| Export Wizard doesn't show my plugin [message #56746] | Fri, 17 April 2009 15:28  |  |
| Eclipse User  |  |  |  |  | Originally posted by: ledelstein.salesforce.com
 Why isn't one of my plugins showing up in the export wizard?
 I've created four plugins; they're all in my workspace.  When I try to
 export them using "File..Export..Plug-in Development/Deployable plug-ins
 and fragments", only three of my plugins show up in the list of available
 plugins and fragments.
 Any ideas?
 Larry Edelstein
 Senior Member of Technical Staff
 salesforce.com
| Re: Export Wizard doesn't show my plugin [message #62554 is a reply to message #56881] | Thu, 21 May 2009 21:14   |  |
| Eclipse User  |  |  |  |  | Originally posted by: zzq.hvc.rr.com
 I'm having the same problem - I have several plugin projects which have
 somehow lost their ability to be recognized as plugins by the Export
 Wizard.
 I've compared the build.properties, plugin.xml, MANIFEST.MF, .project
 and .classpath files with a project which is recognized by the Export
 Wizard, and I don't see anything which might be causing this.
 If there is someone who is familiar with the internals of the Export
 Wizard, perhaps they could explain what information is used by the
 wizard to identify a plugin project?
 Even more importantly, I'd like to know how to reset the plugins so that
 they can then be exported.
 Thanks.
 Bill Fenlason
 ps I have no idea where the source for the Export Wizard is, but if
 someone can point me at it I'll have a look for myself.
 Chris Aniszczyk wrote:
 > Larry Edelstein wrote:
 >> Thanks Ankur.  The plugin project in question has the same project
 >> natures and builders as the other projects - including the plugin
 nature.
 >> One thing it doesn't have is a plugin.xml, nor does it have a
 >> build.properties.  I didn't think those would be needed, though. Still
 >> looking -
 > How do you have a plug-in project w/o a build.properties ;)?
 > How did you create the plug-in project?
 > What's your workflow like?
 > Cheers,
 > Chris Aniszczyk | EclipseSource Austin | +1 860 839 2465
 > http://twitter.com/eclipsesource | http://twitter.com/caniszczyk
| Re: Export Wizard doesn't show my plugin [message #62654 is a reply to message #62554] | Fri, 22 May 2009 13:00  |  |
 After tracing GetListElements() in the PluginExportWizardPage, it
 appears to me that the problem is not with the existence or contents of
 any of the files, but that WorkspaceModelManager.isBinaryProject()
 returns true.
 The EXTERNAL_PROJECT_PROPERTY is set, even though the project is not
 really external in the sense that all of the source and other files are
 in the project in the workspace.  Shouldn't that be sufficient for the
 plugin to be exportable?
 Could be something about the "imported" property not getting reset or
 something like that.  I'm not exactly sure what I did to cause the
 situation.  Maybe the plugin was a binary import originally and then the
 source added, moved around, etc.
 In any event, the problem is real.  Is this an obscure bug that should
 be submitted?  It is certainly a bit of a PIA for me to straighten out.
 Perhaps the logic in GetListElements() which decides what an eligible
 project is could be reconsidered?  Or perhaps the problem is with
 isBinaryProperty()?  I wouldn't presume to totally understand the
 situation, but hopefully someone who does will take a look.  I'll retain
 the problem workspace and projects in case there is any more information
 that would be useful.
 Bill
| Re: Export Wizard doesn't show my plugin [message #595772 is a reply to message #56746] | Fri, 17 April 2009 15:40  |  |
| Eclipse User  |  |  |  |  | Larry Edelstein wrote: > Why isn't one of my plugins showing up in the export wizard?
 > available plugins and fragments.
 > Any ideas?
 > Larry Edelstein
 > salesforce.com
 Make sure the 4th one IS a plugin project and not just a Java project.
 hth,
 Ankur..
| Re: Export Wizard doesn't show my plugin [message #595810 is a reply to message #56773] | Fri, 17 April 2009 17:02  |  |
| Eclipse User  |  |  |  |  | Thanks Ankur.  The plugin project in question has the same project natures and builders as the other projects - including the plugin nature.
 Still looking -
 Larry Edelstein
 salesforce.com
| Re: Export Wizard doesn't show my plugin [message #595815 is a reply to message #56854] | Fri, 17 April 2009 17:27  |  |
| Eclipse User  |  |  |  |  | Larry Edelstein wrote: > Thanks Ankur.  The plugin project in question has the same project
 > Still looking -
| Re: Export Wizard doesn't show my plugin [message #597735 is a reply to message #56881] | Thu, 21 May 2009 21:14  |  |
| Eclipse User  |  |  |  |  | I'm having the same problem - I have several plugin projects which have somehow lost their ability to be recognized as plugins by the Export
 Wizard.
 Thanks.
 Bill Fenlason
 nature.
 >> looking -
 > Cheers,
| Re: Export Wizard doesn't show my plugin [message #597768 is a reply to message #62554] | Fri, 22 May 2009 13:00  |  |
| Eclipse User  |  |  |  |  | After tracing GetListElements() in the PluginExportWizardPage, it appears to me that the problem is not with the existence or contents of
 returns true.
 Bill
FUDForum. Page generated in 0.03678 seconds
