[MOFScript] functions [message #377481] |
Thu, 10 May 2007 07:04  |
I'm outputting a comma separated list within a
forEach iterator and want to append a comma
after all elements, except the last. I thought
that a simple conditional statement might do this: i.e.:
self.elements->forEach(element) {
element.output()
if (position() + 1 < self.elements.size()) {
However, the use of arithmetic expressions in
sub parts of logical expressions seems not to
be allowed and the above gives me a syntax error.
As an alternative I factored out the arithmetic; i.e.:
var lastPosition = self.elements.size() - 1
element.output()
if (position() < lastPosition) {
Although this works for this example, I now need to
filter the collection and the last element output may
not be at the end of the collection. So, I need a
something like a MOFScript function that indicates
when the last element in the collection is being
processed.
Does anyone know a better approach for the
simple case or how to do the more complicated one.
thanks
Andy.
Dr Andy Carpenter
School of Computer Science,
University of Manchester, Manchester M13 9PL, UK
Email: Andy.Carpenter@manchester.ac.uk
Tel: +44 161 275 6168
Fax: +44 161 275 6280
Re: [MOFScript] functions [message #596131 is a reply to message #377481] |
Fri, 11 May 2007 04:01  |
There is a function in MOFScript that you can use to handle this. The
example bellow should do the work.
self.elements->forEach(element) between (',') {
element.output()
/G
FUDForum. Page generated in 0.03123 seconds
