Home » Archived » Eclipse Communications Framework (ECF) » Access container config properties
Access container config properties [message #597172] Mon, 30 January 2006 10:00 Go to next message
I am using ECF for the Eclipse Corona project and have the following
question.
I have a server and client component.
I created a shared object on server and replicated it to the client. The
shared object has properties.
I created the client container(TCPClientSOContainer) with configuration
properties and created the server container(TCPServerSOContainer) with
properties.
When the shared object is created in the client, I can get the shared object
properties via a call to the shared object method getConfig().
What I need access to from the shared object is the container's properties.
From the client shared object I want to access the client container's
properties. From the server shared object I want to access the server
Is there a way to do this?
Jim Wright
Compuware Corp.
Re: Access container config properties [message #597181 is a reply to message #597172] Mon, 30 January 2006 11:38 Go to previous messageGo to next message
Hi Jim,
> question.
> properties.
Yes, but it's not currently in the sharedobjectcontainer api.
You could make a trivial subclass of the TCPClientSOContainer and
TCPServerSOContainer that overrides 'createSharedObjectContext' method
in SOContainer (which is called whenever an shared object is
constructed) and fill out the properties passed to the newly created
shared object context with whichever of the local container's properties
you prefer. This context (and the filled out properties) will be passed
to the shared object when its init method is called and so the shared
object will have those properties available when its code calls
getConfig().getProperties().
Now...do think there is reasonable cause here to expose a method on the
shared object context to access the local container's properties? This
could be easily exposed via a
ISharedObjectContext.getLocalContainerProperties() method or some such.
Could you describe the use case for this a little further? I hadn't
anticipated that shared objects would typically access their container's
properties (unless the container explicitly exposes them through
mechanism such as above), but this could be a good idea.
Scott
Re: Access container config properties [message #597191 is a reply to message #597181] Mon, 30 January 2006 12:26 Go to previous messageGo to next message
Scott
In my case I need the BundleContext of the Bundle that the container/shared
object is running under. I need to create a ServiceTracker so I can
interface with an OSGI service.
The first parameter of the ServiceTracker is the BundleContext.
By placing this information in the Container's properties, I can use the
same code whether the shared object is in the client or the server.
I like the idea of adding ISharedObjectContext.getLocalContainerProperties()
method. It is clean and clearly separates the shared object properties from
JimW
By placing that information in the Container's properties, then I can use
the same code under the client and the server.
"Scott Lewis" <slewis@composent.com> wrote in message
news:43DE4106.7050007@composent.com...
> Hi Jim,
> > question.
The
> > properties.
object
properties.
> Scott
Re: Access container config properties [message #597204 is a reply to message #597191] Mon, 30 January 2006 13:00 Go to previous messageGo to next message
Hi Jim,
Jim Wright wrote:
> Scott
Ah...interesting. Some time ago I had actually anticipated exposing
org.eclipse.ecf.core.IOSGIService directly (which just exposes the
BundleContext service access methods). This so that shared object code
could...with container 'approval'...access local OSGI services...without
having to do what you are doing (passing round BundleContext refs).
So I think that I should move the API to completion there (it's just not
finished yet)...in addition to adding the getLocalContainerProperties()
method to ISharedObjectContext as discussed below. Any comments about that?
Do you think this is reasonable? Just for curiosity's sake...what
BundleContext methods are you going after?
Yes, I will add this method and implementation. After a few minutes
thought I think it would be a reasonable addition. It won't be deployed
until 0.6.2, however, which will probably be next week.
BTW Jim...I haven't yet been able to follow up with Corona plan changes,
support from ECF, etc. Would you like to have a conference call to
discuss...perhaps sometime later this week or next?
Scott
> JimW
>>Hi Jim,
>>>question.
> The
>>>properties.
> object
> properties.
>>Thanks,
>>Scott
Re: Access container config properties [message #597209 is a reply to message #597204] Mon, 30 January 2006 13:08 Go to previous messageGo to next message
I am not not actually using any of the bundle context methods. I need a
BundleContext to create a ServiceTracker to access other registered
services. As in the following
ServiceTracker srvTracker = new
ServiceTracker(context,CollaborationEventRouter.class.getNam e(),null);
I do like the idea of getting a BundleContext without having to pass it
around.
If I wasn't so busy, I think the ECF project would be fun to work on...
JimW
news:43DE5449.90807@composent.com...
> Hi Jim,
> Jim Wright wrote:
> > Scott
container/shared
that?
from
> Scott
> > Thanks,
> > JimW
use
> >>Hi Jim,
> >>>question.
> > The
> >>>properties.
> > object
> > properties.
> >>Thanks,
> >>Scott
Re: Access container config properties [message #597216 is a reply to message #597209] Mon, 30 January 2006 13:22 Go to previous messageGo to next message
Hi Jim,
Ah...OK.
> around.
Hmmm. Perhaps the IOSGIService interface should be enhanced to provide
direct access to BundleContext. BTW, there is a 'getServiceAccess()'
method on ISharedObjectContext interface...although the current
implementations just return null. That can/could be easily fixed, however.
I have a similar perspective :).
This project is largely in the hands of the developer/committer
community, and the community can drive it in directions where they
want/need it to go. Please just be open about your needs and desires so
that they can be addressed (through newsgroups, ecf-dev, bug
reports/feature requests, etc)...and be patient as we're an extremely
small, but active group.
BTW, the ECF committer group is also growing larger...so if any are able
to provide their personal and/or employer commitment to supporting ECF
(through adding developers, etc) then please do so!
Scott
Re: Access container config properties [message #597223 is a reply to message #597216] Mon, 30 January 2006 13:35 Go to previous messageGo to next message
I think for now I am going to subclass TCPClientSOContainer and
TCPServerSOContainer.
As new ECF versions appear, I will look for the
ISharedObjectContext.getLocalContainerProperties() method, if it is
implemented.
I did look at get ServiceAccess and did see some use of it in the future.
JimW
news:43DE595E.9000408@composent.com...
> Hi Jim,
> Ah...OK.
> > around.
however.
> Scott
Re: Access container config properties [message #597232 is a reply to message #597223] Mon, 30 January 2006 17:48 Go to previous message
Hi Jim/all,
I just checked in the following addition to ISharedObjectContext API:
* Get local container properties that it wishes to expose to shared
object access
* @return Map of properties available to calling shared object. Map
returned must not be null.
public Map getLocalContainerProperties();
This API change will appear in v0.6.2 stable...probably in next week
build. The generic ISharedObjectContext implementation (aka SOContext)
of this API calls the following method on SOContainer:
protected Map getContainerPropertiesForSharedObject(ID sharedObjectID) {
return new HashMap();
Subclasses of SOContainer/Client[Server]SOContainer and
TCPClient[Server]SOContainer may override this SOContainer method as
desired to provide properties to sharedobjects that use
getLocalContainerProperties().
Scott
Jim Wright wrote:
> Thanks
> implemented.
> Thanks
> JimW
>>Hi Jim,
>>Ah...OK.
>>>around.
> however.
>>Thanks,
>>Scott
Previous Topic:v 0.6.1 stable now available
Next Topic:ECF as replacement for RMI
Current Time: Sat Jul 26 12:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.07051 seconds
