);
> g.setItemCount(2);
> // Renderers
> gr.setMinMargin(3);
> //never going into
> int index;
> } else {
> // Your image here
> //never going into
> //never going into
> g.setItemCount(2);
> gallery.setData(g);
> g.setItemCount(2);
Re: Gallery with SWT.VIRTUAL [message #599334 is a reply to message #523208] |
// Renderers
gr.setMinMargin(3);
//never going into
int index;
} else {
// Your image here
g.setItemCount(2);
gallery.setData(g);
g.setItemCount(2);
// Renderers
gr.setMinMargin(3);
//never going into
int index;
} else {
// Your image here
//never going into
//never going into
g.setItemCount(2);
gallery.setData(g);
g.setItemCount(2);
Aurelien Pupier - BonitaSoft S.A.
"http://scratsh.wordpress.com/"
Re: Gallery with SWT.VIRTUAL [message #599359 is a reply to message #599334] |
Aurelien,
never be used.
Nicolas
> // Renderers
> gr.setMinMargin(3);
> //never going into
> int index;
> } else {
> // Your image here
> g.setItemCount(2);
> gallery.setData(g);
> g.setItemCount(2);
> // Renderers
> gr.setMinMargin(3);
> //never going into
> int index;
> } else {
> // Your image here
> //never going into
> //never going into
> g.setItemCount(2);
> gallery.setData(g);
> g.setItemCount(2);
Current Time: Sun Jul 27 03:55:08 EDT 2025
Powered by FUDForum. Page generated in 0.10842 seconds
