Home » Archived » Service Oriented Architecture Tools Platform (STP) » Cannot access SOA Preferences pages
Cannot access SOA Preferences pages [message #593963] Mon, 01 October 2007 11:38 Go to next message
When trying to access the SOA preferences pages I get the following errors:
Unable to create the selected preference page.
org.eclipse.stp.sc.jaxws.preferences.SCMainPreferencePage
org.eclipse.stp.sc.sca.preferences.SCMainPreferencePage
I have tried mulitple base eclipse version and then extracted the pre-reqs
on top and finally extracted the latest stp:
stp-all-in-one-R-R200709271701-200709271701.zip
All of this started because my original install of the
eclipse-jee-europa-win32.zip and then using the Update Manager to pull in
the Europa Discovery SOA plugins with the latest apache cxf and tuscany
plugins from the apache site gave me problems trying to create the wsdl from
the java code and then it would not create the Java client from the wsdl.
So....then I tried the eclipse-jee-europa-fall-win32.zip and then pulling in
the SOA plugins from the SOA update site and the required pre-reqs from the
Europa Discovery site. That gave me an incomplete install of SOA, JAX-WS
and SCA was missing all together from the preferences.
And finally I went with the eclipse-SDK-3.3.1-win32.zip and then downloaded
all of the pre-req plugins from the SOA download page as well as the
stp-all-in-one-R-R200709271701-200709271701.zip which brings me to my
current problem.
Here is the .log dump:
!SESSION 2007-10-01
11:12:13.283 -----------------------------------------------
eclipse.buildId=M20070921-1145
java.version=1.6.0_02
Command-line arguments: -os win32 -ws win32 -arch x86
!ENTRY org.eclipse.update.configurator 2007-10-01 11:12:18.157
!MESSAGE Could not install bundle
plugins/net.sourceforge.lpg.lpgjavaruntime.source_1.1.0.v200 706111738.jar
Bundle "net.sourceforge.lpg.lpgjavaruntime.source" version
"1.1.0.v200706111738" has already been installed from:
update@plugins /net.sourceforge.lpg.lpgjavaruntime.source_1.1.0.v2007061117 38/
!SESSION 2007-10-01
11:13:30.073 -----------------------------------------------
java.version=1.5.0_12
!ENTRY org.eclipse.update.configurator 2007-10-01 11:13:33.432
!SESSION 2007-10-01
11:17:28.210 -----------------------------------------------
!ENTRY org.eclipse.update.configurator 2007-10-01 11:17:30.866
!ENTRY org.eclipse.ui 4 0 2007-10-01 11:17:49.239
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.Error:
Unresolved compilation problem:
Override cannot be resolved to a type
at org.eclipse.swt.SWT.error(SWT.java:3563)
at org.eclipse.swt.SWT.error(SWT.java:3481)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:126)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3659)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3296)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:820 )
at org.eclipse.jface.window.Window.open(Window.java:796)
at
org.eclipse.ui.internal.OpenPreferencesAction.run(OpenPrefer encesAction.java:65)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:546)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:490)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:402)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:169)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
at
at
at java.lang.reflect.Method.invoke(Method.java:585)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 508)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:447)
at org.eclipse.equinox.launcher.Main.run(Main.java:1173)
at org.eclipse.equinox.launcher.Main.main(Main.java:1148)
Caused by: java.lang.Error: Unresolved compilation problem:
at
org.eclipse.stp.common.preferences.CategoryPreferencePage.cr eateContents(CategoryPreferencePage.java:44)
at
org.eclipse.jface.preference.PreferencePage.createControl(Pr eferencePage.java:233)
at
org.eclipse.jface.preference.PreferenceDialog.createPageCont rol(PreferenceDialog.java:1456)
at
org.eclipse.jface.preference.PreferenceDialog$13.run(Prefere nceDialog.java:1213)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:857)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:46)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:19 9)
at
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1207)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.sho wPage(FilteredPreferenceDialog.java:433)
at
org.eclipse.jface.preference.PreferenceDialog$9.selectionCha nged(PreferenceDialog.java:698)
at
org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredV iewer.java:842)
at
org.eclipse.jface.viewers.StructuredViewer.firePostSelection Changed(StructuredViewer.java:840)
at
org.eclipse.jface.viewers.StructuredViewer.handlePostSelect( StructuredViewer.java:1153)
at
org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected( StructuredViewer.java:1178)
at
org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(O penStrategy.java:250)
at org.eclipse.jface.util.OpenStrategy.access$4(OpenStrategy.ja va:244)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java: 418)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
at
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
... 34 more
!ENTRY org.eclipse.osgi 2 0 2007-10-01 11:17:59.644
!MESSAGE The activator org.eclipse.stp.sc.jaxws.ScJaxWsPlugin for bundle
org.eclipse.stp.sc.jaxws is invalid
!STACK 0
org.osgi.framework.BundleException: The activator
org.eclipse.stp.sc.jaxws.ScJaxWsPlugin for bundle org.eclipse.stp.sc.jaxws
is invalid
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
at
org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:970)
at
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:260)
at
org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:234)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1269)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
at
org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:788)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:252)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
at
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:248)
at
org.eclipse.ui.internal.dialogs.WorkbenchPreferenceNode.crea tePage(WorkbenchPreferenceNode.java:47)
at
org.eclipse.jface.preference.PreferenceDialog.createPage(Pre ferenceDialog.java:1294)
at
org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.cre atePage(FilteredPreferenceDialog.java:313)
at
org.eclipse.jface.preference.PreferenceDialog.showPage(Prefe renceDialog.java:1185)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:434)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:369)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:357)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:83)
at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:289)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:134)
... 66 more
Root exception:
java.lang.ClassNotFoundException: org.eclipse.stp.sc.jaxws.ScJaxWsPlugin
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
!ENTRY org.eclipse.ui 4 0 2007-10-01 11:18:03.269
!STACK 0
Unresolved compilation problems:
The import org.eclipse.stp.sc.jaxws.ScJaxWsPlugin cannot be resolved
The import org.eclipse.stp.sc.jaxws.ScJaxWsResources cannot be resolved
The import org.eclipse.stp.sc.jaxws.preferences.SCPreferenceConstants
cannot be resolved
SCPreferenceConstants cannot be resolved
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Caused by: java.lang.Error: Unresolved compilation problems:
cannot be resolved
at
org.eclipse.stp.sc.cxf.preferences.SCCXFPreferencePage.<init >(SCCXFPreferencePage.java:16)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Nativ e Method)
at
sun.reflect.NativeConstructorAccessorImpl.newInstance(Native ConstructorAccessorImpl.java:39)
at
sun.reflect.DelegatingConstructorAccessorImpl.newInstance(De legatingConstructorAccessorImpl.java:27)
at java.lang.reflect.Constructor.newInstance(Constructor.java:4 94)
at java.lang.Class.newInstance0(Class.java:350)
at java.lang.Class.newInstance(Class.java:303)
at
org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:170)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 34 more
!ENTRY org.eclipse.ui 4 0 2007-10-01 11:18:05.347
!STACK 0
cannot be resolved
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
cannot be resolved
at
org.eclipse.stp.sc.jaxwsri.preferences.SCJAXWSRIPreferencePa ge. <init>(SCJAXWSRIPreferencePage.java:16)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 34 more
!ENTRY org.eclipse.osgi 2 0 2007-10-01 11:18:06.847
!MESSAGE The activator org.eclipse.stp.sc.sca.ScScaPlugin for bundle
org.eclipse.stp.sc.sca is invalid
!STACK 0
org.eclipse.stp.sc.sca.ScScaPlugin for bundle org.eclipse.stp.sc.sca is
invalid
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
... 66 more
Root exception:
java.lang.ClassNotFoundException: org.eclipse.stp.sc.sca.ScScaPlugin
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Re: Cannot access SOA Preferences pages [message #593992 is a reply to message #593963] Tue, 02 October 2007 07:20 Go to previous messageGo to next message
Originally posted by: Emanuel.Georgiew.c-lab.de
Hi Scott!
I'm also currently trying to install SOA with the Eclipse Fall Maintenance
release on a Debian Linux machine. Unfortunately still with no complete
success, but I succeeded in installing the plugin.
I have experienced, that it is vital to install the required third party
plugin JSR API plugins from open.iona.com (see «
http://wiki.eclipse.org/STP_Service_Creation_getting_started _guide_for_stp_0.7
Have You installed it? Have you also installed all required prerequisites
(GMF, EMF, etc. )? Try to install them manually step by step, if an
installation with all options fails.
Check the error log for output. Sometimes update sites cannot be parsed
(Faild to parse dictionary ...)
Currently I get an error trying to access the Preferences page of the SOA
Tools. I believe there's a dependency on the Web Tools Platform plugin
(WTP), but I am not sure.
Anyway I successfully installed STP on Eclipse Europa's first release on a
Windows XP machine.
So I guess currently several updated features interfere with each other
hardening the installation via Eclipse's integrated Update Manager.
I will report when I will succeed in the complete installation.
Good luck,
Emanuel
> errors:
> pre-reqs
> from
> pulling in
> the
> downloaded
> current problem.
> !SESSION 2007-10-01
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !SESSION 2007-10-01
> !SESSION 2007-10-01
> !STACK 0
> (java.lang.Error:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 34 more
> !STACK 0
> is invalid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 66 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> !STACK 0
> (java.lang.Error:
> cannot be resolved
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> cannot be resolved
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 34 more
> !STACK 0
> (java.lang.Error:
> cannot be resolved
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> cannot be resolved
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 34 more
> !STACK 0
> invalid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 66 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: Cannot access SOA Preferences pages [message #594001 is a reply to message #593992] Tue, 02 October 2007 09:31 Go to previous messageGo to next message
I did not load the JSR API plugin, from the download site I thought it was
part of the stp all in one zip file. Also, based on the website I was
assuming that the EMF, GMF, and etc. were also part of the all in one zip
file as well.
I will try the JSR API plugin and let you know how it works, but at this
point I think my problem has more to do with the 5 JUnit test issues
rather than a plugin missing.
I also had all of this setup and working in the first release of Europa,
however, the java2wsdl and wsdl2java would not work. That is why I
upgraded.
Scott
Re: Cannot access SOA Preferences pages [message #594012 is a reply to message #594001] Tue, 02 October 2007 16:13 Go to previous messageGo to next message
Tried the jsr plugin and the preferences pages for JAX-WS ans SCA still
are not displayed. See error in original post...Still thinking it is the
build...
Re: Cannot access SOA Preferences pages [message #594020 is a reply to message #594012] Wed, 03 October 2007 04:57 Go to previous messageGo to next message
> the build...
Yes, it's the build, sorry for this inconvenience. I published a new build to
the STP download site yesterday for people to work with in the interm.
If you take the SOAS / SC components from there, you should be able to
correctly set up the preferences page.
Adrian.
http://download.eclipse.org/stp/downloads/drops/I-I200710021 406-200710021406/
Re: Cannot access SOA Preferences pages [message #594048 is a reply to message #594020] Wed, 03 October 2007 16:53 Go to previous messageGo to next message
Adrian,
Did the following and thanks the preferences pages now work. However,
once I get the runtimes setup for either and both Apache CXF 2.0.x or
JaxWS RI 2.1.2 and I then try to create a JAX-WS Java First Project. I go
through the wizard and enter the project name then pick a server (Tried
both CXF and JaxWS RI) click the finish button and the new project dialog
won't close unless I click Cancel. It does create a project and I can go
through the rest of the tutorial and create the interface but the CXF or
JaxWS RI libraries are not added to the project as the tutorial video
shows for the 0.70 version. Checked the log and found the following error:
!ENTRY org.eclipse.ui 4 0 2007-10-03 16:38:31.692
!STACK 0
at
org.eclipse.stp.common.logging.LoggingProxy.error(LoggingPro xy.java:122)
at
org.eclipse.stp.sc.jaxws.wizards.ProjectWizardBase.performFi nish(ProjectWizardBase.java:81)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:742)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:373)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:616)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:227)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:182)
at
at
at
at
at
at
at
at
at
at
at
at
at
>> the build...
to
> Adrian.
Re: Cannot access SOA Preferences pages [message #594073 is a reply to message #594048] Thu, 04 October 2007 09:50 Go to previous messageGo to next message
Scott Selvia wrote:
> Adrian,
> go through the wizard and enter the project name then pick a server
> (Tried both CXF and JaxWS RI) click the finish button and the new
> project dialog won't close unless I click Cancel. It does create a
> project and I can go through the rest of the tutorial and create the
> interface but the CXF or JaxWS RI libraries are not added to the project
> as the tutorial video shows for the 0.70 version. Checked the log and
Looking into this now Scott.... I'll hopefully get back to you later today
with an update.
A.
Re: Cannot access SOA Preferences pages [message #594084 is a reply to message #594073] Thu, 04 October 2007 10:33 Go to previous messageGo to next message
Adrian,
Not trying to be a pain, but I found something else interesting:
I downloaded stp-all-in-one-I-I200710021406-200710021406.zip and extracted
that on top of the zip's from yesterday.
When I try to define a SOA Runtime I can select the server in this case
Apache CXF 2.0 and I can select the CXF Installation directory but the
"Finish" button is still greyed out.
Here is the stack trace:
!ENTRY org.eclipse.ui 4 0 2007-10-04 10:33:09.685
!STACK 0
java.lang.NoClassDefFoundError: org/eclipse/jdt/core/JavaModelException
at
org.eclipes.stp.soas.deploy.runtime.cxf.CxfRuntimePlugin.get CxfVersionHandler(CxfRuntimePlugin.java:50)
at
org.eclipes.stp.soas.deploy.runtime.cxf.core.internal.CxfRun time.getVersionHandler(CxfRuntime.java:42)
at
org.eclipes.stp.soas.deploy.runtime.cxf.core.internal.CxfRun time.verifyLocation(CxfRuntime.java:84)
at
org.eclipes.stp.soas.deploy.runtime.cxf.core.internal.CxfRun time.validate(CxfRuntime.java:92)
at org.eclipse.wst.server.core.internal.Runtime.validate(Runtim e.java:64)
at
org.eclipes.stp.soas.deploy.runtime.cxf.ui.internal.CxfRunti meComposite.validate(CxfRuntimeComposite.java:316)
at
org.eclipes.stp.soas.deploy.runtime.cxf.ui.internal.CxfRunti meComposite$2.modifyText(CxfRuntimeComposite.java:137)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:166)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:962)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:943)
at org.eclipse.swt.widgets.Text.wmCommandChild(Text.java:2366)
at org.eclipse.swt.widgets.Control.WM_COMMAND(Control.java:3801 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3675 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4351 )
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:217 9)
at org.eclipse.swt.widgets.Text.callWindowProc(Text.java:133)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3760 )
at org.eclipse.swt.widgets.Text.windowProc(Text.java:2013)
at org.eclipse.swt.internal.win32.OS.SetWindowTextW(Native Method)
at org.eclipse.swt.internal.win32.OS.SetWindowText(OS.java:3043 )
at org.eclipse.swt.widgets.Text.setText(Text.java:1804)
at
org.eclipes.stp.soas.deploy.runtime.cxf.ui.internal.CxfRunti meComposite$3.widgetSelected(CxfRuntimeComposite.java:153)
at
at
org.eclipse.wst.server.ui.internal.RuntimePreferencePage.sho wWizard(RuntimePreferencePage.java:357)
at
org.eclipse.stp.sc.common.internal.preferences.RuntimePrefer encePage.access$3(RuntimePreferencePage.java:1)
at
org.eclipse.stp.sc.common.internal.preferences.RuntimePrefer encePage$2.widgetSelected(RuntimePreferencePage.java:135)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
Scott
> Scott Selvia wrote:
>> Adrian,
> with an update.
> A.
Re: Cannot access SOA Preferences pages [message #594100 is a reply to message #594084] Thu, 04 October 2007 10:47 Go to previous messageGo to next message
Scott Selvia wrote:
> Adrian,
> extracted that on top of the zip's from yesterday.
Not being a pain at all Scott.
I suspect this is down to an issues that Chandra Jain reported last week with
a missing dependency. I've just put a commit in to fix it, kicking off a build
now, and it should be published shortly and I'll take it for a test again.
At this point I've lost all confidence in our build system though, it needs a
good hard look to see why it's publishing with some mistakes like this. I'll
post details of a fresh build shortly.
A.
Re: Cannot access SOA Preferences pages [message #594104 is a reply to message #594100] Thu, 04 October 2007 11:46 Go to previous messageGo to next message
> Scott Selvia wrote:
>> Adrian,
> with a missing dependency. I've just put a commit in to fix it, kicking
> off a build now, and it should be published shortly and I'll take it for
> a test again.
> needs a good hard look to see why it's publishing with some mistakes
> like this. I'll post details of a fresh build shortly.
> A.
Scott,
Just published a new build to [1]. Should fix that problem for you. This will
replicate over to the main download site in about 15 minutes or so.
Adrian.
[1] http://download.eclipse.org/stp/committers/drops/I-I20071004 1504-200710041504/
Re: Cannot access SOA Preferences pages [message #594118 is a reply to message #594104] Thu, 04 October 2007 13:10 Go to previous message
>> Scott Selvia wrote:
>>> Adrian,
>> week with a missing dependency. I've just put a commit in to fix it,
>> kicking off a build now, and it should be published shortly and I'll
>> A.
> Scott,
> will replicate over to the main download site in about 15 minutes or so.
> Adrian.
> [1]
Apologies for this guys, but that builds not the best so don't spend any time
with it, i've kicked of a new build and will follow on with more info shortly.
Adrian.
Previous Topic:Open BPMN model in main method
Next Topic:Re: Open BPMN model in main method
Current Time: Sat Jul 26 02:46:25 EDT 2025
Powered by FUDForum. Page generated in 0.11597 seconds
