Home » Archived » XML Schema Definition (XSD) » Stack overflow when opening XSD
| Stack overflow when opening XSD [message #65956] |
Thu, 09 February 2006 14:10  |
I am trying to open the HL-7 CDA XSD file in Eclipse and keep getting a
stack overflow message after Eclipse works on opening the file for a while.
I have fiddled with -X args and cranked them up about as high as I can and
still get the same stack overflow. Could someone give me some advice on
other things to try to get the file open?
Here are some highlights from my system. The platform details are below
followed by the stack trace.
*** Date: Thu Feb 09 14:02:48 EST 2006
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=M20050929-0840
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-launcher
F:\eclipse-SDK-3.1.1-win32\eclipse\eclipse.exe
-name
Eclipse
-showsplash
600
-exitdata
fbc_60
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.product=org.eclipse.sdk.ide
eclipse.startTime=1139511756277
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-Xmx256M
-jar
F:\eclipse-SDK-3.1.1-win32\eclipse\startup.jar
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=F:\eclipse-SDK-3.1.1-win32\eclipse\startup.j ar
java.class.version=49.0
java.endorsed.dirs=C:\Program Files\Java\jre1.5.0_06\lib\endorsed
java.ext.dirs=C:\Program Files\Java\jre1.5.0_06\lib\ext
java.home=C:\Program Files\Java\jre1.5.0_06
java.io.tmpdir=C:\DOCUME~1\bcousins\LOCALS~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;C:\Program
Files\Windows Resource
Kits\Tools\;C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System 32\Wbem;C:\Program
Files\Microsoft Office\OFFICE11\Business Contact Manager\IM;C:\Program
Files\Microsoft SQL Server\80\Tools\Binn\;C:\Program Files\Microsoft
Office\OFFICE11\Business Contact Manager\;C:\PTDLL
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.5.0_06-b05
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.5
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.5.0_06
java.vm.info=mixed mode, sharing
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.5.0_06-b05
line.separator=
org.osgi.framework.bootdelegation=*
org.osgi.framework.executionenvironment=J2SE-1.5
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.system.packages=javax.accessibility,javax .activity,javax.crypto,javax.crypto.interfaces,javax.crypto. spec,javax.imageio,javax.imageio.event,javax.imageio.metadat a,javax.imageio.plugins.bmp,javax.imageio.plugins.jpeg,javax .imageio.spi,javax.imageio.stream,javax.management,javax.man agement.loading,javax.management.modelmbean,javax.management .monitor,javax.management.openmbean,javax.management.relatio n,javax.management.remote,javax.management.remote.rmi,javax. management.timer,javax.naming,javax.naming.directory,javax.n aming.event,javax.naming.ldap,javax.naming.spi,javax.net,jav ax.net.ssl,javax.print,javax.print.attribute,javax.print.att ribute.standard,javax.print.event,javax.rmi,javax.rmi.CORBA, javax.rmi.ssl,javax.security.auth,javax.security.auth.callba ck,javax.security.auth.kerberos,javax.security.auth.login,ja vax.security.auth.spi,javax.security.auth.x500,javax.securit y.cert,javax.security.sasl,javax.sound.midi,javax.sound.midi .spi,javax.sound.sampled,javax.sound.sampled.spi,javax.sql,j avax.sql.rowset,javax.sql.rowset.serial,javax.sql.rowset.spi ,javax.swing,javax.swing.border,javax.swing.colorchooser,jav ax.swing.event,javax.swing.filechooser,javax.swing.plaf,java x.swing.plaf.basic,javax.swing.plaf.metal,javax.swing.plaf.m ulti,javax.swing.plaf.synth,javax.swing.table,javax.swing.te xt,javax.swing.text.html,javax.swing.text.html.parser,javax. swing.text.rtf,javax.swing.tree,javax.swing.undo,javax.trans action,javax.transaction.xa,javax.xml,javax.xml.datatype,jav ax.xml.namespace,javax.xml.parsers,javax.xml.transform,javax .xml.transform.dom,javax.xml.transform.sax,javax.xml.transfo rm.stream,javax.xml.validation,javax.xml.xpath,org.ietf.jgss ,org.omg.CORBA,org.omg.CORBA_2_3,org.omg.CORBA_2_3.portable, org.omg.CORBA.DynAnyPackage,org.omg.CORBA.ORBPackage,org.omg .CORBA.portable,org.omg.CORBA.TypeCodePackage,org.omg.CosNam ing,org.omg.CosNaming.NamingContextExtPackage,org.omg.CosNam ing.NamingContextPackage,org.omg.Dynamic,org.omg.DynamicAny, org.omg.DynamicAny.DynAnyFactoryPackage,org.omg.DynamicAny.D ynAnyPackage,org.omg.IOP,org.omg.IOP.CodecFactoryPackage,org .omg.IOP.CodecPackage,org.omg.Messaging,org.omg.PortableInte rceptor,org.omg.PortableInterceptor.ORBInitInfoPackage,org.o mg.PortableServer,org.omg.PortableServer.CurrentPackage,org. omg.PortableServer.POAManagerPackage,org.omg.PortableServer. POAPackage,org.omg.PortableServer.portable,org.omg.PortableS erver.ServantLocatorPackage,org.omg.SendingContext,org.omg.s tub.java.rmi,org.w3c.dom,org.w3c.dom.bootstrap,org.w3c.dom.e vents,org.w3c.dom.ls,org.xml.sax,org.xml.sax.ext,org.xml.sax .helpers
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.3.0
org.osgi.supports.framework.extension=true
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundlestore=f:\eclipse-SDK-3.1.1-win32\eclipse\configur ation\org.eclipse.osgi\bundles
osgi.configuration.area=file:/f:/eclipse-SDK-3.1.1-win32/ecl ipse/configuration/
osgi.framework=file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plug ins/org.eclipse.osgi_3.1.2.jar
osgi.framework.beginningstartlevel=1
osgi.framework.shape=jar
osgi.framework.version=3.1.2
osgi.install.area=file:/f:/eclipse-SDK-3.1.1-win32/eclipse/
osgi.instance.area=file:/F:/TMDev/eclipse/workspace/
osgi.instance.area.default=file:/C:/Documents and
Settings/bcousins/workspace/
osgi.logfile=F:\TMDev\eclipse\workspace\.metadata\.log
osgi.manifest.cache=f:\eclipse-SDK-3.1.1-win32\eclipse\confi guration\org.eclipse.osgi\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=f:\eclipse-SDK-3.1.1-win32\eclipse\plugi ns\org.eclipse.platform_3.1.2\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.syspath=f:\eclipse-SDK-3.1.1-win32\eclipse\plugins
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\jre1.5.0_06\lib\rt.jar;C:\Program
Files\Java\jre1.5.0_06\lib\i18n.jar;C:\Program
Files\Java\jre1.5.0_06\lib\sunrsasign.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jsse.jar;C:\Program
Files\Java\jre1.5.0_06\lib\jce.jar;C:\Program
Files\Java\jre1.5.0_06\lib\charsets.jar;C:\Program
Files\Java\jre1.5.0_06\classes
sun.boot.library.path=C:\Program Files\Java\jre1.5.0_06\bin
sun.cpu.endian=little
sun.cpu.isalist=
sun.desktop=windows
sun.io.unicode.encoding=UnicodeLittle
sun.jnu.encoding=Cp1252
sun.management.compiler=HotSpot Client Compiler
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=F:\eclipse-SDK-3.1.1-win32\eclipse
user.home=C:\Documents and Settings\bcousins
user.language=en
user.name=bcousins
user.timezone=America/New_York
user.variant=
*** Features:
org.eclipse.emf (2.1.2) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.1.2) "Eclipse Modeling Framework (EMF) Programmers
Guide"
org.eclipse.emf.ecore.sdo (2.1.1) "EMF Service Data Objects (SDO)"
org.eclipse.emf.ecore.sdo.doc (2.1.1) "EMF Service Data Objects (SDO)
Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.1.1) "EMF Service Data Objects (SDO)
Source"
org.eclipse.emf.examples (2.1.0) "Eclipse Modeling Framework (EMF) Examples"
org.eclipse.emf.source (2.1.2) "Eclipse Modeling Framework (EMF) Source"
org.eclipse.gef (3.1.1) "Graphical Editing Framework"
org.eclipse.gef.examples (3.1.1) "GEF Examples"
org.eclipse.gef.sdk (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.1.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.1.2) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.1.2) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.1.0.1) "Java EMF Model"
org.eclipse.jem.sdk (1.1.0.1) "Java EMF Model SDK"
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source"
org.eclipse.jst (0.7.1) "J2EE Standard Tools"
org.eclipse.jst.sdk (0.7.1) "J2EE Standard Tools SDK"
org.eclipse.pde (3.1.2) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.1.2) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.1.2) "Eclipse Platform"
org.eclipse.platform.source (3.1.2) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.rcp (3.1.2) "Eclipse RCP"
org.eclipse.rcp.source (3.1.2) "Eclipse RCP Plug-in Developer Resources"
org.eclipse.sdk (3.1.2) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.0.1) "Eclipse SDK Examples"
org.eclipse.team.extras (3.0.0) "Eclipse FTP and WebDAV Support"
org.eclipse.uml2 (1.1.1) "UML2"
org.eclipse.uml2.doc (1.1.1) "UML2 Documentation"
org.eclipse.uml2.examples (1.1.1) "UML2 Examples"
org.eclipse.uml2.examples.source (1.1.1) "UML2 Examples Source"
org.eclipse.uml2.source (1.1.1) "UML2 Source"
org.eclipse.ve (1.1.0.1) "Visual Editor"
org.eclipse.ve.sdk (1.1.0.1) "Visual Editor SDK"
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source"
org.eclipse.wst (0.7.1) "Web Standard Tools"
org.eclipse.wst.sdk (0.7.1) "Web Standard Tools SDK"
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.1.1) "XML Schema Infoset Model (XSD) Programmers
Guide"
org.eclipse.xsd.source (2.1.1) "XML Schema Infoset Model (XSD) Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model" [Resolved]
org.apache.ant (1.6.5) "Apache Ant" [Resolved]
org.apache.axis (1.2.1) "Axis121 Plug-in" [Resolved]
org.apache.lucene (1.4.3) "Apache Lucene" [Resolved]
org.apache.wsil4j (1.0.0) "Apache WSIL4J 1.0" [Resolved]
org.apache.xerces (2.7.0) "Xerces 2.7.0" [Resolved]
org.eclipse.ant.core (3.1.1) "Ant Build Tool Core" [Resolved]
org.eclipse.ant.ui (3.1.2) "Ant UI" [Resolved]
org.eclipse.compare (3.1.1) "Compare Support" [Resolved]
org.eclipse.compare.examples (3.0.0) "Compare Example" [Resolved]
org.eclipse.compare.examples.xml (3.0.0) "XML Compare Support" [Resolved]
org.eclipse.core.boot (3.1.0) "Core Boot" [Resolved]
org.eclipse.core.commands (3.1.0) "Commands" [Active]
org.eclipse.core.expressions (3.1.0) "Expression Language" [Active]
org.eclipse.core.filebuffers (3.1.2) "File Buffers" [Active]
org.eclipse.core.resources (3.1.2) "Core Resource Management" [Active]
org.eclipse.core.resources.compatibility (3.1.0) "Core Resource Management
Compatibility Fragment" [Resolved]
org.eclipse.core.resources.win32 (3.1.0) "Core Resource Management Win32
org.eclipse.core.runtime (3.1.2) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility (3.1.0) "Core Runtime Plug-in
Compatibility" [Active]
org.eclipse.core.variables (3.1.0) "Core Variables" [Resolved]
org.eclipse.debug.core (3.1.2) "Debug Core" [Active]
org.eclipse.debug.ui (3.1.2) "Debug UI" [Active]
org.eclipse.draw2d (3.1.1) "Draw2d" [Resolved]
org.eclipse.draw2d.doc.isv (3.1.1) "Draw2D Documentation" [Resolved]
org.eclipse.emf (2.1.2) "Eclipse Modeling Framework (EMF)" [Resolved]
org.eclipse.emf.activities (2.1.0) "EMF Activities" [Resolved]
org.eclipse.emf.ant (2.1.0) "EMF Ant Tasks" [Resolved]
org.eclipse.emf.codegen (2.1.2) "EMF Template Code Generator" [Resolved]
org.eclipse.emf.codegen.ecore (2.1.0) "EMF Ecore Code Generation" [Resolved]
org.eclipse.emf.codegen.ecore.ui (2.1.0) "EMF Ecore Code Generation UI"
[Resolved]
org.eclipse.emf.codegen.ui (2.1.0) "EMF Template Code Generator UI"
[Resolved]
org.eclipse.emf.common (2.1.0) "EMF Common" [Resolved]
org.eclipse.emf.common.ui (2.1.0) "EMF Common UI" [Resolved]
org.eclipse.emf.commonj.sdo (2.1.0) "CommonJ SDO" [Resolved]
Guide" [Resolved]
org.eclipse.emf.ecore (2.1.0) "EMF Ecore" [Resolved]
org.eclipse.emf.ecore.change (2.1.2) "EMF Ecore Change Model" [Resolved]
org.eclipse.emf.ecore.change.edit (2.1.0) "EMF Ecore Change Edit Support"
[Resolved]
org.eclipse.emf.ecore.edit (2.1.1) "EMF Ecore Edit Support" [Resolved]
org.eclipse.emf.ecore.editor (2.1.0) "Sample Ecore Editor" [Resolved]
[Resolved]
Programmers Guide" [Resolved]
org.eclipse.emf.ecore.sdo.edit (2.1.0) "EMF Service Data Objects (SDO) Edit
Support" [Resolved]
org.eclipse.emf.ecore.sdo.editor (2.1.0) "EMF Service Data Objects (SDO)
Editor" [Resolved]
Source" [Resolved]
org.eclipse.emf.ecore.xmi (2.1.0) "EMF XMI" [Resolved]
org.eclipse.emf.edit (2.1.1) "EMF Edit" [Resolved]
org.eclipse.emf.edit.ui (2.1.0) "EMF Edit UI" [Resolved]
[Resolved]
org.eclipse.emf.importer (2.1.0) "EMF Model Import Support" [Resolved]
org.eclipse.emf.importer.ecore (2.1.2) "EMF Ecore Importer" [Resolved]
org.eclipse.emf.importer.java (2.1.2) "EMF Annotated Java Importer"
[Resolved]
org.eclipse.emf.importer.rose (2.1.1) "EMF Rose Importer" [Resolved]
org.eclipse.emf.java (2.1.0) "EMF Java" [Resolved]
org.eclipse.emf.java.edit (2.1.0) "EMF Java Edit" [Resolved]
org.eclipse.emf.java.editor (2.1.0) "EMF Java Editor" [Resolved]
org.eclipse.emf.mapping (2.1.0) "EMF Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2ecore (2.1.0) "Ecore to Ecore Mapping"
[Resolved]
org.eclipse.emf.mapping.ecore2ecore.editor (2.1.0) "Ecore to Ecore Mapping
Editor" [Resolved]
org.eclipse.emf.mapping.ecore2xml (2.1.0) "Ecore to XML Mapping" [Resolved]
org.eclipse.emf.mapping.ecore2xml.ui (2.1.1) "Ecore to XML Mapping UI"
[Resolved]
org.eclipse.emf.mapping.ui (2.1.0) "EMF Mapping UI" [Resolved]
org.eclipse.emf.mapping.xsd2ecore (2.1.0) "XSD to Ecore Mapping" [Resolved]
org.eclipse.emf.mapping.xsd2ecore.editor (2.1.0) "XSD to Ecore Mapping
Editor" [Resolved]
[Resolved]
org.eclipse.gef (3.1.1) "Graphical Editing Framework" [Resolved]
org.eclipse.gef.doc.isv (3.1.1) "Graphical Editing Framework Documentation"
[Resolved]
org.eclipse.gef.examples.flow (3.1.1) "GEF Flow Editor Example" [Resolved]
org.eclipse.gef.examples.logic (3.1.1) "GEF Logic Editor Example" [Resolved]
org.eclipse.gef.examples.shapes (3.1.1) "GEF Shape Editor Example"
[Resolved]
org.eclipse.gef.examples.source (3.1.1) "GEF Examples" [Resolved]
org.eclipse.gef.examples.text (3.1.1) "GEF Text Editor Example" [Resolved]
Resources" [Resolved]
org.eclipse.help (3.1.0) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.0) "Help Application Server" [Resolved]
org.eclipse.help.base (3.1.0) "Help System Base" [Resolved]
org.eclipse.help.examples.ex1 (3.0.0) "Online Help Sample" [Resolved]
org.eclipse.help.ui (3.1.1) "Help System UI" [Resolved]
org.eclipse.help.webapp (3.1.0) "Help System Webapp" [Resolved]
org.eclipse.jdt (3.1.0) "Eclipse Java Development Tools" [Resolved]
org.eclipse.jdt.core (3.1.2) "Java Development Tools Core" [Active]
org.eclipse.jdt.debug (3.1.1) "JDI Debug Model" [Resolved]
org.eclipse.jdt.debug.ui (3.1.2) "JDI Debug UI" [Resolved]
org.eclipse.jdt.doc.isv (3.1.2) "Eclipse JDT Plug-in Developer Guide"
[Resolved]
org.eclipse.jdt.doc.user (3.1.1) "Eclipse Java Development User Guide"
[Resolved]
org.eclipse.jdt.junit (3.1.1) "Java Development Tools JUnit support"
[Resolved]
org.eclipse.jdt.junit.runtime (3.1.0) "Java Development Tools JUnit runtime
support" [Resolved]
org.eclipse.jdt.launching (3.1.0) "Java Development Tools Launching Support"
[Active]
[Resolved]
org.eclipse.jdt.ui (3.1.2) "Java Development Tools UI" [Active]
org.eclipse.jdt.ui.examples.projects (3.0.1) "Java Development Tools Example
Projects" [Resolved]
org.eclipse.jem (1.1.0.1) "Java EMF Model" [Resolved]
org.eclipse.jem.beaninfo (1.1.0.1) "Java EMF Model BeanInfo (Introspection)
Support" [Resolved]
org.eclipse.jem.proxy (1.1.0.1) "Java EMF Model Proxy Support" [Resolved]
org.eclipse.jem.sdk (1.1.0) "Java EMF Model SDK" [Resolved]
org.eclipse.jem.source (1.1.0.1) "Java EMF Model Source" [Resolved]
org.eclipse.jem.ui (1.1.0.1) "Java EMF Model UI" [Resolved]
org.eclipse.jem.util (1.1.0.1) "Java EMF Model Utilities" [Resolved]
org.eclipse.jem.workbench (1.1.0.1) "Java EMF Model Workbench Support"
[Resolved]
org.eclipse.jface (3.1.1) "JFace" [Active]
org.eclipse.jface.text (3.1.2) "JFace Text" [Active]
org.eclipse.jst (0.7.0) "J2EE Standard Tools" [Resolved]
org.eclipse.jst.common.annotations.controller (0.7.1) "Annotation Controller
Plug-in" [Resolved]
org.eclipse.jst.common.annotations.core (0.7.0) "Annotation Core Plug-in"
[Resolved]
org.eclipse.jst.common.annotations.ui (0.7.0) "Ui Plug-in" [Resolved]
org.eclipse.jst.common.frameworks (0.7.0) "Integration Plug-in" [Resolved]
org.eclipse.jst.common.navigator.java (0.7.1) "Navigator Plug-in" [Resolved]
org.eclipse.jst.ejb.ui (0.7.0) "WTP EJB UI Plug-in" [Resolved]
org.eclipse.jst.j2ee (0.7.1) "J2EE Component" [Resolved]
org.eclipse.jst.j2ee.core (0.7.1) "J2EE Core Component" [Resolved]
org.eclipse.jst.j2ee.ejb (0.7.0) "EJB component Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotation.model (0.7.0) "EJB Annotation Model
Plug-in" [Resolved]
org.eclipse.jst.j2ee.ejb.annotations.emitter (0.7.0) "EJB Emitter Plug-in"
[Resolved]
org.eclipse.jst.j2ee.ejb.annotations.ui (0.7.1) "EJB Annotations Ui Plug-in"
[Resolved]
org.eclipse.jst.j2ee.ejb.annotations.xdoclet (0.7.1) "Xdoclet Annotations
Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca (0.7.0) "JCA Plug-in" [Resolved]
org.eclipse.jst.j2ee.jca.ui (0.7.0) "WTP JCA UI Plug-in" [Resolved]
org.eclipse.jst.j2ee.navigator.ui (0.7.0) "J2EE Extensions to Common
Navigator" [Resolved]
org.eclipse.jst.j2ee.ui (0.7.1) "WTP J2EE UI Plug-in" [Resolved]
org.eclipse.jst.j2ee.web (0.7.1) "Web Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservice (0.7.0) "Web Service Plug-in" [Resolved]
org.eclipse.jst.j2ee.webservices.ui (0.7.0) "WTP Webservice UI Plug-in"
[Resolved]
org.eclipse.jst.jsp.core (0.7.1) "Structured Source JSP Model" [Resolved]
org.eclipse.jst.jsp.ui (0.7.1) "SSE JSP Source Editor" [Resolved]
org.eclipse.jst.server.core (0.7.0) "Java Server Support" [Resolved]
org.eclipse.jst.server.generic.core (0.7.0) "Generic Server Plugin"
[Resolved]
org.eclipse.jst.server.generic.serverdefinitions (0.7.0) "Generic server
example definitions" [Resolved]
org.eclipse.jst.server.generic.ui (0.7.0) "Generic Server Plugin UI"
[Resolved]
org.eclipse.jst.server.geronimo.core (0.7.0) "Geronimo server support"
[Resolved]
org.eclipse.jst.server.geronimo.ui (0.7.0) "Geronimo server UI support"
[Resolved]
org.eclipse.jst.server.tomcat.core (0.7.0) "Apache Tomcat Support"
[Resolved]
org.eclipse.jst.server.tomcat.ui (0.7.0) "Apache Tomcat UI Support"
[Resolved]
org.eclipse.jst.server.ui (0.7.0) "Java Server UI Support" [Resolved]
org.eclipse.jst.server.websphere.core (0.7.0) "WebSphere Generic Server
Definition Core Plug-in" [Resolved]
org.eclipse.jst.servlet.ui (0.7.1) "WTP Servlet UI Plug-in" [Resolved]
org.eclipse.jst.source (0.7.1) "J2EE Standard Tools SDK" [Resolved]
org.eclipse.jst.ws (0.7.1) "Web Services" [Resolved]
org.eclipse.jst.ws.axis.consumption.core (0.7.0) "Web service Axis
Consumption Core" [Resolved]
org.eclipse.jst.ws.axis.consumption.ui (0.7.1) "Webservice Axis Consumption
UI" [Resolved]
org.eclipse.jst.ws.axis.creation.ui (0.7.0) "Webservice Axis Creation UI"
[Resolved]
org.eclipse.jst.ws.consumption (0.7.0) "Web Services Consumption" [Resolved]
org.eclipse.jst.ws.consumption.ui (0.7.1) "Web Services Consumption
Graphical User Interface" [Resolved]
org.eclipse.jst.ws.creation.ejb.ui (0.7.0) "Web Services Creation EJB
org.eclipse.jst.ws.creation.ui (0.7.1) "Web Services Creation Graphical User
org.eclipse.jst.ws.uddiregistry (0.7.0) "Web Services Universal Description
Discovery and Integration Registry" [Resolved]
org.eclipse.jst.ws.ui (0.7.1) "Web Services Graphical User Interface"
[Resolved]
org.eclipse.ltk.core.refactoring (3.1.0) "Refactoring Core" [Resolved]
org.eclipse.ltk.ui.refactoring (3.1.1) "Refactoring UI" [Resolved]
org.eclipse.osgi.services (3.1.2) "OSGi Release 3 Services" [Resolved]
org.eclipse.osgi.util (3.1.1) "OSGi R3 Utility Classes" [Resolved]
org.eclipse.pde (3.1.0) "Eclipse Plug-in Development Environment" [Resolved]
org.eclipse.pde.build (3.1.2) "Plug-in Development Environment Build
Support" [Resolved]
org.eclipse.pde.core (3.1.1) "Plug-in Development Core" [Active]
org.eclipse.pde.doc.user (3.1.2) "Eclipse Plug-in Development User Guide"
[Resolved]
org.eclipse.pde.junit.runtime (3.1.0) "PDE JUnit Plug-in Test" [Resolved]
org.eclipse.pde.runtime (3.1.1) "Plug-in Development Environment Runtime"
[Resolved]
Developer Resources" [Resolved]
org.eclipse.pde.ui (3.1.2) "Plug-in Development UI" [Resolved]
org.eclipse.platform (3.1.2) "Eclipse Platform" [Resolved]
org.eclipse.platform.doc.isv (3.1.2) "Eclipse Platform Plug-in Developer
Guide" [Resolved]
org.eclipse.platform.doc.user (3.1.1) "Eclipse Workbench User Guide"
[Resolved]
org.eclipse.platform.source.win32.win32.x86 (3.1.2) "Eclipse Platform
Plug-in Developer Resources" [Resolved]
org.eclipse.rcp (3.1.0) "Eclipse RCP" [Resolved]
[Resolved]
org.eclipse.rcp.source.win32.win32.x86 (3.1.2) "Eclipse RCP Plug-in
org.eclipse.sdk (3.1.2) "Eclipse Project SDK" [Resolved]
org.eclipse.sdk.examples (3.0.1) "Eclipse SDK Examples" [Resolved]
org.eclipse.sdk.examples.source (3.0.1) "Eclipse Platform Plug-in Developer
org.eclipse.sdk.examples.source.win32.win32.x86 (3.0.1) "Eclipse Platform
org.eclipse.search (3.1.2) "Search Support" [Resolved]
org.eclipse.swt (3.1.0) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.examples (3.0.0) "SWT Standalone Examples Plugin" [Resolved]
org.eclipse.swt.examples.browser (3.0.0) "SWT Browser Example Plugin"
[Resolved]
org.eclipse.swt.examples.controls (3.0.0) "SWT Controls Example Plugin"
[Resolved]
org.eclipse.swt.examples.launcher (3.0.0) "SWT Launcher Example Plugin"
[Resolved]
org.eclipse.swt.examples.layouts (3.0.0) "SWT Layout Example Plugin"
[Resolved]
org.eclipse.swt.examples.ole.win32 (3.0.0) "SWT OLE Example Plugin (Win32)"
[Resolved]
org.eclipse.swt.examples.paint (3.0.0) "SWT Paint Example Plugin" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.1.2) "Standard Widget Toolkit for
Windows" [Resolved]
org.eclipse.team.core (3.1.1) "Team Support Core" [Active]
org.eclipse.team.cvs.core (3.1.1) "CVS Team Provider Core" [Active]
org.eclipse.team.cvs.ssh (3.1.0) "CVS SSH Core" [Resolved]
org.eclipse.team.cvs.ssh2 (3.1.0) "CVS SSH2" [Active]
org.eclipse.team.cvs.ui (3.1.1) "CVS Team Provider UI" [Active]
org.eclipse.team.examples.filesystem (3.0.0) "Eclipse Team File System
Example" [Active]
org.eclipse.team.extras (3.0.0) "Eclipse FTP and WebDAV Support" [Resolved]
org.eclipse.team.extras.source (3.0.0) "Eclipse Team Extras Plug-in
org.eclipse.team.ftp (3.0.0) "FTP Deployment Provider" [Resolved]
org.eclipse.team.ui (3.1.1) "Team Support UI" [Active]
org.eclipse.team.webdav (3.0.0) "WebDAV Team Provider" [Resolved]
org.eclipse.text (3.1.1) "Text" [Active]
org.eclipse.tomcat (4.1.30.1) "Tomcat Wrapper" [Resolved]
org.eclipse.ui (3.1.2) "Eclipse UI" [Active]
org.eclipse.ui.browser (3.1.1) "Browser Support" [Resolved]
org.eclipse.ui.cheatsheets (3.1.1) "Cheat Sheets" [Resolved]
org.eclipse.ui.console (3.1.2) "Console" [Active]
org.eclipse.ui.editors (3.1.1) "Default Text Editor" [Active]
org.eclipse.ui.examples.javaeditor (3.0.0) "JFace Text Example" [Resolved]
org.eclipse.ui.examples.multipageeditor (2.1.0) "Multi-Page Editor Example"
[Resolved]
org.eclipse.ui.examples.propertysheet (2.1.0) "User File Editor" [Resolved]
org.eclipse.ui.examples.readmetool (2.1.0) "Readme File Editing Tool"
[Resolved]
org.eclipse.ui.externaltools (3.1.1) "External Tools" [Active]
org.eclipse.ui.forms (3.1.0) "Eclipse Forms" [Resolved]
org.eclipse.ui.ide (3.1.1) "Eclipse IDE UI" [Active]
org.eclipse.ui.intro (3.1.1) "Welcome Framework" [Resolved]
org.eclipse.ui.presentations.r21 (3.1.0) "R21 Presentation Plug-in"
[Resolved]
org.eclipse.ui.views (3.1.1) "Views" [Active]
org.eclipse.ui.win32 (3.1.0) "Eclipse UI Win32 Enhancements" [Resolved]
org.eclipse.ui.workbench (3.1.2) "Workbench" [Active]
org.eclipse.ui.workbench.compatibility (3.1.0) "Workbench Compatibility"
[Resolved]
org.eclipse.ui.workbench.texteditor (3.1.2) "Text Editor Framework" [Active]
org.eclipse.uml2 (1.1.1) "UML2" [Resolved]
org.eclipse.uml2.codegen.ecore (1.1.1) "UML2 Ecore Code Generation"
[Resolved]
org.eclipse.uml2.codegen.ecore.ui (1.1.1) "UML2 Ecore Code Generation UI"
[Resolved]
org.eclipse.uml2.common (1.1.1) "UML2 Common" [Resolved]
org.eclipse.uml2.common.edit (1.1.1) "UML2 Common Edit" [Resolved]
org.eclipse.uml2.doc (1.1.1) "UML2 Documentation" [Resolved]
org.eclipse.uml2.ecore.importer (1.1.1) "UML2 Importer for EMF" [Resolved]
org.eclipse.uml2.edit (1.1.1) "UML2 Edit Support" [Resolved]
org.eclipse.uml2.editor (1.1.1) "UML2 Editor" [Resolved]
org.eclipse.uml2.examples (1.1.1) "UML2 Examples" [Resolved]
org.eclipse.uml2.examples.emof2ecore (1.1.1) "UML2 EMOF2Ecore Example"
[Resolved]
org.eclipse.uml2.examples.source (1.1.1) "UML2 Examples Source" [Resolved]
org.eclipse.uml2.examples.ui (1.1.1) "UML2 Examples UI" [Resolved]
org.eclipse.uml2.resources (1.1.0) "UML2 Resources" [Resolved]
org.eclipse.uml2.source (1.1.1) "UML2 Source" [Resolved]
org.eclipse.update.configurator (3.1.0) "Install/Update Configurator"
[Active]
org.eclipse.update.core (3.1.2) "Install/Update Core" [Resolved]
org.eclipse.update.core.win32 (3.1.0) "Install/Update Core for Windows"
[Resolved]
org.eclipse.update.scheduler (3.1.0) "Automatic Updates Scheduler" [Active]
org.eclipse.update.ui (3.1.1) "Install/Update UI" [Resolved]
org.eclipse.ve (1.1.0) "Visual Editor" [Resolved]
org.eclipse.ve.cde (1.1.0.1) "Visual Editor Common Data Editor" [Resolved]
org.eclipse.ve.doc (1.1.0) "Visual Editor for Java User Guide" [Resolved]
org.eclipse.ve.java.core (1.1.0.1) "Visual Editor Java Core" [Resolved]
org.eclipse.ve.jfc (1.1.0.1) "Visual Editor for Java Foundation Classes"
[Resolved]
org.eclipse.ve.propertysheet (1.1.0.1) "Visual Editor PropertySheet"
[Resolved]
org.eclipse.ve.sdk (1.1.0) "Visual Editor SDK" [Resolved]
org.eclipse.ve.source (1.1.0.1) "Visual Editor Source" [Resolved]
org.eclipse.ve.swt (1.1.0.1) "Visual Editor for Standard Widget Toolkit"
[Resolved]
org.eclipse.webdav (3.0.0) "WebDAV Client" [Resolved]
org.eclipse.wst (0.7.0) "Web Standard Tools" [Resolved]
org.eclipse.wst.command.env (0.7.0) "Environment Command Framework
(headless)" [Resolved]
org.eclipse.wst.command.env.core (0.7.0) "Environment Command Framework
(core)" [Resolved]
org.eclipse.wst.command.env.ui (0.7.0) "Environment Command Framework (GUI)"
[Resolved]
org.eclipse.wst.common.emf (0.7.0) "EMF Utilities" [Resolved]
org.eclipse.wst.common.emfworkbench.integration (0.7.0) "EMF Workbench Edit
Plug-in" [Resolved]
org.eclipse.wst.common.frameworks (0.7.1)
"org.eclipse.wst.common.frameworks" [Resolved]
org.eclipse.wst.common.frameworks.ui (0.7.1) "WTP UI Plug-in" [Resolved]
org.eclipse.wst.common.modulecore (0.7.0) "Modulecore Plug-in" [Resolved]
org.eclipse.wst.common.navigator.views (0.7.0) "Common Navigator View"
[Resolved]
org.eclipse.wst.common.navigator.workbench (0.7.0) "Navigator Workbench
Components" [Resolved]
org.eclipse.wst.common.snippets (0.7.0) "Snippets View" [Resolved]
org.eclipse.wst.common.ui (0.7.0) "Eclipse Base UI extensions" [Resolved]
org.eclipse.wst.common.ui.properties (0.7.0) "Common Properties UI"
[Resolved]
org.eclipse.wst.common.uriresolver (0.7.0)
"org.eclipse.wst.common.uriresolver" [Resolved]
org.eclipse.wst.css.core (0.7.0) "Structured Source CSS Model" [Resolved]
org.eclipse.wst.css.ui (0.7.0) "SSE CSS Source Editor" [Resolved]
org.eclipse.wst.dtd.core (0.7.0) "Structured Source DTD Core" [Resolved]
org.eclipse.wst.dtd.ui (0.7.0) "SSE DTD Source Editor" [Resolved]
org.eclipse.wst.html.core (0.7.1) "Structured Source HTML Model" [Resolved]
org.eclipse.wst.html.standard.dtds (0.7.0) "Known DTDs" [Resolved]
org.eclipse.wst.html.ui (0.7.1) "HTML UI Source Editor" [Resolved]
org.eclipse.wst.internet.cache (0.7.0) "Cache URI Resolver Plug-in"
[Resolved]
org.eclipse.wst.internet.monitor.core (0.7.0) "Monitor" [Resolved]
org.eclipse.wst.internet.monitor.ui (0.7.0) "TCP/IP Monitor" [Resolved]
org.eclipse.wst.internet.proxy (0.7.0) "Internet Proxy Preferences" [Active]
org.eclipse.wst.javascript.core (0.7.0) "Structured Source JavaScript Model"
[Resolved]
org.eclipse.wst.javascript.ui (0.7.0) "SSE JavaScript Source Editor"
[Resolved]
org.eclipse.wst.rdb.connection.ui (0.7.1) "RDB Connection.ui" [Resolved]
org.eclipse.wst.rdb.core (0.7.1) "RDB Core" [Resolved]
org.eclipse.wst.rdb.core.ui (0.7.1) "Core UI plugin" [Resolved]
org.eclipse.wst.rdb.data.core (0.7.0) "Data Core Plugin" [Resolved]
org.eclipse.wst.rdb.data.ui (0.7.0) "Data UI Plugin" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.iseries (1.0.0) "DB2 UDB iSeries
Database Definition Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.db2.luw (0.7.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.db2.zseries (0.7.0) "DB2 UDB Database
org.eclipse.wst.rdb.dbdefinition.derby (0.7.0) "IBM Cloudscape Database
Definition" [Resolved]
org.eclipse.wst.rdb.dbdefinition.informix (0.7.0) "Informix Database
org.eclipse.wst.rdb.dbdefinition.mysql (0.7.0) "DBDefinition Mysql Plug-in"
[Resolved]
org.eclipse.wst.rdb.dbdefinition.oracle (0.7.0) "Oracle Database Definition
Plug-in" [Resolved]
org.eclipse.wst.rdb.dbdefinition.sqlserver (0.7.0) "SQL Server Database
org.eclipse.wst.rdb.dbdefinition.sybase (0.7.0) "Sybase Database Definition
Plug-in" [Resolved]
org.eclipse.wst.rdb.derby (0.7.1) "RDB Derby Plug-in" [Resolved]
org.eclipse.wst.rdb.derby.ui (0.7.1) "RDB Derby Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui (0.7.0) "FE Ui Plug-in" [Resolved]
org.eclipse.wst.rdb.fe.ui.actions (0.7.0) "FE Ui Actions Plug-in" [Resolved]
org.eclipse.wst.rdb.models.dbdefinition (0.7.0) "DBDefinition Model"
[Resolved]
org.eclipse.wst.rdb.models.sql (0.7.0) "SQLModel Plug-in" [Resolved]
org.eclipse.wst.rdb.models.sql.edit (0.7.0) "SQLModel Edit Plug-in"
[Resolved]
org.eclipse.wst.rdb.mysql (0.7.1) "RDB Mysql Plug-in" [Resolved]
org.eclipse.wst.rdb.outputview (0.7.0) "Data Output Plug-in" [Resolved]
org.eclipse.wst.rdb.server.extensions (0.7.1) "Server Explorer Extensions
Plug-in" [Resolved]
org.eclipse.wst.rdb.server.ui (0.7.1) "Server Explorer plugin" [Resolved]
org.eclipse.wst.rdb.sqleditor (0.7.0) "SQL Source Editor Plugin" [Resolved]
org.eclipse.wst.rdb.sqlscrapbook (0.7.0) "Sqlscrapbook Plug-in" [Resolved]
org.eclipse.wst.server.core (0.7.0) "Server Core" [Resolved]
org.eclipse.wst.server.ui (0.7.0) "Server UI" [Resolved]
org.eclipse.wst.source (0.7.1) "Web Standard Tools SDK" [Resolved]
org.eclipse.wst.sse.core (0.7.1) "Structured Text Model" [Resolved]
org.eclipse.wst.sse.ui (0.7.0) "Structured Source Editor" [Resolved]
org.eclipse.wst.validation (0.7.0) "Validation Framework" [Resolved]
org.eclipse.wst.validation.ui (0.7.0) "Validation Framework UI" [Resolved]
org.eclipse.wst.web (0.7.1) "Simple Web Plug-in" [Resolved]
org.eclipse.wst.web.ui (0.7.0) "Simple Web UI Plug-in" [Resolved]
org.eclipse.wst.ws (0.7.1) "Web Services" [Resolved]
org.eclipse.wst.ws.explorer (0.7.1) "Web Services Explorer" [Resolved]
org.eclipse.wst.ws.parser (0.7.0) "Web Services Description Parser"
[Resolved]
org.eclipse.wst.ws.ui (0.7.0) "Web Services UI" [Resolved]
org.eclipse.wst.wsdl (0.7.0) "WSDL Model" [Resolved]
org.eclipse.wst.wsdl.ui (0.7.1) "WSDL Editor" [Resolved]
org.eclipse.wst.wsdl.validation (0.7.0) "WSDL Validator" [Resolved]
org.eclipse.wst.wsi (0.7.0) "WSI Conformance Tools" [Resolved]
org.eclipse.wst.wsi.ui (0.7.0) "Soap Monitor" [Resolved]
org.eclipse.wst.xml.core (0.7.1) "Structured Source XML Model" [Resolved]
org.eclipse.wst.xml.ui (0.7.1) "XML UI Plugin" [Resolved]
org.eclipse.wst.xsd.core (0.7.1) "XSD Core Plugin" [Resolved]
org.eclipse.wst.xsd.ui (0.7.1) "XML Schema Editor" [Resolved]
org.eclipse.xsd (2.1.1) "XML Schema Infoset Model (XSD)" [Resolved]
Guide" [Resolved]
org.eclipse.xsd.ecore.importer (2.1.0) "XML Schema Importer for EMF"
[Resolved]
org.eclipse.xsd.edit (2.1.0) "XML Schema Edit Framework" [Resolved]
org.eclipse.xsd.editor (2.1.0) "XML Schema Editor" [Resolved]
org.eclipse.xsd.example (2.1.0) "XML Schema Infoset Model Example"
[Resolved]
[Resolved]
org.junit (3.8.1) "JUnit Testing Framework" [Resolved]
org.uddi4j (2.0.3) "UDDI4J 2.0.3" [Resolved]
org.wsdl4j (1.4.1) "WSDL4J 1.4" [Resolved]
system.bundle (3.1.2) "OSGi System Bundle" [Active]
*** User Preferences:
#Thu Feb 09 14:02:49 EST 2006
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.ui.browser/browsers=<?xml version\="1.0"
encoding\="UTF-8"?>\r\n<web-browsers current\="0">\r\n<external
location\="C\:\\Program Files\\Mozilla Firefox\\firefox.exe"
name\="Firefox"/>\r\n<external location\="V\:\\Program Files\\Mozilla
Firefox\\firefox.exe" name\="Firefox"/>\r\n<external location\="W\:\\Program
Files\\Mozilla Firefox\\firefox.exe" name\="Firefox"/>\r\n<external
location\="C\:\\Program Files\\Internet Explorer\\iexplore.exe"
name\="Internet Explorer"/>\r\n<external location\="V\:\\Program
Files\\Internet Explorer\\iexplore.exe" name\="Internet
Explorer"/>\r\n<external location\="W\:\\Program Files\\Internet
Explorer\\iexplore.exe" name\="Internet Explorer"/>\r\n</web-browsers>
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.editor.tab.w idth=
/instance/org.eclipse.ui.ide/platformState=488
/instance/org.eclipse.ui.ide/quickStart=true
@org.eclipse.help.ui=3.1.1
/instance/org.eclipse.wst.sse.core/task-tag-projects-already -scanned=XMLExamples,org.eclipse.emf,org.eclipse.emf.ecore.s do,org.eclipse.emf.releng.build,org.eclipse.gef,org.eclipse. gef-feature,org.eclipse.gef.doc.isv,org.eclipse.gef.examples -feature,org.eclipse.gef.examples.ediagram,org.eclipse.gef.e xamples.flow,org.eclipse.gef.examples.logic,org.eclipse.gef. examples.shapes,org.eclipse.gef.examples.text,org.eclipse.ge f.releng,org.eclipse.gef.source,org.eclipse.gef.source-featu re,org.eclipse.gef.test,org.eclipse.uml2,org.eclipse.uml2.re leng,org.eclipse.xsd
file_export_version=3.0
/instance/org.eclipse.wst.xml.ui/lastActivePage=1
@org.eclipse.pde.core=3.1.1
@org.eclipse.wst.sse.ui=0.7.0
@org.eclipse.wst.sse.core=0.7.1
@org.eclipse.jdt.ui=3.1.2
/instance/org.eclipse.team.cvs.ui/pref_first_startup=false
/instance/org.eclipse.pde.core/platform_path=f\:\\eclipse-SD K-3.1.1-win32\\eclipse
/instance/org.eclipse.core.resources/version=1
/instance/org.eclipse.wst.sse.ui/useQuickDiffPrefPage=true
@org.eclipse.ui.browser=3.1.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/instance/org.eclipse.team.cvs.core/repositories/%pserver%anonymous@dev.eclipse.org%%cvsroot%tools/location=\:pserver\:anonymous@dev.eclipse.org\:/cvsroot/tools
@org.eclipse.wst.xml.ui=0.7.1
@org.eclipse.jdt.launching=3.1.0
/instance/org.eclipse.ui.ide/tipsAndTricks=true
@org.eclipse.wst.xsd.ui=0.7.1
/instance/org.eclipse.ui.editors/overviewRuler_migration=mig rated_3.1
/instance/org.eclipse.ui.browser/internalWebBrowserHistory=F \:\\TMDev\\eclipse\\workspace\\XMLExamples\\readme.html|*|fi le\:/F\:/TMDev/eclipse/workspace/XMLExamples/readme.html|*|
/instance/org.eclipse.ui/showIntro=false
@org.eclipse.team.cvs.core=3.1.1
/configuration/org.eclipse.ui.ide/MAX_RECENT_WORKSPACES=5
@org.eclipse.jdt.core=3.1.2
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES=F\:\\TMD ev\\eclipse\\workspace
/instance/org.eclipse.help.ui/browser.y=29
/configuration/org.eclipse.ui.ide/SHOW_WORKSPACE_SELECTION_D IALOG=false
/instance/org.eclipse.wst.sse.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.help.ui/browser.x=22
/instance/org.eclipse.help.ui/browser.w=1024
@org.eclipse.ui.ide=3.1.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/org.eclipse.jdt.ui/fontPropagated=true
@org.eclipse.ui=3.1.2
@org.eclipse.core.resources=3.1.2
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" javadocURL\="http\://java.sun.com/j2se/1.5.0/docs/api/"
name\="jre1.5.0_06" path\="C\:\\Program
Files\\Java\\jre1.5.0_06"/>\r\n</vmType>\r\n</vmSettings >\r\n
/configuration/org.eclipse.ui.ide/RECENT_WORKSPACES_PROTOCOL =2
@org.eclipse.ui.workbench=3.1.2
/instance/org.eclipse.help.ui/browser.h=768
@org.eclipse.ui.editors=3.1.1
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions.migrated=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=8
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.ui.workbench/ENABLED_DECORATORS=org.ec lipse.jst.common.navigator.internal.java.resource.decorator\ :true,org.eclipse.jst.common.navigator.internal.java.decorat or\:true,org.eclipse.team.pessimistic.ui.decorator\:true,org .eclipse.jdt.ui.override.decorator\:true,org.eclipse.jst.ejb .ui.internal.util.EJBAnnotationBeanDecorator_beanClass\:true ,org.eclipse.jst.ejb.ui.internal.util.EJBAnnotationBeanDecor ator\:true,org.eclipse.pde.ui.binaryProjectDecorator\:false, org.eclipse.team.cvs.ui.decorator\:true,org.eclipse.ui.Linke dResourceDecorator\:true,org.eclipse.wst.rdb.core.internal.u i.explorer.DependencyDecoration\:true,org.eclipse.wst.rdb.co re.internal.ui.explorer.ColumnDecoration\:true,org.eclipse.w st.rdb.core.internal.ui.explorer.ForeignKeyDecoration\:true, org.eclipse.wst.rdb.internal.core.ui.bookmarkDecoration\:tru e,com.ibm.datatools.project.internal.ui.explorer.ServerState Decoration\:true,org.eclipse.wst.rdb.core.internal.ui.explor er.FilterNodeDecoration\:true,
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
@org.eclipse.team.cvs.ui=3.1.1
/instance/org.eclipse.wst.xsd.ui/lastActivePage=1
@org.eclipse.team.ui=3.1.1
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.wst.xsd.ui/org.eclipse.wst.xsd.ui.inte rnal.defaultPage=org.eclipse.wst.xsd.ui.internal.graphPage
*** Current Install Configuration:
Install configuration:
Last changed on Feb 7, 2006
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/configuration/org.e clipse.update/platform.xml
Configured sites:
platform:/base/
Configured features:
ID: org.eclipse.jst.source, Version: 0.7.1
ID: org.eclipse.jdt.source, Version: 3.1.2
ID: org.eclipse.emf.ecore.sdo.source, Version: 2.1.1
ID: org.eclipse.sdk, Version: 3.1.2
ID: org.eclipse.pde.source, Version: 3.1.2
ID: org.eclipse.wst.source, Version: 0.7.1
ID: org.eclipse.rcp.source, Version: 3.1.2
ID: org.eclipse.uml2.doc, Version: 1.1.1
ID: org.eclipse.jst, Version: 0.7.0
ID: org.apache.wsil4j.feature, Version: 1.0.0
ID: org.eclipse.emf.ecore.sdo.doc, Version: 2.1.1
ID: org.eclipse.gef.examples.source, Version: 3.1.1
ID: org.eclipse.team.extras, Version: 3.0.0
ID: org.eclipse.platform, Version: 3.1.2
ID: org.eclipse.emf.source, Version: 2.1.2
ID: org.eclipse.uml2.examples.source, Version: 1.1.1
ID: org.eclipse.gef.source, Version: 3.1.1
ID: org.eclipse.jdt, Version: 3.1.0
ID: org.eclipse.uml2, Version: 1.1.1
ID: org.eclipse.jem, Version: 1.1.0.1
ID: org.eclipse.ve.source, Version: 1.1.0.1
ID: org.eclipse.uml2.examples, Version: 1.1.1
ID: org.eclipse.gef, Version: 3.1.1
ID: org.eclipse.sdk.examples, Version: 3.0.1
ID: org.eclipse.jem.source, Version: 1.1.0.1
ID: org.uddi4j.feature, Version: 2.0.3
ID: org.eclipse.emf, Version: 2.1.2
ID: org.eclipse.ve.sdk, Version: 1.1.0
ID: org.eclipse.platform.source, Version: 3.1.2
ID: org.eclipse.rcp, Version: 3.1.0
ID: org.wsdl4j.feature, Version: 1.4.0
ID: org.eclipse.emf.sdk, Version: 2.1.2
ID: org.eclipse.ve, Version: 1.1.0
ID: org.apache.axis.feature, Version: 1.2.1
ID: org.eclipse.xsd.source, Version: 2.1.1
ID: org.eclipse.xsd.doc, Version: 2.1.1
ID: org.eclipse.uml2.source, Version: 1.1.1
ID: org.eclipse.pde, Version: 3.1.0
ID: org.eclipse.xsd, Version: 2.1.1
ID: org.eclipse.emf.doc, Version: 2.1.2
ID: org.eclipse.emf.ecore.sdo, Version: 2.1.1
ID: org.eclipse.wst, Version: 0.7.0
ID: org.eclipse.jem.sdk, Version: 1.1.0
ID: org.eclipse.emf.examples, Version: 2.1.0
Configured plug-ins:
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/com.ibm.eto ols.emf.event_3.0.0.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.apache. ant_1.6.5/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.apache. axis_1.2.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.apache. lucene_1.4.3/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.apache. wsil4j_1.0.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.apache. xerces_2.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .ant.core_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .ant.ui_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .compare.examples.xml_3.0.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .compare.examples_3.0.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .compare_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.boot_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.commands_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.expressions_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.filebuffers_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.resources.compatibility_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.resources.win32_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.resources_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.runtime.compatibility_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.runtime_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .core.variables_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .debug.core_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .debug.ui_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .draw2d.doc.isv_3.1.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .draw2d_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.activities_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ant_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.codegen.ecore.ui_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.codegen.ecore_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.codegen.ui_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.codegen_2.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.common.ui_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.commonj.sdo_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.common_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.doc_2.1.2/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.change.edit_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.change_2.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.editor_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.edit_2.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.sdo.doc_2.1.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.sdo.editor_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.sdo.edit_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.sdo.source_2.1.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.sdo_2.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore.xmi_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.ecore_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.edit.ui_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.edit_2.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.examples_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.importer.ecore_2.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.importer.java_2.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.importer.rose_2.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.importer_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.java.editor_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.java.edit_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.java_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.mapping.ecore2ecore.editor_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.mapping.ecore2ecore_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.mapping.ecore2xml.ui_2.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.mapping.ecore2xml_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.mapping.ui_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.mapping.xsd2ecore.editor_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.mapping.xsd2ecore_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.mapping_2.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf.source_2.1.2/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .emf_2.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .gef.doc.isv_3.1.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .gef.examples.flow_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .gef.examples.logic_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .gef.examples.shapes_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .gef.examples.source_3.1.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .gef.examples.text_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .gef.source_3.1.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .gef_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .help.appserver_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .help.base_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .help.examples.ex1_3.0.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .help.ui_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .help.webapp_3.1.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .help_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.core_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.debug.ui_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.debug_3.1.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.doc.isv_3.1.2/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.doc.user_3.1.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.junit.runtime_3.1.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.junit_3.1.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.launching_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.source_3.1.2/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.ui.examples.projects_3.0.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt.ui_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jdt_3.1.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jem.beaninfo_1.1.0.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jem.proxy_1.1.0.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jem.sdk_1.1.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jem.source_1.1.0.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jem.ui_1.1.0.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jem.util_1.1.0.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jem.workbench_1.1.0.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jem_1.1.0.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jface.text_3.1.2.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jface_3.1.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.common.annotations.controller_0.7.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.common.annotations.core_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.common.annotations.ui_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.common.frameworks_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.common.navigator.java_0.7.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.ejb.ui_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.core_0.7.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.ejb.annotation.model_0.7.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.ejb.annotations.emitter_0.7.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.ejb.annotations.ui_0.7.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.ejb.annotations.xdoclet_0.7.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.ejb_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.jca.ui_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.jca_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.navigator.ui_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.ui_0.7.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.webservices.ui_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.webservice_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee.web_0.7.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.j2ee_0.7.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.jsp.core_0.7.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.jsp.ui_0.7.1.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.core_0.7.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.generic.core_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.generic.serverdefinitions_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.generic.ui_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.geronimo.core_0.7.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.geronimo.ui_0.7.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.tomcat.core_0.7.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.tomcat.ui_0.7.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.ui_0.7.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.server.websphere.core_0.7.0.jar
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.servlet.ui_0.7.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.source_0.7.1/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.ws.axis.consumption.core_0.7.0/
file:/f:/eclipse-SDK-3.1.1-win32/eclipse/plugins/org.eclipse .jst.ws.axis.consumption.ui_0.7.1/
file:/f:/eclipse-
| Re: Stack overflow when opening XSD [message #65996 is a reply to message #65956] |
Thu, 09 February 2006 15:38   |
Billy,
This schema sounds familiar. I'm fairly sure other folks have loaded
this fine, so this might be a problem with the resolver added by WTP.
If you open a bugzilla describing where I can get the schema(s) or you
attach the schemas, I'll try it out. If the problem is in XSD, I'll try
to fix it. If I can't reproduce it, I'll transfer it to WTP and ask
them to have a look.
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> fbc_60
> -vm
> -jar
> eof=eof
> file.separator=\
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=en_US
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=bcousins
> user.variant=
> *** Features:
> Guide"
> Programmers Guide"
> Source"
> Resources"
> Resources"
> Resources"
> Guide"
> [Resolved]
> [Resolved]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> Support" [Resolved]
> Editor" [Resolved]
> Source" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> support" [Resolved]
> [Active]
> [Resolved]
> Support" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> UI" [Resolved]
> [Resolved]
> [Resolved]
> Support" [Resolved]
> [Resolved]
> [Resolved]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Windows" [Resolved]
> Example" [Active]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> (core)" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Location:
> Configured sites:
> platform:/base/
> file:/f:/ec
| Re: Stack overflow when opening XSD [message #66709 is a reply to message #66688] |
Fri, 17 March 2006 17:46  |
--------------070208050200090800000609
Wendell,
The same comment applies. If I can't reproduce it I can't fix it. XSD
itself is designed to handle circular includes, but when I see this in
the stack, all bets are off:
org.eclipse.wst.xsd.ui.internal.util.XSDSchemaLocationResolv erImpl
So someone needs to open a bugzilla and then I'll investigate. If the
problem is not reproducible for me, I ask the WTP folks to investigate
the behavior in their context with their resolver.
Wendell Ocasio wrote:
> I experienced the same problem with other HL7 schemas. It might be
> related to the presence of circular includes. When I manually removed
> the circular includes, the schema was loaded fine.
<html>
<head>
http-equiv="Content-Type">
</head>
Wendell,<br>
<br>
| Re: Stack overflow when opening XSD [message #597544 is a reply to message #65956] |
Billy,
> win32
> -ws
> win32
> -arch
> x86
> -launcher
> -name
> Eclipse
> -showsplash
> 600
> -exitdata
> fbc_60
> -vm
> -jar
> eof=eof
> file.separator=\
> line.separator=
> os.arch=x86
> os.name=Windows XP
> os.version=5.1
> osgi.arch=x86
> osgi.nl=en_US
> osgi.os=win32
> osgi.ws=win32
> path.separator=;
> sun.cpu.isalist=
> sun.desktop=windows
> user.country=US
> user.language=en
> user.name=bcousins
> user.variant=
> *** Features:
> Guide"
> Programmers Guide"
> Source"
> Resources"
> Resources"
> Resources"
> Guide"
> [Resolved]
> [Resolved]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> Support" [Resolved]
> Editor" [Resolved]
> Source" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> Editor" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> support" [Resolved]
> [Active]
> [Resolved]
> Support" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> UI" [Resolved]
> [Resolved]
> [Resolved]
> Support" [Resolved]
> [Resolved]
> [Resolved]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Windows" [Resolved]
> Example" [Active]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Active]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> (core)" [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> [Resolved]
> Plug-in" [Resolved]
> [Resolved]
> Guide" [Resolved]
> [Resolved]
> [Resolved]
> [Resolved]
> Location:
> Configured sites:
> platform:/base/
| Re: Stack overflow when opening XSD [message #597806 is a reply to message #65956] |
Fri, 17 March 2006 17:37  |
related to the presence of circular includes. When I manually removed the
| Re: Stack overflow when opening XSD [message #597808 is a reply to message #66688] |
Wendell,
<html>
<head>
</head>
Wendell,<br>
<br>
Current Time: Sun Nov 02 11:04:31 EST 2025
Powered by FUDForum. Page generated in 0.11406 seconds
