Home » Archived » XML Schema Definition (XSD) » XML generating wizard
XML generating wizard [message #62585] Wed, 27 July 2005 03:47 Go to next message
Originally posted by: smahon.ittalks.co.uk
For part of an Eclipse plugin i'm developing, I want to generate an XML
file from an XSD Schema, similar to 'new -> other -> xml -> Create XML
file from an XML schema file'. This leads on to a great wizard, which I
would like to use in my app.
But I would like to make some changes to the wizard and make some
selections automatically. What plugin is this wizard contained in and is
it possible to extend it as part of my project?
Shane
Re: XML generating wizard [message #62609 is a reply to message #62585] Wed, 27 July 2005 07:24 Go to previous messageGo to next message
Shane,
Probably this wizard is provided by the XML tools in the WTP project.
I don't know anything about it.
shane wrote:
> XML file from an XSD Schema, similar to 'new -> other -> xml -> Create
> XML file from an XML schema file'. This leads on to a great wizard,
> which I would like to use in my app.
> is it possible to extend it as part of my project?
> Thanks
> Shane
Re: XML generating wizard [message #62842 is a reply to message #62585] Fri, 02 September 2005 01:21 Go to previous messageGo to next message
Originally posted by: nancygrek.gmail.com
shane
did you get to know answer to your question? I having same problem. I want
to generate xml from a schema.
do u know exactly which api can help me?
thaks in advance
nancy
Re: XML generating wizard [message #62857 is a reply to message #62842] Wed, 07 September 2005 07:33 Go to previous message
Nancy,
Did you try the WTP newsgroup?
nancy wrote:
> shane
> want to generate xml from a schema.
> thaks in advance nancy
Re: XML generating wizard [message #596109 is a reply to message #62585] Wed, 27 July 2005 07:24 Go to previous message
Shane,
shane wrote:
> Thanks
> Shane
Re: XML generating wizard [message #596263 is a reply to message #62585] Fri, 02 September 2005 01:21 Go to previous message
shane
thaks in advance
nancy
Re: XML generating wizard [message #596270 is a reply to message #62842] Wed, 07 September 2005 07:33 Go to previous message
Nancy,
nancy wrote:
> shane
Previous Topic:finding enclosed type of soap-encoded arrays
Next Topic:Accessing included/imported XSD in App Server environment
Current Time: Mon Oct 27 06:38:35 EDT 2025
Powered by FUDForum. Page generated in 0.05615 seconds
