| Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #60507] | Mon, 11 May 2009 07:16  |  |
| Eclipse User  |  |  |  |  | I have an existing headless build that successfully uses the SDK and delta pack from 3.4.  I recently added dependencies on the latest ECF changes, so
 I had to upgrade to 3.5.  I replaced the SDK and delta pack from 3.4 with
 the ones from 3.5, and I also added the ECF plugin.  The build itself
 succeeds, but when I run the built application, I get an error having to do
 with unresolved bundles (see below), all of which are Equinox p2 bundles.  I
 read that this problem could indicate that my SDK and delta pack libraries
 are incompatible, but I downloaded them from the same build, so that seems
 unlikely.
 Any ideas?  I'm stumped, and I have to resort to manually building (via the
 product file UI) and distributing the software for now.
 Thanks!
 Matt
 !SESSION 2009-05-10
 16:28:33.820 -----------------------------------------------
 eclipse.buildId=unknown
 java.version=1.6.0_13
 Command-line arguments:  -os win32 -ws win32 -arch x86 -console -consoleLog
 !ENTRY org.eclipse.equinox.registry 2 0 2009-05-10 16:28:35.311
 !MESSAGE The extensions and extension-points from the bundle "com.etm.ws"
 are ignored. The bundle is not marked as singleton.
 !ENTRY org.eclipse.osgi 4 0 2009-05-10 16:28:35.632
 !MESSAGE Application error
 !STACK 1
 java.lang.RuntimeException: Application "com.etm.application" could not be
 found in the registry. The applications available are:
 com.etm.ui.news.application, org.eclipse.ant.core.antRunner,
 org.eclipse.ecf.example.clients.chatroomrobot,
 org.eclipse.ecf.example.clients.chatsorobot,
 org.eclipse.ecf.example.clients.chatrobot,
 org.eclipse.ecf.server.generic.Server, org.eclipse.equinox.app.error.
 at
 org.eclipse.equinox.internal.app.EclipseAppContainer.startDe faultApp(EclipseAppContainer.java:242)
 at
 org.eclipse.equinox.internal.app.MainApplicationLauncher.run (MainApplicationLauncher.java:29)
 at
 org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
 at
 org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
 at
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
 at
 org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
 at  org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
 !ENTRY org.eclipse.osgi 2 0 2009-05-10 16:28:35.692
 !MESSAGE One or more bundles are not resolved because the following root
 constraints are not resolved:
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.694
 !MESSAGE Bundle
 initial@reference :file:plugins/org.eclipse.equinox.p2.artifact.repository_1.0 .100.v20090430-2300.jar/
 was not resolved.
 !SUBENTRY 2 org.eclipse.equinox.p2.artifact.repository 2 0 2009-05-10
 16:28:35.697
 !MESSAGE Missing imported package
 org.eclipse.equinox.internal.p2.repository_0.0.0.
 16:28:35.700
 org.eclipse.equinox.internal.provisional.spi.p2.repository_0 .0.0.
 16:28:35.703
 org.eclipse.equinox.internal.p2.repository.helpers_0.0.0.
 16:28:35.705
 org.eclipse.equinox.internal.p2.persistence_0.0.0.
 16:28:35.708
 org.eclipse.equinox.internal.provisional.p2.repository_0.0.0 .
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.711
 !MESSAGE Bundle
 initial@reference :file:plugins/org.eclipse.equinox.p2.engine_1.0.100.v2009043 0-0100.jar/
 was not resolved.
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.713
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.716
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.718
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.720
 !MESSAGE Bundle
 initial@reference :file:plugins/org.eclipse.equinox.p2.metadata.repository_1.0 .100.v20090429-2126.jar/
 was not resolved.
 !SUBENTRY 2 org.eclipse.equinox.p2.metadata.repository 2 0 2009-05-10
 16:28:35.723
 16:28:35.725
 16:28:35.729
 16:28:35.732
 16:28:35.734
 !ENTRY org.eclipse.osgi 2 0 2009-05-10 16:28:35.770
 !MESSAGE The following is a complete list of bundles which are not resolved,
 see the prior log entry for the root cause if it exists:
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.772
 !MESSAGE Bundle com.etm.network_1.0.0  was not resolved.
 !SUBENTRY 2 com.etm.network 2 0 2009-05-10 16:28:35.776
 !MESSAGE Missing required bundle org.eclipse.ecf.example.collab_2.0.0.
 !SUBENTRY 2 com.etm.network 2 0 2009-05-10 16:28:35.778
 !MESSAGE Missing required bundle org.eclipse.ecf.docshare_2.1.0.
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.780
 !MESSAGE Bundle com.etm.ui_1.0.0  was not resolved.
 !SUBENTRY 2 com.etm.ui 2 0 2009-05-10 16:28:35.782
 !MESSAGE Missing required bundle com.etm.ui.network_0.0.0.
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.783
 !MESSAGE Bundle com.etm.ui.network_1.0.0  was not resolved.
 !SUBENTRY 2 com.etm.ui.network 2 0 2009-05-10 16:28:35.785
 !MESSAGE Missing required bundle com.etm.network_0.0.0.
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.787
 !MESSAGE Bundle org.eclipse.ecf.docshare_2.1.0.v20090504-0800  was not
 resolved.
 !SUBENTRY 2 org.eclipse.ecf.docshare 2 0 2009-05-10 16:28:35.790
 !MESSAGE Missing required bundle org.eclipse.ui.editors_0.0.0.
 !SUBENTRY 2 org.eclipse.ecf.docshare 2 0 2009-05-10 16:28:35.791
 !MESSAGE Missing required bundle org.eclipse.ui.ide_0.0.0.
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.793
 !MESSAGE Bundle org.eclipse.ecf.example.collab_2.0.0.v20090504-0800  was
 not resolved.
 !SUBENTRY 2 org.eclipse.ecf.example.collab 2 0 2009-05-10 16:28:35.796
 !SUBENTRY 2 org.eclipse.ecf.example.collab 2 0 2009-05-10 16:28:35.798
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.800
 !MESSAGE Bundle
 org.eclipse.equinox.p2.artifact.repository_1.0.100.v20090430 -2300  was
 not resolved.
 16:28:35.802
 16:28:35.805
 16:28:35.807
 16:28:35.810
 16:28:35.813
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.816
 !MESSAGE Bundle org.eclipse.equinox.p2.engine_1.0.100.v20090430-0100
 was not resolved.
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.818
 org.eclipse.equinox.p2.metadata.repository_1.0.100.
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.820
 org.eclipse.equinox.internal.p2.metadata.repository_0.0.0.
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.822
 org.eclipse.equinox.internal.p2.metadata.repository.io_0.0.0 .
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.824
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.827
 org.eclipse.equinox.internal.provisional.p2.artifact.reposit ory_0.0.0.
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.829
 org.eclipse.equinox.internal.provisional.p2.metadata.reposit ory_0.0.0.
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.831
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.834
 org.eclipse.equinox.internal.provisional.spi.p2.metadata.rep ository_0.0.0.
 !SUBENTRY 2 org.eclipse.equinox.p2.engine 2 0 2009-05-10 16:28:35.836
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.838
 !MESSAGE Bundle
 org.eclipse.equinox.p2.metadata.repository_1.0.100.v20090429 -2126  was
 not resolved.
 16:28:35.841
 16:28:35.843
 16:28:35.846
 16:28:35.849
 16:28:35.851
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.854
 !MESSAGE Bundle org.eclipse.ui.editors_3.5.0.v20090429-1800b  was not
 resolved.
 !SUBENTRY 2 org.eclipse.ui.editors 2 0 2009-05-10 16:28:35.856
 !MESSAGE Missing required bundle org.eclipse.ui.ide_[3.5.0,4.0.0).
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.858
 !MESSAGE Bundle org.eclipse.ui.ide_3.5.0.I20090429-1800  was not
 resolved.
 !SUBENTRY 2 org.eclipse.ui.ide 2 0 2009-05-10 16:28:35.860
 org.eclipse.equinox.p2.engine_[1.0.100,2.0.0).
 !SUBENTRY 1 org.eclipse.osgi 2 0 2009-05-10 16:28:35.862
 !MESSAGE Bundle org.eclipse.ui.win32_3.2.100.v20090429-1800 [93] was not
 resolved.
 !SUBENTRY 2 org.eclipse.ui.win32 2 0 2009-05-10 16:28:35.864
 !MESSAGE Missing host org.eclipse.ui.ide_[3.2.0,4.0.0).
| Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #60901 is a reply to message #60560] | Mon, 11 May 2009 09:47  |  |
| Eclipse User  |  |  |  |  | Thanks for the prompt response.  I had tried "Add Required Plug-ins", but that didn't add org.eclipse.equinox.p2.repository.  It turns out my install
 doesn't have that plug-in.  I actually run the automated build on a
 different machine.  My development eclipse is version 3.5.0 (not sure which
 milestone it was from, but I installed in within the past three weeks).  On
 the automated build machine, I downloaded the most recent SDK and delta pack
 (3.5M7).  So I'm guessing the unresolved bundles changed between my
 installed version and the M7 version?  Is there an easy way to update my
 install so it's consistent with the M7 build?  Or do you recommend
 downgrading the SDK and delta pack on the build machine?
 -Matt
 "Andrew Niefer" <aniefer@ca.ibm.com> wrote in message
 news:gu98fc$9kv$1@build.eclipse.org...
 > The location of the delta-pack does not affect headless build headless
 > build in the same way it does the UI since headless build doesn't know
 > anything about the new Target Platform.
 > The error message implies that your product is simply missing some
 > required bundles.  The p2 bundles' dependencies have changed since 3.4,
 > you appear to be missing org.eclipse.equinox.p2.repository.
 > Add that bundle, or simply just "Add Required Plug-ins" if you have a
 > plug-in based .product file.
 > -Andrew
 > Sither wrote:
 >> I see.  You're right on, I'm still unzipping it over the SDK.  I'm having
 >> trouble finding revised instructions for the headless build in 3.5.  Can
 >> you point me in the right direction?
 >> " msacarny" <michael.sacarny@analog.com> wrote in message
 >> news:c4a37a5ab66a5fb98ddc13bafd7312dd$1@www.eclipse.org...
 >>> How are you including the 3.5 Delta pack? You no longer unzip it over
 >>> the SDK. We ended up using a separate folder and including this
 >>> Directory in the Target Platform.
| Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #597180 is a reply to message #60548] | Mon, 11 May 2009 09:16  |  |
| Eclipse User  |  |  |  |  | The location of the delta-pack does not affect headless build headless build in the same way it does the UI since headless build doesn't know
 -Andrew
 > having trouble finding revised instructions for the headless build in
 > 3.5.  Can you point me in the right direction?
| Re: Problem upgrading existing automated build to use eclipse 3.5 (related to p2?) [message #597185 is a reply to message #60560] | Mon, 11 May 2009 09:47  |  |
 -Matt
 > -Andrew
FUDForum. Page generated in 0.05438 seconds
