Home » Modeling » BPEL Designer » Create process from template flashes
Create process from template flashes [message #5969] Fri, 15 September 2006 04:06 Go to next message
Originally posted by: rthummala.gmail.com
Having trouble creating a process.
I created a project and tried to add BPEL process to it. "Create process
from template" flashes and nothing happens.
I am using Java version "1.5.0_08" on windows.
Any help would be great start for me...
thanks
-Raghu
Re: Create process from template flashes [message #6340 is a reply to message #5969] Thu, 28 September 2006 17:02 Go to previous message
Raghu,
If you are using the build from the update site, there is a bug you
could be hitting that has been since fixed, but a new build has not been
pushed yet.
Make sure that a folder or project is selected in your project before
you run the new process wizard. The wizard is supposed to write its
files to a selected project/folder in your workspace.
Hope this helps.
-michal
> thanks
> -Raghu
Previous Topic:namespaces in bpel
Next Topic:general questions about the BPEL Plugin
Current Time: Wed Sep 17 03:27:18 EDT 2025
Powered by FUDForum. Page generated in 0.03098 seconds
