problem running through test [message #471505] |
Wed, 22 March 2006 17:02  |
I was trying to run through the 1.5 tutorial. after downloading the
pre-reqs. when i go into the windows>pref>web>jsf i get the error
unable to create the selected preference page.
Plug-in org.eclipse.wtp.jsf.ui was unable to load class
org.eclipse.wtp.jsf.ui.internal.classpath.JSFLibrariesPrefer encePage.
anyone know why?
thanks,
dt
Re: problem running through test [message #471585 is a reply to message #471582] |
Wed, 22 March 2006 18:40   |
Dave,
The problem may lie in the fact that the JSF M5 dev build appears to have
been built using Java 5, and you appear to be running Eclipse with JDK
1.4.2_03. (I see a "major.minor version 49.0" message in the log.)
We should be building JSF Tools with JDK 1.4.x, I'm not sure what happened
there (we will look into it, though).
Meanwhile, is it possible/practical for you to run Eclipse with a Java 5 VM
while using JSF Tools?
I apologize for any inconvenience this is causing folks,
Ian Trimble (Oracle)
davest wrote:
> i am using eclipse on windows with the versions in the jsf 1.5 tutorial
> ( http://www.eclipse.org/webtools/jsf/dev_resource/JSFTutorial -M5/JSFTools_milestone5_tutorial.html),
> i have tried the version
> http://download.eclipse.org/eclipse/downloads/drops/I2006030 7-1315/download.php?dropFile=eclipse-SDK-I20060307-1315-win3 2.zip
> and others (as this verison has an x next to it.)
> !ENTRY org.eclipse.ui 4 4 2006-03-22 22:52:16.968
> !MESSAGE Plugin org.eclipse.ui.ide, extension org.eclipse.ui.propertyPages
> Unknown extension tag found: enablement
> !SESSION 2006-03-22 22:52:18.328
> eclipse.buildId=I20060307-1315
> java.version=1.4.2_03
> java.vendor=Sun Microsystems Inc.
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_GB
> Command-line arguments: -os win32 -ws win32 -arch x86
> !ENTRY org.eclipse.osgi 4 0 2006-03-22 22:52:28.140
> !MESSAGE An error occurred while automatically activating bundle
> org.eclipse.wtp.jsf.ui (378).
> !STACK 0
> org.osgi.framework.BundleException: The activator
> org.eclipse.wtp.jsf.ui.internal.JSFUiPlugin for bundle
> org.eclipse.wtp.jsf.ui is invalid
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:965)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:314)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:256)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .preFindLocalClass(EclipseLazyStarter.java:83)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:402)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:188)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:338)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:390)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:351)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
> org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:276)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1245)
> at
> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:144)
> at
> org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:759)
> at
> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
> at
> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
> at
> org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:241)
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
> at
> org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:237)
> at
> org.eclipse.ui.internal.dialogs.WorkbenchPreferenceNode.crea tePage(WorkbenchPreferenceNode.java:46)
> at
> org.eclipse.jface.preference.PreferenceDialog.createPage(Pre ferenceDialog.java:1222)
> at
> org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.cre atePage(FilteredPreferenceDialog.java:316)
> at
> org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1115)
> at
> org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:439)
> at
> org.eclipse.jface.preference.PreferenceDialog$8.selectionCha nged(PreferenceDialog.java:642)
> at
> org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:832)
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
> at org.eclipse.core.runtime.Platform.run(Platform.java:816)
> at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
> at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:14 9)
> at
> org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:830)
> at
> org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1114)
> at
> org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1134)
> at
> org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:236)
> at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:230)
> at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 404)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at
> org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3317)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2963)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
> at org.eclipse.jface.window.Window.open(Window.java:796)
> at
> org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:65)
> at org.eclipse.jface.action.Action.runWithEvent(Action.java:499 )
> at
> org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:539)
> at
> org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
> at
> org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:925)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3340)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2960)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1924)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1888)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:422)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
> at
> org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:107)
> at
> org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:374)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
> at org.eclipse.core.launcher.Main.invokeFramework(Main.java:338 )
> at org.eclipse.core.launcher.Main.basicRun(Main.java:282)
> at org.eclipse.core.launcher.Main.run(Main.java:977)
> at org.eclipse.core.launcher.Main.main(Main.java:952)
> Caused by: java.lang.UnsupportedClassVersionError:
> org/eclipse/wtp/jsf/ui/internal/JSFUiPlugin (Unsupported major.minor
> version 49.0)
> at java.lang.ClassLoader.defineClass0(Native Method)
> at java.lang.ClassLoader.defineClass(Unknown Source)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:160)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:491)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:461)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:420)
> at
> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:403)
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
> ... 71 more
> Root exception:
> version 49.0)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !ENTRY org.eclipse.ui 4 4 2006-03-22 22:52:32.343
Re: problem running through test [message #471590 is a reply to message #471588] |
Thu, 23 March 2006 13:11  |
Dave,
Glad you got things working.
Just to be clear, it *should* have worked with your JDK 1.4.x VM also. Your
experience has made us more aware that we need to ensure we're building JSF
Tools to run in the same VMs that WTP is able to. Oops. (blush)
davest wrote:
> blatant user error! all now works. good work. (prepended jvm in the old
> path problem.)
Re: problem running through test [message #596686 is a reply to message #471505] |
Wed, 22 March 2006 17:45  |
Dave,
That's very odd - I've been in and out of that page several times today
alone, without one problem.
Could you provide a few more details so we can try to reproduce the issue,
please? What Eclipse/WTP/JSF versions? Platform/version?
Anything interesting in the error log?
> anyone know why?
> thanks,
> dt
Re: problem running through test [message #596799 is a reply to message #471505] |
Wed, 22 March 2006 17:57  |
!STACK 0
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:241)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:107)
at
at
at
at
at
version 49.0)
at
at
at
at
at
at
at
at
at
at
at
at
at
... 71 more
Root exception:
version 49.0)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: problem running through test [message #596806 is a reply to message #471582] |
Dave,
> !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> version 49.0)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 71 more
> Root exception:
> version 49.0)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: problem running through test [message #596834 is a reply to message #471588] |
Dave,
davest wrote:
> path problem.)
FUDForum. Page generated in 0.05957 seconds
