| Attaching source to swt.jar inside the SWT Container [message #55906] | Fri, 13 August 2004 03:25  |  |
| Eclipse User  |  |  |  |  | Originally posted by: harri.mindless.com
 It seems that I am unable to find a way to attach source to swt.jar when
 it is inside the SWT Container.
 The obvious way of opening project properties -> Java build path ->
 Libraries -> SWT Container -> swt.jar -> Source Attachment does not work
 for me (the source attachment always disappears after pressing OK).
 Editing the properties of swt.jar on the package explorer -view suggests
 that I cannot attach the source directly, instead I should "go directly
 to the corresponding configuration page", which I cannot find.
 The bug report https://bugs.eclipse.org/bugs/show_bug.cgi?id=60614
 suggests that there is no obvious way of doing this. Is there a
 non-obvious way?
| Re: Attaching source to swt.jar inside the SWT Container [message #597293 is a reply to message #55906] | Fri, 13 August 2004 07:12  |  |
| Eclipse User  |  |  |  |  | Harry wrote: > Hello,
 > non-obvious way?
 Hi Harry,
 The automatic attachment of source to the SWT/JFace libraries feature
 has been added in recent builds of the VE, post M2.  If you try out the
 VE build I20040811 it should be in there.  The bug you quoted should be
 updated to say this feature has been added.
 - Jeff
FUDForum. Page generated in 0.04827 seconds
