Home » Archived » XML Schema Definition (XSD) » XML Generation and element hiding
XML Generation and element hiding [message #67811] Fri, 21 April 2006 05:49 Go to next message
I am looking for a way to simplify this bit of XML Schema. Namely, I
have an element which is not useful ("XXX"), but required ID-wise. The
purpose of this is to generate some XML.
<xsd:complexType name="listeningDataType" ecore:name="listeningData">
<xsd:sequence>
<xsd:element minOccurs="1" maxOccurs="unbounded" name="datas"
type="datasType"/>
</xsd:sequence>
<!-- Couple of attributes there -->
</xsd:complexType>
<xsd:complexType name="datasType" ecore:name="datas">
<xsd:sequence>
<xsd:element minOccurs="1" maxOccurs="1" name="dataId"
type="xsd:IDREF" ecore:reference="dataidtype"/>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="outputType" ecore:name="output">
<xsd:sequence>
<xsd:element minOccurs="0" maxOccurs="unbounded" name="XXX"
type="dataidtype"/>
</xsd:sequence>
</xsd:complexType>
<xsd:complexType name="dataidtype" ecore:name="dataId">
<xsd:sequence>
<xsd:element name="dataId" type="xsd:ID"/>
</xsd:sequence>
</xsd:complexType>
Using this schema, I end up with the following generated XML code (via
EMF):
<output [.. some attributes...]>
<XXX>
<dataId>myDataId</dataId>
</XXX>
</output>
<listeningdata [... some attributes ...]>
<datas>
</datas>
</listeningdata>
As you can guess, I would like to get rid of the XML element "XXX", but
still would like to be able to include 'dataidtype' in 'output'.
Eventually, is there a way not to make it appear during the XML generation?
Any ideas?
Re: XML Generation and element hiding [message #67836 is a reply to message #67811] Fri, 21 April 2006 07:13 Go to previous messageGo to next message
Guillaume,
One suggestion. Data is plural for datum, so datas is kind of bad.
Since you can't have multiple IDs for a given element, I'd need to know
what goal you are trying to achieve by having what's effectively just a
list of IDs.
Guillaume Windels wrote:
> Hello,
> <xsd:sequence>
> type="datasType"/>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> type="dataidtype"/>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> EMF):
> <XXX>
> </XXX>
> </output>
> <datas>
> </datas>
> </listeningdata>
> but still would like to be able to include 'dataidtype' in 'output'.
> generation?
> Any ideas?
Re: XML Generation and element hiding [message #67854 is a reply to message #67836] Fri, 21 April 2006 07:44 Go to previous messageGo to next message
Thanks for the suggestion, it always helps.
As for the goal, I actually would like, insides 'datas' to be able to
make a reference to a 'dataid' residing in a pool of 'dataid' defined
into the 'output'.
In other words, this is a simple 'calculator' I'd like the Schema to
reflect.
<process>
<output>dataIdC</output>
<input>dataIdB</input>
<process>
<output>dataIdB</output>
<input>dataIdA</input>
</process>
</process>
I thought the way I did it was the most relevant
Ed Merks a écrit :
> Guillaume,
> list of IDs.
>> Hello,
>> <xsd:sequence>
>> type="datasType"/>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> type="dataidtype"/>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence> </xsd:complexType>
>> EMF):
>> <XXX>
>> </XXX>
>> </output>
>> <datas>
>> </datas>
>> </listeningdata>
>> generation?
>> Any ideas?
Re: XML Generation and element hiding [message #67872 is a reply to message #67854] Fri, 21 April 2006 07:55 Go to previous messageGo to next message
Guillaume,
Perhaps what you want is a complex type with simple content that extends
ID as the base type. Note that using elements of type ID is permitted
but is specifically recommended against by the XML Schema specification.
<xsd:complexType name="SimpleContentComplexTypeDefinition">
<xsd:simpleContent>
<xsd:extension base="xsd:ID">
</xsd:extension>
</xsd:simpleContent>
</xsd:complexType>
> into the 'output'.
> reflect.
> <process>
> <process>
> </process>
> </process>
> Ed Merks a écrit :
>> Guillaume,
>> know what goal you are trying to achieve by having what's effectively
>> just a list of IDs.
>>> Hello,
>>> The purpose of this is to generate some XML.
>>> <xsd:sequence>
>>> type="datasType"/>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> type="dataidtype"/>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> (via EMF):
>>> <XXX>
>>> </XXX>
>>> </output>
>>> <datas>
>>> </datas>
>>> </listeningdata>
>>> generation?
>>> Any ideas?
Re: XML Generation and element hiding [message #68077 is a reply to message #67872] Tue, 09 May 2006 10:13 Go to previous messageGo to next message
Ed,
"Note that using elements of type ID is permitted but is specifically
recommended against by the XML Schema specification."
Thanks, is there an explanation for that?
How about IDREF?
Ed Merks a écrit :
> Guillaume,
> <xsd:simpleContent>
> </xsd:extension>
> </xsd:complexType>
>> into the 'output'.
>> reflect.
>> <process>
>> <process>
>> </process>
>> </process>
>> Ed Merks a écrit :
>>> Guillaume,
>>> just a list of IDs.
>>>> Hello,
>>>> <xsd:sequence>
>>>> type="datasType"/>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> type="dataidtype"/>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> (via EMF):
>>>> <XXX>
>>>> </XXX>
>>>> </output>
>>>> <datas>
>>>> </datas>
>>>> </listeningdata>
>>>> generation?
>>>> Any ideas?
Re: XML Generation and element hiding [message #68093 is a reply to message #68077] Tue, 09 May 2006 11:20 Go to previous message
--------------050902010907020602040300
Guillaume,
The spec says the same thing for IDREF
http://www.w3.org/TR/xmlschema-2/#IDREF:
For compatibility (see Terminology (
Re: XML Generation and element hiding [message #597995 is a reply to message #67811] Fri, 21 April 2006 07:13 Go to previous message
Guillaume,
list of IDs.
> Hello,
> <xsd:sequence>
> type="datasType"/>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> type="dataidtype"/>
> </xsd:sequence>
> </xsd:complexType>
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> EMF):
> <XXX>
> </XXX>
> </output>
> <datas>
> </datas>
> </listeningdata>
> generation?
> Any ideas?
Re: XML Generation and element hiding [message #598001 is a reply to message #67836] Fri, 21 April 2006 07:44 Go to previous message
into the 'output'.
reflect.
<process>
<process>
</process>
</process>
Ed Merks a écrit :
> Guillaume,
> list of IDs.
>> Hello,
>> <xsd:sequence>
>> type="datasType"/>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> type="dataidtype"/>
>> </xsd:sequence>
>> </xsd:complexType>
>> <xsd:sequence>
>> EMF):
>> <XXX>
>> </XXX>
>> </output>
>> <datas>
>> </datas>
>> </listeningdata>
>> generation?
>> Any ideas?
Re: XML Generation and element hiding [message #598008 is a reply to message #67854] Fri, 21 April 2006 07:55 Go to previous message
Guillaume,
<xsd:simpleContent>
</xsd:extension>
</xsd:complexType>
> into the 'output'.
> reflect.
> <process>
> <process>
> </process>
> </process>
> Ed Merks a écrit :
>> Guillaume,
>> just a list of IDs.
>>> Hello,
>>> <xsd:sequence>
>>> type="datasType"/>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> type="dataidtype"/>
>>> </xsd:sequence>
>>> </xsd:complexType>
>>> <xsd:sequence>
>>> (via EMF):
>>> <XXX>
>>> </XXX>
>>> </output>
>>> <datas>
>>> </datas>
>>> </listeningdata>
>>> generation?
>>> Any ideas?
Re: XML Generation and element hiding [message #598064 is a reply to message #67872] Tue, 09 May 2006 10:13 Go to previous message
Ed,
How about IDREF?
Ed Merks a écrit :
> Guillaume,
> <xsd:simpleContent>
> </xsd:extension>
> </xsd:complexType>
>> into the 'output'.
>> reflect.
>> <process>
>> <process>
>> </process>
>> </process>
>> Ed Merks a écrit :
>>> Guillaume,
>>> just a list of IDs.
>>>> Hello,
>>>> <xsd:sequence>
>>>> type="datasType"/>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> type="dataidtype"/>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> <xsd:sequence>
>>>> (via EMF):
>>>> <XXX>
>>>> </XXX>
>>>> </output>
>>>> <datas>
>>>> </datas>
>>>> </listeningdata>
>>>> generation?
>>>> Any ideas?
Re: XML Generation and element hiding [message #598070 is a reply to message #68077] Tue, 09 May 2006 11:20 Go to previous message
Guillaume,
Previous Topic:XSDImporter.java cannot run headless
Next Topic:getFacets() Vs getFacetContents()
Current Time: Sun Jul 27 07:32:20 EDT 2025
Powered by FUDForum. Page generated in 0.09193 seconds
