Home » Eclipse Projects » DTP » Missing Dependency
Missing Dependency [message #445251] Fri, 31 July 2009 15:10 Go to next message
I have added DTP to my RCP application and I get the following error when
opening the DSE while the properties view is open.
!ENTRY org.eclipse.ui.views.properties.tabbed 4 4 2009-07-31 15:08:15.324
!MESSAGE Contributor
org.eclipse.datatools.connectivity.DataSourceExplorerNavigat or cannot be
created.
!STACK 1
org.eclipse.core.runtime.CoreException: Plug-in
org.eclipse.datatools.connectivity.ui.dse was unable to load class
org.eclipse.ui.internal.navigator.resources.workbench.Tabbed PropertySheetTitleProvider.
Caused by: java.lang.ClassNotFoundException:
If I add org.eclipse.ui.navigator.resources as a dependency in
org.eclipse.datatools.connectivity.ui.dse the problem goes away.
Is this a missing dependency?
Re: Missing Dependency [message #446309 is a reply to message #445251] Fri, 31 July 2009 17:47 Go to previous messageGo to next message
After further research I believe I have found the problem. In
org.eclipse.datatools.connectivity.ui.dse you have the following:
<extension
point="org.eclipse.ui.views.properties.tabbed.propertyContributor ">
<propertyContributor
contributorId=" org.eclipse.datatools.connectivity.DataSourceExplorerNavigat or "
labelProvider=" org.eclipse.ui.internal.navigator.resources.workbench.Tabbed PropertySheetTitleProvider ">
<propertyCategory category="general"/>
<propertyCategory category="core"/>
<propertyCategory category="appearance"/>
<propertyCategory category="advanced"/>
</propertyContributor>
</extension>
This problem is only triggered if the properties view is a tabbed
properties view.
Re: Missing Dependency [message #446453 is a reply to message #445251] Fri, 31 July 2009 18:10 Go to previous messageGo to next message
> when opening the DSE while the properties view is open.
> created.
> !STACK 1
Hi Erik...
What version of DTP are you working with? But yes, it does sound like a
missing dependency.
--Fitz
Re: Missing Dependency [message #446457 is a reply to message #446309] Fri, 31 July 2009 18:12 Go to previous messageGo to next message
> <extension
> </extension>
> properties view.
Interesting. Something to look at for our 1.7.1 release. Can you create
a Bugzilla entry for this? Thanks!
Re: Missing Dependency [message #480402 is a reply to message #446457] Sun, 16 August 2009 16:29 Go to previous message
Bug Logged:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=286740
Re: Missing Dependency [message #596220 is a reply to message #445251] Fri, 31 July 2009 17:47 Go to previous message
<extension
</extension>
properties view.
Re: Missing Dependency [message #596237 is a reply to message #445251] Fri, 31 July 2009 18:10 Go to previous message
> created.
> !STACK 1
Hi Erik...
missing dependency.
--Fitz
Re: Missing Dependency [message #596250 is a reply to message #446309] Fri, 31 July 2009 18:12 Go to previous message
> <extension
> </extension>
> properties view.
Re: Missing Dependency [message #596325 is a reply to message #446457] Sun, 16 August 2009 16:29 Go to previous message
Bug Logged:
Previous Topic:How to generate Execution Plan in eclipse?
Next Topic:DTP Init Not Thread Safe
Current Time: Fri Jul 18 21:55:03 EDT 2025
Powered by FUDForum. Page generated in 0.43592 seconds
