Eclipse IDE Help Documentation [message #470853] |
Fri, 09 November 2007 13:04  |
Hi. I'm not sure if this is the best forum for this. If not, please
advise. I have two questions.
1. If I have specific suggestions about changes / improvements I'd like
to see in the Eclipse Help documentation (e.g., relating to JDT or the
general IDE), I assume I create a Bugzilla enhancement request. Is this
correct?
2. If I would like to help improve the Eclipse help documentation (e.g.,
by writing / editing help content), how do I get started and who do I
contact?
Thanks for your help.
Re: Eclipse IDE Help Documentation [message #470855 is a reply to message #470854] |
Fri, 09 November 2007 15:25  |
Chris Goldthorpe wrote:
> We would appreciate any bugs that you would file against the
> documentation since this is the part of Eclipse that gets least tested
> by developers. To do this open a bugzilla defect, if it is for the JDT
> select "Eclipse" then "JDT" when entering the component for the bug. If
> you want to write or improve an existing document that would also be
> appreciated. Starting with a Bugzilla bug would be a good way to do this
> also and indicate that you are offering to write the content, someone
> should reply to the bug and they can let you know what the procedure is.
>> like to see in the Eclipse Help documentation (e.g., relating to JDT
>> or the general IDE), I assume I create a Bugzilla enhancement request.
>> Is this correct?
>> (e.g., by writing / editing help content), how do I get started and
>> who do I contact?
Thanks. I'll do it right now.
Re: Eclipse IDE Help Documentation [message #593718 is a reply to message #470853] |
Fri, 09 November 2007 14:05  |
> correct?
> contact?
Re: Eclipse IDE Help Documentation [message #593726 is a reply to message #470854] |
>> Is this correct?
>> who do I contact?
FUDForum. Page generated in 0.17537 seconds
