Home » Eclipse Projects » Mylyn » Mylyn Trac connector mappings for priority and severity fields
Mylyn Trac connector mappings for priority and severity fields [message #60149] Fri, 17 October 2008 11:27 Go to next message
does anybody know which custom values for the priority (and severity) fields are supported by Mylyn
Trac connector to see the overlay icons for high ("!") and low ("^") priorities?
Has the severity field any influence on the decoration?
Thanks, Jörg
Re: Mylyn Trac connector mappings for priority and severity fields [message #60172 is a reply to message #60149] Fri, 17 October 2008 14:39 Go to previous messageGo to next message
This bug has details how the mapping works for Trac:
211147: recognize priority levels of custom trac priorities
https://bugs.eclipse.org/bugs/show_bug.cgi?id=211147
I'll add an entry to the FAQ.
Steffen
> Hello,
> fields are supported by Mylyn Trac connector to see the overlay icons for
> Thanks, Jörg
Re: Mylyn Trac connector mappings for priority and severity fields [message #60219 is a reply to message #60172] Sat, 18 October 2008 13:12 Go to previous messageGo to next message
Thanks, Steffen.
Please, could you also tell us what happens if you have less than 5 priorities.
We have the following ones:
"urgent" -- should be mapped to P1 ( big "!" )
"normal" -- should be mapped to P3 ( no indicator )
Many thanks, Jörg
Re: Mylyn Trac connector mappings for priority and severity fields [message #60291 is a reply to message #60219] Sun, 19 October 2008 14:56 Go to previous message
Originally posted by: steffen.pingel.eclipse.org
I would expect the mapping to work like this if urgent is the first priority
and normal the last:
urgent - P1 (!)
normal - P5 ( )
Steffen
Please file a bug if the behavior is different.
> Thanks, Steffen.
> priorities. We have the following ones:
> Many thanks, Jörg
Re: Mylyn Trac connector mappings for priority and severity fields [message #594285 is a reply to message #60149] Fri, 17 October 2008 14:39 Go to previous message
Steffen
> Hello,
> Thanks, Jörg
Re: Mylyn Trac connector mappings for priority and severity fields [message #594313 is a reply to message #60172] Sat, 18 October 2008 13:12 Go to previous message
Thanks, Steffen.
Many thanks, Jörg
Re: Mylyn Trac connector mappings for priority and severity fields [message #594343 is a reply to message #60219] Sun, 19 October 2008 14:56 Go to previous message
urgent - P1 (!)
normal - P5 ( )
Steffen
> Thanks, Steffen.
> Many thanks, Jörg
Previous Topic:Trac problems with certificates
Next Topic:Could not load repository template extension repository
Current Time: Sun Oct 19 05:38:38 EDT 2025
Powered by FUDForum. Page generated in 0.27268 seconds
