Home » Eclipse Projects » Nebula » Grid - using the Selection Service
Grid - using the Selection Service [message #500894] Mon, 30 November 2009 03:05 Go to next message
I'm new to Nebula and RCP and my problem is that I don't know how to use the Grid with the RCP Selection Service.
In my RCP Application i have a view with a grid - but how can i get the current selection of the grid so i can use it in my command handlers?
Re: Grid - using the Selection Service [message #500946 is a reply to message #500894] Mon, 30 November 2009 07:15 Go to previous messageGo to next message
You need to use a GridViewer and register it in the selection service.
Tom
Michael Lindner schrieb:
> Hello,
Re: Grid - using the Selection Service [message #500993 is a reply to message #500894] Mon, 30 November 2009 10:48 Go to previous messageGo to next message
Ok I tried to use a GridTreeViewer and my view looks like this:
viewer = new GridTreeViewer(parent, SWT.MULTI | SWT.H_SCROLL
				| SWT.V_SCROLL);
		GridColumn column = new GridColumn(viewer,SWT.NONE);
		column.setWidth(200);
		column.setText("foo");
		column.setTree(true);
		GridColumn column2 = new GridColumn(viewer,SWT.None);
		column2.setWidth(200);
		column2.setText("bar");
		viewer.setContentProvider(new MyContentProvider());
		viewer.getGrid().setHeaderVisible(true);
Now I add GridItems to the viewer
GridItem item1 = new GridItem(viewer.getGrid(),SWT.NONE);
GridItem item2 = new GridItem(item1,SWT.NONE);
When I run the application the Rootelement(item1) is displayed with a plus, but when I klick on the plus nothing happens...
Re: Grid - using the Selection Service [message #501098 is a reply to message #500993] Mon, 30 November 2009 20:59 Go to previous messageGo to next message
Whenever using a viewer you should not interface with the underlying
control but using LabelProvider and ContentProviders.
You need to get familiar with JFace concepts.
Tom
> | SWT.V_SCROLL);
Re: Grid - using the Selection Service [message #501208 is a reply to message #500894] Tue, 01 December 2009 09:31 Go to previous message
Thank you for your help
I think I understand the concepts of the JFace viewer so far, but I don't want to create my own DomainObjects but instead use the standard GridItems.
Or are they not supported by the GridTreeViewer?
It is clear now that I have to use the setInput() Method instead of interfacing with the underlying control.
Michael
Re: Grid - using the Selection Service [message #598725 is a reply to message #500993] Mon, 30 November 2009 20:59 Go to previous message
Tom
> | SWT.V_SCROLL);
Previous Topic:Listener for resize and moving of columns in grid view
Next Topic:Grid - using the Selection Service
Current Time: Sat Jul 26 10:25:08 EDT 2025
Powered by FUDForum. Page generated in 0.07349 seconds
