Home » Eclipse Projects » Plugin Development Environment (PDE) » Feature based app is exporting fine but not starting with exit code -1
Feature based app is exporting fine but not starting with exit code -1 [message #67635] Thu, 09 July 2009 12:11 Go to next message
beside my feature based RCP app not able to run inside 3.5 anymore it
also has problems when exported. It exports fine but is not startable.
The error message is visible here:
http://screencast.com/t/Kr4Lr65dOh
Even Deltapacks are in the target platform.
I have no idea what that means.
Phil
Re: Feature based app is exporting fine but not starting with exit code -1 [message #67693 is a reply to message #67635] Thu, 09 July 2009 13:04 Go to previous messageGo to next message
Philipp Kursawe wrote:
> Hello,
Do you have some logs generated anywhere in the metadata area? There
isn't much to go on here... mostly signifies that a problem has happened
very early in the launching process (ie., maybe not pointing to the
proper osgi jar etc...)
Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
Re: Feature based app is exporting fine but not starting with exit code -1 [message #67713 is a reply to message #67693] Thu, 09 July 2009 14:10 Go to previous messageGo to next message
>> Hello,
Unfortunatly nothing is logged. Not even a workspace is generated. The
thing is, on an older I-Build of 3.5 the export works and the RCP app
runs. I will keep you updated.
Phil
Re: Feature based app is exporting fine but not starting with exit code -1 [message #67734 is a reply to message #67693] Thu, 09 July 2009 14:33 Go to previous messageGo to next message
>> Hello,
Here is the output when i start with -console:
Exception in thread "main" java.lang.NoClassDefFoundError:
org/eclipse/equinox/launcher/JNIBridge
Caused by: java.lang.ClassNotFoundException:
org.eclipse.equinox.launcher.JNIBridge
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClassInternal(Unknown Source)
org/eclipse/equinox/launcher/Main
org.eclipse.equinox.launcher.Main
Re: Feature based app is exporting fine but not starting with exit code -1 [message #67755 is a reply to message #67734] Thu, 09 July 2009 15:08 Go to previous messageGo to next message
This usually signifies a launcher fragment can't be found properly.
What are you booting with? Can you run with -debug so we can see the
initial boot constants...
BootLoader constants: OS=win32, ARCH=x86, etc...
I have a feeling that one of those values may be wrong... or a launcher
fragment is missing somehow.
You could also be bit by this bug atm:
[product] not added to feature based product without deltapack
https://bugs.eclipse.org/bugs/show_bug.cgi?id=281224
That will be fixed for 3.5.1 and 3.6M1
Re: Feature based app is exporting fine but not starting with exit code -1 [message #67776 is a reply to message #67755] Thu, 09 July 2009 18:25 Go to previous messageGo to next message
Chris, the fragment for win32 x86 is there, its unpacked in plugins.
The loader wants to load win32 x86, and even with deltapack installed
its no change.
I am little confused here, as it was working 2 days ago without any
updates happened to the target platform meanwhile.
Phil
Re: Feature based app is exporting fine but not starting with exit code -1 [message #67796 is a reply to message #67755] Thu, 09 July 2009 18:47 Go to previous messageGo to next message
I found the reason for it!
I had imported all the required bundles from the target platform as
binary plugins into my workspace. So I could test a feature based run
configuration inside the IDE. Well, it seems that it does not work for 2
reasons. One seems to be that, even though they are supposed to be
binary projects, they contain a *source.jar and the code of the plugin
inside another *jar INSIDE the actual plugin.jar. And the classpath was
wrong in all target platform imported plugins. PDE or whoever is
responsible for importing plugins into the workspace does it wrong. You
end up with a launcherXXX.jar plugin that contains a launcher.src.jar
and a launcher.jar but the classpath in the manifest is not adjusted to
point to launcher.jar INSIDE the plugin. For whatever reason the
exporter/importer decides to repackage the plugin instead of just
copying it from the target platform.
I hope I made clear what goes wrong. If not I will post such a damaged
exported plugin.
Thats how the plugin looks like after the import (using Import wizard
with BINARY plugin option):
http://screencast.com/t/t1R5yRTw6
Any ideas?
Phil
Re: Feature based app is exporting fine but not starting with exit code -1 [message #67856 is a reply to message #67796] Fri, 10 July 2009 11:30 Go to previous message
There is a bug https://bugs.eclipse.org/bugs/show_bug.cgi?id=240821.
The workaround is not have the imported binary projects in your
workspace when you do the export. Build will find them in the target.
-Andrew
> exported plugin.
> Any ideas?
> Phil
Re: Feature based app is exporting fine but not starting with exit code -1 [message #599170 is a reply to message #67635] Thu, 09 July 2009 13:04 Go to previous message
> Hello,
Re: Feature based app is exporting fine but not starting with exit code -1 [message #599178 is a reply to message #67693] Thu, 09 July 2009 14:10 Go to previous message
>> Hello,
Phil
Re: Feature based app is exporting fine but not starting with exit code -1 [message #599186 is a reply to message #67693] Thu, 09 July 2009 14:33 Go to previous message
>> Hello,
Re: Feature based app is exporting fine but not starting with exit code -1 [message #599197 is a reply to message #67734] Thu, 09 July 2009 15:08 Go to previous message
Re: Feature based app is exporting fine but not starting with exit code -1 [message #599201 is a reply to message #67755] Thu, 09 July 2009 18:25 Go to previous message
its no change.
Phil
Re: Feature based app is exporting fine but not starting with exit code -1 [message #599206 is a reply to message #67755] Thu, 09 July 2009 18:47 Go to previous message
exported plugin.
Any ideas?
Phil
Re: Feature based app is exporting fine but not starting with exit code -1 [message #599233 is a reply to message #67796] Fri, 10 July 2009 11:30 Go to previous message
-Andrew
> exported plugin.
> Any ideas?
> Phil
Previous Topic:External tool implementation
Next Topic:Editor plugin doesn't work on Mac
Current Time: Wed Jul 23 19:01:32 EDT 2025
Powered by FUDForum. Page generated in 0.05287 seconds
