Generic importation of processes from EPF/Composer with an JEE application [message #598931] |
Wed, 28 October 2009 14:31  |
We are currently working on the maintenance and enrichment of a
software project management, named Wilos, based on processes.
It is an application in JEE.
That's why, the softaware import processes from EPF/Composer.
But currently, only versions 1.0.2 and earlier are accepted,
so we must change the structure of imports in order to
use the process established by the latest version of EPF/Composer.
However we would like to change the import of the EPF processes to become
more generic so that in future developments of EPF/Composer, it is not
necessary to change the structure of our imports.
Could you give us information that can help us to do this?
Thank you in advance for your help
Wilos Team
Website of Wilos : http://www.wilos.ups-tlse.fr/
Re: Generic importation of processes from EPF/Composer with an JEE application [message #598980 is a reply to message #598931] |
Thu, 12 November 2009 05:39  |
Hello EPF Composer community,
Our goal is to make the importation of generic XML file. That's why we need to know if you plan to add new XML tags, or to delete, modify some XML tags of the XML file exported from a process designed by EPF Composer. Do you understand what we need ? Can someone help the wilos team ?
We would like to contact the project manager EPF Composer by e-mail, or if he exists the responsable of the XML file export or an equivalent. Does someone know his e-mail adress ?
FUDForum. Page generated in 0.04909 seconds
