Re: Need help generating the SQL Parser [message #596944 is a reply to message #596764] |
Fri, 11 December 2009 19:08  |
Can you explain more about what you are trying to do? I don't
understand the part about the SQLQueryParserManager class not appearing.
You should get that class with a standard download of DTP. It's in
the org.eclipse.datatools.sqltools.parsers.sql.query plugin.
aiquefernandez wrote:
> Hi!.
> Recently I was working with the SQL Parser generated with de DTP
> project, but I've lost it.
> I'm building a new environment, but I don´t know how to generate the SQL
> Parser on my own. I've downloaded the Eclipse, with the EMF, GEF, LPG
> and DTP jars, but if I try to write the code from
> http://www.eclipse.org/datatools/project_sqldevtools/sqltool s_doc/SQL%20Query%20Parser%20User%20documentation.htm
> the SQLQueryParserManager class doesn`t appear. How can I generate the
> parser?.
> Thank for the help, I'm really stuck in the project :(.
FUDForum. Page generated in 0.03302 seconds
