| What's wrong with the RCP help system ? [message #470571] |
Tue, 30 October 2007 09:16  |
I'm using the new jetty-based RCP-Help-system since spring 2007. I
followed all those threads about 404 errors because I had them too.
After all I got it to work.
But now it seems to be broken again - without manipulating any help
based ressource.
I get the following error in the runtime workbench as as well as in the
exported product:
HTTP ERROR: 404
ProxyServlet: /help/index.jsp
RequestURI=/help/index.jsp
Powered by Jetty://
This happens when opening the external help-browser (Help Contents).
When I use the helpview I can see my contributed tocs but I get the 404
when I try to follow a link from there.
My error log always stays clean.
What makes me wonder is, that the IDE-help works and my product help
does not.
I found a post which relates to the old tomcat and apache.commons.logging:
http://dev.eclipse.org/mhonarc/newsLists/news.eclipse.newcom er/msg08657.html
which says that multiple commons.logging-jars break tomcat.
This could be related to me, because the only thing I changed was an
implementation with apache-fop into my application which comes with
commons.logging too.
I compared my exported plugins with them from the svn when help worked -
without any difference.
Anyway here are my plugins:
*** Plug-in Registry:
com.ibm.icu (3.6.1.v20070417) "International Components for Unicode for
Java (ICU4J)" [Active]
de.tragwerk.core (1.1.0) "Core" [Active]
de.tragwerk.core.license (1.1.0) "Shared Library License" [Resolved]
de.tragwerk.core.license.customer (1.1.0) "License-Library Customer"
[Resolved]
de.tragwerk.solution (1.1.0) "Solution Platform" [Active]
de.tragwerk.solution.model (1.1.0) "Solution Models" [Resolved]
de.tragwerk.solution.module.comingag.topfloor (1.1.0) "Com-Ing AG
Topfloor" [Starting]
de.tragwerk.solution.module.comingag.topfloor.model (1.1.0) "Com-Ing AG
Topfloor Model" [Resolved]
de.tragwerk.solution.module.tw.knickenHerzog (1.1.0) "TW Knicken Herzog"
[Starting]
de.tragwerk.solution.module.tw.knickenHerzog.model (1.1.0) "TW Knicken
Herzog Model" [Resolved]
de.tragwerk.xtrn.commons (1.1.0) "Commons Plug-in" [Active]
de.tragwerk.xtrn.fop (1.1.0) "Apache Fop Plug-in" [Starting]
de.tragwerk.xtrn.hsqldb (1.1.0) "HSQLDB" [Active]
de.tragwerk.xtrn.nebula (1.1.0) "Nebula Plug-in" [Starting]
de.tragwerk.xtrn.saxon (1.1.0) "Saxon Plug-in" [Resolved]
de.tragwerk.xtrn.toplink (1.1.0) "Toplink Plug-in" [Resolved]
javax.servlet (2.4.0.v200706111738) "Servlet API Bundle" [Resolved]
javax.servlet.jsp (2.0.0.v200706191603) "Java Server Pages API Bundle"
[Resolved]
org.apache.commons.el (1.0.0.v200706111724) "Apache Commons JSP 2.0
Expression Language Interpreter" [Resolved]
org.apache.commons.logging (1.0.4.v200706111724) "Apache Commons Logging
Plug-in" [Resolved]
org.apache.jasper (5.5.17.v200706111724) "Apache Jasper 2 Plug-in"
[Resolved]
org.apache.lucene (1.9.1.v200706111724) "Apache Lucene" [Resolved]
org.apache.lucene.analysis (1.9.1.v200706181610) "Apache Lucene
Analysis" [Resolved]
org.eclipse.core.commands (3.3.0.I20070605-0010) "Commands" [Resolved]
org.eclipse.core.contenttype (3.2.100.v20070319) "Eclipse Content
Mechanism" [Starting]
org.eclipse.core.databinding (1.0.0.I20070606-0010) "JFace Data Binding"
[Resolved]
org.eclipse.core.databinding.beans (1.0.0.I20070606-0010) "JFace Data
Binding for JavaBeans" [Resolved]
org.eclipse.core.expressions (3.3.0.v20070606-0010) "Expression
Language" [Active]
org.eclipse.core.jobs (3.3.0.v20070423) "Eclipse Jobs Mechanism" [Active]
org.eclipse.core.runtime (3.3.100.v20070530) "Core Runtime" [Active]
org.eclipse.core.runtime.compatibility.auth (3.2.100.v20070502)
"Authorization Compatibility Plug-in" [Active]
org.eclipse.equinox.app (1.0.0.v20070606) "Equinox Application
Container" [Active]
org.eclipse.equinox.common (3.3.0.v20070426) "Common Eclipse Runtime"
[Active]
org.eclipse.equinox.http.jetty (1.0.0.v20070607) "Jetty Http Service"
[Starting]
org.eclipse.equinox.http.registry (1.0.0.v20070608) "Http Service
Registry Extensions" [Resolved]
org.eclipse.equinox.http.servlet (1.0.0.v20070606) "Http Services
Servlet" [Starting]
org.eclipse.equinox.jsp.jasper (1.0.0.v20070607) "Jasper Jsp Support
Bundle" [Starting]
org.eclipse.equinox.jsp.jasper.registry (1.0.0.v20070607) "Jasper Jsp
Registry Support Plug-in" [Starting]
org.eclipse.equinox.launcher (1.0.0.v20070606) "Equinox Launcher" [Resolved]
org.eclipse.equinox.launcher.win32.win32.x86 (1.0.0.v20070523) "Equinox
Launcher Win32 X86 Fragment" [Resolved]
org.eclipse.equinox.preferences (3.2.100.v20070522) "Eclipse Preferences
Mechanism" [Active]
org.eclipse.equinox.registry (3.3.0.v20070522) "Extension Registry
Support" [Active]
org.eclipse.help (3.3.0.v20070524) "Help System Core" [Active]
org.eclipse.help.appserver (3.1.200.v20070510) "Help Application Server"
[Starting]
org.eclipse.help.base (3.3.0.v20070606) "Help System Base" [Starting]
org.eclipse.help.ui (3.3.0.v20070530) "Help System UI" [Starting]
org.eclipse.jface (3.3.0.I20070606-0010) "JFace" [Active]
org.eclipse.jface.databinding (1.1.0.I20070606-0010) "JFace Data Binding
for SWT and JFace" [Resolved]
org.eclipse.osgi (3.3.0.v20070530) "OSGi System Bundle" [Active]
org.eclipse.osgi.services (3.1.200.v20070605) "OSGi Release 4.0.1
Services" [Resolved]
org.eclipse.rcp (3.2.0.v20070612) "Eclipse RCP" [Starting]
org.eclipse.swt (3.3.0.v3346) "Standard Widget Toolkit" [Resolved]
org.eclipse.swt.win32.win32.x86 (3.3.0.v3346) "Standard Widget Toolkit
for Windows" [Resolved]
org.eclipse.ui (3.3.0.I20070614-0800) "Eclipse UI" [Active]
org.eclipse.ui.forms (3.3.0.v20070511) "Eclipse Forms" [Active]
org.eclipse.ui.intro (3.2.100.v20070530) "Welcome Framework" [Active]
org.eclipse.ui.intro.universal (3.2.100.v20070530A) "Universal Welcome"
[Active]
org.eclipse.ui.navigator (3.3.0.I20070605-0010) "Common Navigator View"
[Active]
org.eclipse.ui.views (3.2.100.I20070319-0010) "Views" [Active]
org.eclipse.ui.views.properties.tabbed (3.3.0.I20070605-0010) "Tabbed
Properties View" [Starting]
org.eclipse.ui.workbench (3.3.0.I20070608-1100) "Workbench" [Active]
org.eclipse.update.configurator (3.2.100.v20070615) "Install/Update
Configurator" [Active]
org.mortbay.jetty (5.1.11.v200706111724) "Jetty WebServer" [Resolved]
Sebastian
FUDForum. Page generated in 1.34735 seconds
