Home » Eclipse Projects » Nebula » Nebula grid - get selected values
Nebula grid - get selected values [message #478828] Fri, 07 August 2009 03:35 Go to next message
i use the nebula grid component to load spreadsheet values.
In some operations i need to get all selected values which can be in one block (as usual) or in many blocks (using control and/or Shift).
If i want to get all values in many blocks (using the Control-key: select one column->pressing Control->select another column)
i get some values twice (the first number in the spread in the next selection block).
i use:
Point[] sel = grid.getCellSelection();
String[] data = new String[sel.length];
for (int i = 0; i < sel.length; i++) {
data[i] = grid.getItem(sel[i].y).getText(sel[i].x);
System.out.println(data[i]);
Is this a normal behaviour of nebula grid?
With kind regards
Marcel
Re: Nebula grid - get selected values [message #489272 is a reply to message #478828] Fri, 02 October 2009 04:08 Go to previous messageGo to next message
I could remove double entries of the selection as a workaround
but is this a bug of the Nebula grid component?
I also want to remove columns from a selection reliable.
Any information is appreciated!
Re: Nebula grid - get selected values [message #489309 is a reply to message #489272] Fri, 02 October 2009 07:11 Go to previous messageGo to next message
Most likely but I don't have time to work on it :-(
Tom
Re: Nebula grid - get selected values [message #489317 is a reply to message #489309] Fri, 02 October 2009 08:12 Go to previous messageGo to next message
Crying or Very Sad
It would help me to avoid selections if control is pressed together
with a mouse drag event (to remove columns reliable).
Is there a swt mouse drag listener available i could use for the nebula grid?
Re: Nebula grid - get selected values [message #490911 is a reply to message #478828] Mon, 12 October 2009 07:37 Go to previous messageGo to next message
My workaround for the moment is that i do not permit a selection
(delete selection) if a drag event occurs and the controll key
is pressed. This works so far for my purposes.
Re: Nebula grid - get selected values [message #494470 is a reply to message #490911] Fri, 30 October 2009 14:54 Go to previous messageGo to next message
I have uploaded a patch to fix this bug.
Here is the link to the patch.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=293824
Marty
Re: Nebula grid - get selected values [message #494677 is a reply to message #494470] Mon, 02 November 2009 02:49 Go to previous messageGo to next message
Great!
Is the patch available with the nightly built?
Re: Nebula grid - get selected values [message #494683 is a reply to message #494677] Mon, 02 November 2009 02:54 Go to previous messageGo to next message
No, not yet because I didn't had time to apply it.
Tom
Marcel schrieb:
> Great!
Re: Nebula grid - get selected values [message #494720 is a reply to message #494683] Mon, 02 November 2009 06:14 Go to previous messageGo to next message
Thanks for the information!
Can i patch the class myself?
I only found the code fragment not the whole class which was patched.
Re: Nebula grid - get selected values [message #494721 is a reply to message #494720] Mon, 02 November 2009 06:16 Go to previous messageGo to next message
You need to fetch the sources from CVS, Copy the patch and Apply it
using Eclipse (Team > Apply Patch).
Tom
Marcel schrieb:
> Thanks for the information! Can i patch the class myself?
Re: Nebula grid - get selected values [message #494749 is a reply to message #494721] Mon, 02 November 2009 08:52 Go to previous messageGo to next message
I applied the patch and it seems to work!
Many thanks for your efforts (and fast replies!).
Best regards
Marcel
Re: Nebula grid - get selected values [message #494759 is a reply to message #494749] Mon, 02 November 2009 09:38 Go to previous messageGo to next message
Good deal.
Re: Nebula grid - get selected values [message #598345 is a reply to message #489309] Fri, 02 October 2009 08:12 Go to previous messageGo to next message
:cry:
Re: Nebula grid - get selected values [message #598523 is a reply to message #490911] Fri, 30 October 2009 14:54 Go to previous messageGo to next message
Marty
Re: Nebula grid - get selected values [message #598529 is a reply to message #598523] Mon, 02 November 2009 02:49 Go to previous messageGo to next message
Great!
Re: Nebula grid - get selected values [message #598535 is a reply to message #598529] Mon, 02 November 2009 02:54 Go to previous messageGo to next message
Tom
Marcel schrieb:
> Great!
Re: Nebula grid - get selected values [message #598537 is a reply to message #494683] Mon, 02 November 2009 06:14 Go to previous messageGo to next message
Re: Nebula grid - get selected values [message #598542 is a reply to message #598537] Mon, 02 November 2009 06:16 Go to previous messageGo to next message
Tom
Re: Nebula grid - get selected values [message #598549 is a reply to message #494721] Mon, 02 November 2009 08:52 Go to previous messageGo to next message
Best regards
Marcel
Re: Nebula grid - get selected values [message #598555 is a reply to message #494749] Mon, 02 November 2009 09:38 Go to previous message
Good deal.
Previous Topic:GridTableViewer Sorting
Next Topic:Date/Calendar widgets - any validation support?
Current Time: Sun Jul 27 22:22:42 EDT 2025
Powered by FUDForum. Page generated in 0.10064 seconds
