| Home » Eclipse Projects » Technology Project and PMC » Decision making process in Eclipse project?
 Goto Forum:|
| Decision making process in Eclipse project? [message #58768] | Sun, 12 October 2003 07:33  |  |
| Eclipse User  |  |  |  |  | Originally posted by: derisor.arcor.de
 I am curious about the decision making process in Eclipse. The reason that I am
 so curious is that I am used to working with apache projects which have
 something of a democratic system in their decisions about code implementation
 procedures. In addition the process of submitting patches or code to apache
 projects is rather fast.
 I recently filed some issues with SWT in particular and it seems a couple of
 them were flat vetoed by one single person at IBM.
 Re:
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=44111
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=43007
 In addition, I did a rather significant piece of code that is important and
 submitted it and it has so far been ignored completely.
 https://bugs.eclipse.org/bugs/show_bug.cgi?id=43990
 It is certainly discouraging to people that want to get involved to be merely
 ignored.
 So is there some process behind the Eclipse project or is it just run primarily
 according to the whims of a few people at IBM? If so then I wont bother wasting
 my time making contributions and having them ignored.
 -- Robert
| Re: Decision making process in Eclipse project? [message #58870 is a reply to message #58768] | Mon, 13 October 2003 12:42   |  |
| Eclipse User  |  |  |  |  | > I recently filed some issues with SWT in particular and it seems a couple of > them were flat vetoed by one single person at IBM.
 true, some people tend to get 'snippy' and will give some ideas more
 consideration based on from whom they are coming. but as most
 open-source projects are, this is a meritocracy.
 > Re:
 first, this should have been filed as an RFE, not a bug. what the
 responder is saying that this is functioning as designed.
 second, the entire concept of SWT is to directly call the underlying
 OS's procedure for accomplishing the task (if it exists). absolutely no
 other functionality is added by design. if anything, this RFE should be
 submitted with the OS, since it is the OS that does not check for valid
 styles. SWT merely sends the information to the underlying OS call. it
 does not act on and has no knowledge of the information at all. this is
 a basic SWT concept which is conveyed in much of the SWT documentation
 out there.
 swt is its own project and a link to its web page can be found at:
 http://www.eclipse.org/platform/index.html
 it  has no more or less billing than any other eclipse technology. in
 addition, you can download SWT separately on the download page.
 first, you just submitted this less than two weeks ago, at a time when
 every one is working hard to push the M4 build out the door. any new
 code clearly won't be considered this close to a milestone release. now
 that M4 is out is when you should begin pushing new ideas.
 second, the method:
 public boolean hooks(final int eventType) {
 synchronized (this.eventMap) {
 return (getListenerMap(eventType) == null);
 should be changed to:
 return (getListenerMap(eventType) != null);
 third, although this class is not serializable, who knows what bizarre
 uses it (or its derived classes) may hold in the future. i can't think
 of any reason this would become serializable, but just to be safe
 eventMap (and anything that holds listener references) should be marked
 as <transient>, and the readObject(...) method should be used to
 reinitialize it. of course, then eventMap can't be final, so it's a
 trade off...
 fourth, i'm not an expert at weak references, but i don't think this
 code will work. consider the following (generic) method many people use
 to write event code. I don't know the code, so i'm sure some of it is
 incorrect, but it conveys the concept:
 eventTable.hook(
 SWT.SOME_EVENT, new EventListener() {
 public void handleEvent(Event e) {
 this uses an anonymous inner class to handle the event, so there are no
 references. the only strong reference would normally be is the one in
 the event map. using the WeakHashMap, there are no strong references.
 this anonymous inner class instance may be finalized and cleaned up at
 any time; sometimes the event won't be 'heard'. in fact, i think it's
 standard procedure not to have a reference for events that you know will
 never be unhooked. did you compile and test this code extensively?
 > ignored.
 nothing happens instantly in an open-source project. just because the
 originator of an idea thinks it's a good one doesn't mean everyone will
 think it's worthwhile. enough people have to learn of and support an
 idea for it to become reality. it is up to you to 'advertise' your ideas
 and convince people of their merit. that's one of the reasons why these
 newsgroups exist.
 this project is a very large effort involving a lot of people. many of
 these people are very talented. people are not going to drop what they
 are doing just because some new guy thinks they have a great idea. no
 offense intended with the wording there, just trying to convey the point
 as succinctly as possible. as i mentioned above, eclipse is a
 meritocracy; people start at the bottom. this is necessary with all
 open-source projects because many people become excited about a project
 but then lose interest; a lot of time would be wasted with people who
 don't follow through with their ideas. it is only those with proven
 dedication to the project that have a large say in its direction. if
 someone new has a good idea it is up to them to 'sell' it to those with
 more influence. as they continue to make valuable contributions their
 value to the community will go up.
 as a friend of mine used to say, "you catch more bees with honey than
 you do with vinegar". the tone of your post probably won't help your
 case any and it probably won't get you favored treatment in the future.
 -alvin
| Re: Decision making process in Eclipse project? [message #58920 is a reply to message #58870] | Mon, 13 October 2003 16:43   |  |
 "Alvin Thompson" <nobody@nowhere.com> wrote in message
 news:3F8AD60B.2020101@nowhere.com...
 An idea is an idea, regardless of where it comes from. Given some of the code
 quality in SWT, I would think they need every bit of help they can get.
 > > Re:
 > out there.
 This page is still merely a description of SWT as a component of Eclipse whereas
 it has become a technology in its own right.
 Im pretty much convinced that there is little reason to bother. There is no
 voting process or other process that I can tell. When I merely suggested the
 source should be documented and formatted, some people at IBM threw a fit. You
 would have thought I asked them to murder their firstborn.
 > second, the method:
 Good catch.
 > trade off...
 Why would you serialize a gui component? And the original class isnt
 serializable either.
 > eventTable.hook(
 First of all, anonymous classes are extremely bad practice. I could enumerate
 the problems with them but it would take pages and pages just to get started.
 You can check out my book, Hardcore Java, which should be published in a couple
 months by O'Reilly.
 Second of all, creating a new object and dumping it into nowhere is a bad idea
 as well.
 Third of all, if this was held in a strong reference, there would be no way to
 unhook the event. This can lead to extremely HUGE memory leaks... consider ...
 eventTable.hook(
 Dialog dlg;
 dlg = new Dialog(shell, STYLE);
 // add 12 composites with multiple widgets ad attached to data
 objects.
 // Link the widgets into data objects using jface
 // show the dialog.
 In this case, event listener will hold onto the dialog and all of its controls
 and so on forever and there is absolutely no way to unhook it and make the
 references go away.
 If you absolutely insist on using anonymous classes, you should store their
 instances so that on dispose the window can unhook them. The more circular
 strong references you have in code, the more potential for huge memory leaks.
 To summarize:
 1) Anonmyous classes are bad but if you insist on using them, store their
 instances in class variables.
 2) Memory leaks are caused by circular strong references.
 merely
 > > ignored.
 > newsgroups exist.
 Everyone? From what I can tell individuals are making the vetos. There is no
 voting process that I can see so the word "everyone" is rather a misnomer.
 primarily
 wasting
 Who said they have to drop what they are doing. However when vicious replys hit
 bug tracking and bugs are closed spontaneously because of one person's opinion
 then it isnt open source. Its ... something else.
 People loose interest because they submit ideas and are relied to with hostility
 or ignored.
 I spend a horde of time at work trying to sell the right ideas to managers so
 politically married to their code that they cant see the issues in it. I would
 have hoped in open source commuinity the emphasis would have been on getting
 things done right. As a regular contributor to apache projects I can say that
 they DO have such a process and drive and it works. I could MURDER the code
 quality of SWT if I wanted to. However, instead of merely bitching, I offer my
 services and am attacked or ignored. Since I am no one important I doubt my
 experience is unique.
 Eclipse needs a process. Something similar to the apache process.
 > -alvin
 I dont expect "favored" treatment. I expect people to act like professionals and
 people who are more concerned about doing things right. Developers that treat
 code as if it was their baby and anyone suggesting changes is murdering their
 baby need to get a reality check. My "tone" is matter of fact indication of
 annoyance at what i have seen not just recently but over several months. Im not
 in open source to play politics, Im in it to write good code.
 -- Robert
| Re: Decision making process in Eclipse project? [message #58969 is a reply to message #58920] | Mon, 13 October 2003 20:27  |  |
| Eclipse User  |  |  |  |  | > An idea is an idea, regardless of where it comes from. Given some of the code
 are we now discussing code quality or are we discussing your issues with
 the decision-making process?
 i agree on this. a more 'independent' home page (in addition to the
 current one) is warranted.
 anonymous classes are extremely bad practice? i use them extensively in
 event code and i like to think of myself as a reasonably accomplished
 programmer. please convince me of this.
 besides, your original assertion was that there would be no other
 changes needed in the eclipse code. now it seems using your code would
 require rewriting all event code to not use anonymous nested classes, as
 well as ensuring that no future submissions use them. that's a lot of
 work for everyone else just because you don't like that particular
 programming style.
 > as well.
 i don't understand this statement. please explain it.
 > eventTable.hook(
 >           Dialog dlg;
 > objects.
 >              // show the dialog.
 > references go away.
 true, the code above will hold on to the most recent dialog object and
 its members indefinitely. until it is called again, BUT:
 first, it is poorly written NOT because it hangs on to the Dialog object
 (it should), but rather because it creates a new Dialog object every
 time it is called instead of reusing the old one.  the first rule of
 event management code is to never--ever--create objects unless you
 absolutely have to; if you must use an object, hold on to it for reuse.
 second, i have looked at a lot of code and i have never seen anyone
 write an anonymous nested class that used its own members to hold
 disposable objects. what would be the point? while it is permissible to
 use contrived examples to prove a point, this one is so unlikely as to
 be unreasonable to expend effort accounting for.
 third, if this (or any) framework were to try to account for every
 possible user's bad programming practice, it would be very large and
 very slow (well, larger and slower :) .
 fourth, this code could be easily written without the anonymous inner
 class and it would exhibit the same behavior.
 > To summarize:
 does creating new objects during event dispatch have the potential for
 memory leaks? of course. but that has nothing to do it being in an
 anonymous inner class.
 where are the circular references here? i don't see any. but i DO know
 that the garbage collector is smart enough to reclaim unused circular
 references (that's java 101). i also know that WeakHashMap IS NOT smart
 enough to know that a strong reference to an object is circular (that's
 java 102).
 on the bottom of every bug report/RFE page there is the link 'vote for
 this bug'. if people think it is a good idea, they will vote for it.
 > or ignored.
 i have not observed anyone being especially hostile to you. on the other
 hand, you seem to be exceptionally combative in this newsgroup. you
 cannot expect people to be cooperative when you take this tone. please
 don't give me any 'he started it' arguments as i would find it hard to
 believe.
 it is hard to expect others to act like a professional when you yourself
 do not. you started your last post impugning the code quality in SWT.
 how is this constructive? in a way, the code IS their baby; they have
 put a lot of time and effort into it. if you were a parent and someone
 told you that your baby was ugly, you would take offense as well. you
 claim your code is better, but the SWT team has produced an actual
 working product whereas you have not, a product that you yourself admit
 that many people wish to use.
 > ... Im not
 you are obviously young if you make this statement, so i will give you a
 very good piece of advice: everything in life involves playing politics
 to some degree. if you do not make an effort to 'play well' with others
 you entire life will be much more difficult. this problem you are having
 with the SWT developers is just one example. are there others?
 sincerely,
 alvin
| Re: Decision making process in Eclipse project? [message #595629 is a reply to message #58768] | Mon, 13 October 2003 12:42  |  |
 > Re:
 out there.
 second, the method:
 trade off...
 eventTable.hook(
 > ignored.
 newsgroups exist.
 -alvin
| Re: Decision making process in Eclipse project? [message #595651 is a reply to message #58870] | Mon, 13 October 2003 16:43  |  |
 > > Re:
 > out there.
 > second, the method:
 Good catch.
 > trade off...
 > eventTable.hook(
 months by O'Reilly.
 as well.
 eventTable.hook(
 Dialog dlg;
 objects.
 // show the dialog.
 references go away.
 To summarize:
 merely
 > > ignored.
 > newsgroups exist.
 primarily
 wasting
 or ignored.
 > -alvin
 -- Robert
| Re: Decision making process in Eclipse project? [message #595663 is a reply to message #58920] | Mon, 13 October 2003 20:27  |  |
 programming style.
 > as well.
 > eventTable.hook(
 >           Dialog dlg;
 > objects.
 >              // show the dialog.
 > references go away.
 > To summarize:
 java 102).
 > or ignored.
 believe.
 > ... Im not
 sincerely,
 alvin
 Current Time: Fri Oct 31 19:44:53 EDT 2025
 Powered by FUDForum . Page generated in 0.06848 seconds |
