Home » Archived » XML Schema Definition (XSD) » Embedded elements
Embedded elements [message #67497] Mon, 10 April 2006 16:08 Go to next message
I am trying to build a XML Schema to then being able to generate a XML
file that would look like this:
<root>
<process>
<input>
<data>blah</data>
</input>
<output>
<data>bloh</data>
</output>
<process>
<output>
<data>blah</data>
</output>
</process>
</process>
</root>
As you can see, a <process> produces <output>s, uses <input>, and can
contain itself. My question is, how can we render, in XSD, the fact that
a <data> can be reused in two different objects?
Cheers -
Re: Embedded elements [message #67519 is a reply to message #67497] Mon, 10 April 2006 16:14 Go to previous messageGo to next message
Guillaume,
Define it as a global element and use <element ref="..."/> to refer to
it in multiple complex types.
> <root>
> <process>
> <input>
> <data>blah</data>
> </input>
> <output>
> <data>bloh</data>
> </output>
> <process>
> <output>
> <data>blah</data>
> </output>
> </process>
> </process>
> </root>
> that a <data> can be reused in two different objects?
> Cheers -
Re: Embedded elements [message #67539 is a reply to message #67519] Tue, 11 April 2006 04:27 Go to previous messageGo to next message
Thanks Ed.
Using a global element, would I still be able to add a reference to it
since a <data> element is used by both <input> and <output>?
Ed Merks a écrit :
> Guillaume,
>> <root>
>> <process>
>> <input>
>> <data>blah</data>
>> </input>
>> <output>
>> <data>bloh</data>
>> </output>
>> <process>
>> <output>
>> <data>blah</data>
>> </output>
>> </process>
>> </process>
>> </root>
>> Cheers -
Re: Embedded elements [message #67560 is a reply to message #67539] Tue, 11 April 2006 05:42 Go to previous messageGo to next message
Guillaume,
A global element can be referenced anywhere. A different approach is to
define global types and to reuse those. I.e., each occurrence of <data>
could be specified with a different local element declaration that
references the same globally defined type.
> Thanks Ed.
> Ed Merks a écrit :
>> Guillaume,
>> to it in multiple complex types.
>>> XML file that would look like this:
>>> <root>
>>> <process>
>>> <input>
>>> <data>blah</data>
>>> </input>
>>> <output>
>>> <data>bloh</data>
>>> </output>
>>> <process>
>>> <output>
>>> <data>blah</data>
>>> </output>
>>> </process>
>>> </process>
>>> </root>
>>> can contain itself. My question is, how can we render, in XSD, the
>>> fact that a <data> can be reused in two different objects?
>>> Cheers -
Re: Embedded elements [message #67589 is a reply to message #67560] Tue, 11 April 2006 06:21 Go to previous messageGo to next message
That's fair enough.
However, defining a global element seems to mix up with the root
element. How can you tell you schema that a global element should not
have such behaviour?
Let me clarify that.
This is the start of my XML Schema:
<xsd:element name="processGroup" type="proc:processGroup"/>
<xsd:element name="dataId" type="xsd:string"/>
<xsd:complexType name="processGroup">
<xsd:sequence>
<xsd:element name="name" type="xsd:string"/>
<xsd:element name="process" minOccurs="1" maxOccurs="unbounded"
type="proc:process"/>
</xsd:sequence>
</xsd:complexType>
In the schema, <dataId> stands for <data> (as discussed earlier).
Take a look at the following screenshot:
http://img84.imageshack.us/img84/5367/dataid8lp.jpg
ProcessModel1 is the DocumentRoot. How could you explain there is a link
between ProcessModel1 and dataId?
Ed Merks a écrit :
> Guillaume,
>> Thanks Ed.
>> Ed Merks a écrit :
>>> Guillaume,
>>>> <root>
>>>> <process>
>>>> <input>
>>>> <data>blah</data>
>>>> </input>
>>>> <output>
>>>> <data>bloh</data>
>>>> </output>
>>>> <process>
>>>> <output>
>>>> <data>blah</data>
>>>> </output>
>>>> </process>
>>>> </process>
>>>> </root>
>>>> Cheers -
Re: Embedded elements [message #67610 is a reply to message #67589] Tue, 11 April 2006 07:04 Go to previous messageGo to next message
Guillaume,
Comments below.
> That's fair enough.
> However, defining a global element seems to mix up with the root element.
Root element is not a term that has meaning in the XML Schema specification.
> How can you tell you schema that a global element should not have such
> behaviour?
Since it doesn't mean anything to an XML Schema, you can't preclude such
behavior. As such, if you only want to have a single global element
declaration to represent the one and only valid root element of a
document, you'll need to avoid global element declarations for all other
cases. That's where having local element declarations of some shared
global type should help you...
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> link between ProcessModel1 and dataId?
> Ed Merks a écrit :
>> Guillaume,
>> to define global types and to reuse those. I.e., each occurrence of
>> <data> could be specified with a different local element declaration
>> that references the same globally defined type.
>>> Thanks Ed.
>>> it since a <data> element is used by both <input> and <output>?
>>> Ed Merks a écrit :
>>>> Guillaume,
>>>>> <root>
>>>>> <process>
>>>>> <input>
>>>>> <data>blah</data>
>>>>> </input>
>>>>> <output>
>>>>> <data>bloh</data>
>>>>> </output>
>>>>> <process>
>>>>> <output>
>>>>> <data>blah</data>
>>>>> </output>
>>>>> </process>
>>>>> </process>
>>>>> </root>
>>>>> Cheers -
Re: Embedded elements [message #67628 is a reply to message #67610] Tue, 11 April 2006 07:19 Go to previous messageGo to next message
Ed,
"That's where having local element declarations of some shared global
type should help you..."
Would you mind illustrating that?
Ed Merks a écrit :
> Guillaume,
> Comments below.
>> That's fair enough.
> specification.
>> behaviour?
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> Ed Merks a écrit :
>>> Guillaume,
>>>> Thanks Ed.
>>>> Ed Merks a écrit :
>>>>> Guillaume,
>>>>>> <root>
>>>>>> <process>
>>>>>> <input>
>>>>>> <data>blah</data>
>>>>>> </input>
>>>>>> <output>
>>>>>> <data>bloh</data>
>>>>>> </output>
>>>>>> <process>
>>>>>> <output>
>>>>>> <data>blah</data>
>>>>>> </output>
>>>>>> </process>
>>>>>> </process>
>>>>>> </root>
>>>>>> Cheers -
Re: Embedded elements [message #67651 is a reply to message #67628] Tue, 11 April 2006 07:25 Go to previous messageGo to next message
--------------030201060208070309030806
Guillaume,
Your own example below is an example, i.e., process is a local element
that uses a globally defined type.
<xsd:sequence>
* <xsd:element name="process" minOccurs="1" maxOccurs="unbounded"
type="proc:process"/> *
</xsd:sequence>
> Ed,
> Ed Merks a
Re: Embedded elements [message #67667 is a reply to message #67651] Tue, 11 April 2006 07:28 Go to previous message
Thanks Ed, it makes sense now!
Ed Merks a écrit :
> Guillaume,
> <xsd:sequence>
> </xsd:sequence>
>> Ed,
>> Ed Merks a écrit :
>>> Guillaume,
>>> Comments below.
>>>> That's fair enough.
>>>> element.
>>> specification.
>>>> such behaviour?
>>> such behavior. As such, if you only want to have a single global
>>> element declaration to represent the one and only valid root element
>>> of a document, you'll need to avoid global element declarations for
>>> all other cases. That's where having local element declarations of
>>> some shared global type should help you...
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> Ed Merks a écrit :
>>>>> Guillaume,
>>>>> is to define global types and to reuse those. I.e., each
>>>>> occurrence of <data> could be specified with a different local
>>>>> element declaration that references the same globally defined type.
>>>>>> Thanks Ed.
>>>>>> to it since a <data> element is used by both <input> and <output>?
>>>>>> Ed Merks a écrit :
>>>>>>> Guillaume,
>>>>>>> refer to it in multiple complex types.
>>>>>>>> a XML file that would look like this:
>>>>>>>> <root>
>>>>>>>> <process>
>>>>>>>> <input>
>>>>>>>> <data>blah</data>
>>>>>>>> </input>
>>>>>>>> <output>
>>>>>>>> <data>bloh</data>
>>>>>>>> </output>
>>>>>>>> <process>
>>>>>>>> <output>
>>>>>>>> <data>blah</data>
>>>>>>>> </output>
>>>>>>>> </process>
>>>>>>>> </process>
>>>>>>>> </root>
>>>>>>>> and can contain itself. My question is, how can we render, in
>>>>>>>> XSD, the fact that a <data> can be reused in two different objects?
>>>>>>>> Cheers -
Re: Embedded elements [message #597902 is a reply to message #67497] Mon, 10 April 2006 16:14 Go to previous message
Guillaume,
> <root>
> <process>
> <input>
> <data>blah</data>
> </input>
> <output>
> <data>bloh</data>
> </output>
> <process>
> <output>
> <data>blah</data>
> </output>
> </process>
> </process>
> </root>
> Cheers -
Re: Embedded elements [message #597904 is a reply to message #67519] Tue, 11 April 2006 04:27 Go to previous message
Thanks Ed.
Ed Merks a écrit :
> Guillaume,
>> <root>
>> <process>
>> <input>
>> <data>blah</data>
>> </input>
>> <output>
>> <data>bloh</data>
>> </output>
>> <process>
>> <output>
>> <data>blah</data>
>> </output>
>> </process>
>> </process>
>> </root>
>> Cheers -
Re: Embedded elements [message #597914 is a reply to message #67539] Tue, 11 April 2006 05:42 Go to previous message
Guillaume,
> Thanks Ed.
> Ed Merks a écrit :
>> Guillaume,
>>> <root>
>>> <process>
>>> <input>
>>> <data>blah</data>
>>> </input>
>>> <output>
>>> <data>bloh</data>
>>> </output>
>>> <process>
>>> <output>
>>> <data>blah</data>
>>> </output>
>>> </process>
>>> </process>
>>> </root>
>>> Cheers -
Re: Embedded elements [message #597918 is a reply to message #67560] Tue, 11 April 2006 06:21 Go to previous message
That's fair enough.
<xsd:sequence>
</xsd:sequence>
</xsd:complexType>
Ed Merks a écrit :
> Guillaume,
>> Thanks Ed.
>> Ed Merks a écrit :
>>> Guillaume,
>>>> <root>
>>>> <process>
>>>> <input>
>>>> <data>blah</data>
>>>> </input>
>>>> <output>
>>>> <data>bloh</data>
>>>> </output>
>>>> <process>
>>>> <output>
>>>> <data>blah</data>
>>>> </output>
>>>> </process>
>>>> </process>
>>>> </root>
>>>> Cheers -
Re: Embedded elements [message #597926 is a reply to message #67589] Tue, 11 April 2006 07:04 Go to previous message
Guillaume,
Comments below.
> That's fair enough.
> behaviour?
> <xsd:sequence>
> </xsd:sequence>
> </xsd:complexType>
> Ed Merks a écrit :
>> Guillaume,
>>> Thanks Ed.
>>> Ed Merks a écrit :
>>>> Guillaume,
>>>>> <root>
>>>>> <process>
>>>>> <input>
>>>>> <data>blah</data>
>>>>> </input>
>>>>> <output>
>>>>> <data>bloh</data>
>>>>> </output>
>>>>> <process>
>>>>> <output>
>>>>> <data>blah</data>
>>>>> </output>
>>>>> </process>
>>>>> </process>
>>>>> </root>
>>>>> Cheers -
Re: Embedded elements [message #597930 is a reply to message #67610] Tue, 11 April 2006 07:19 Go to previous message
Ed,
Ed Merks a écrit :
> Guillaume,
> Comments below.
>> That's fair enough.
> specification.
>> behaviour?
>> <xsd:sequence>
>> </xsd:sequence>
>> </xsd:complexType>
>> Ed Merks a écrit :
>>> Guillaume,
>>>> Thanks Ed.
>>>> Ed Merks a écrit :
>>>>> Guillaume,
>>>>>> <root>
>>>>>> <process>
>>>>>> <input>
>>>>>> <data>blah</data>
>>>>>> </input>
>>>>>> <output>
>>>>>> <data>bloh</data>
>>>>>> </output>
>>>>>> <process>
>>>>>> <output>
>>>>>> <data>blah</data>
>>>>>> </output>
>>>>>> </process>
>>>>>> </process>
>>>>>> </root>
>>>>>> Cheers -
Re: Embedded elements [message #597936 is a reply to message #67628] Tue, 11 April 2006 07:25 Go to previous message
Guillaume,
<xsd:sequence>
</xsd:sequence>
> Ed,
> Ed Merks a
Re: Embedded elements [message #597939 is a reply to message #67651] Tue, 11 April 2006 07:28 Go to previous message
Ed Merks a écrit :
> Guillaume,
> <xsd:sequence>
> </xsd:sequence>
>> Ed,
>> Ed Merks a écrit :
>>> Guillaume,
>>> Comments below.
>>>> That's fair enough.
>>>> element.
>>> specification.
>>>> such behaviour?
>>>> <xsd:sequence>
>>>> </xsd:sequence>
>>>> </xsd:complexType>
>>>> Ed Merks a écrit :
>>>>> Guillaume,
>>>>>> Thanks Ed.
>>>>>> Ed Merks a écrit :
>>>>>>> Guillaume,
>>>>>>>> <root>
>>>>>>>> <process>
>>>>>>>> <input>
>>>>>>>> <data>blah</data>
>>>>>>>> </input>
>>>>>>>> <output>
>>>>>>>> <data>bloh</data>
>>>>>>>> </output>
>>>>>>>> <process>
>>>>>>>> <output>
>>>>>>>> <data>blah</data>
>>>>>>>> </output>
>>>>>>>> </process>
>>>>>>>> </process>
>>>>>>>> </root>
>>>>>>>> Cheers -
Previous Topic:Embedded elements
Next Topic:graphics export
Current Time: Sat Nov 08 00:47:30 EST 2025
Powered by FUDForum. Page generated in 0.05827 seconds
