Home » Eclipse Projects » Dali » Dali Installation
Dali Installation [message #434355] Fri, 30 March 2007 08:03 Go to next message
I can't get Dali working. According to the tutorial you need WTP which
contains Dali. I am using wtp-all-in-one-sdk-R-1.5.3. But I can't see
the Persistence Perspective or JPA Structure / JPA Details View.
What is wrong?
Gereon
Re: Dali Installation [message #434359 is a reply to message #434355] Sat, 31 March 2007 16:32 Go to previous messageGo to next message
Gereon Fassbender wrote:
> Hello,
> What is wrong?
Try the latest WTP2.0m5 and it should do the trick. It worked for me,
but I'm using Eclipse 3.3m5 and such a version was the only one
available for it.
Jacek
Jacek Laskowski
http://www.JacekLaskowski.pl
Re: Dali Installation [message #434362 is a reply to message #434355] Mon, 02 April 2007 11:28 Go to previous messageGo to next message
In WTP 1.5, Dali was not actually packaged with WTP, but was made
available as a separate download. If you are using WTP 1.5.x, use the
Dali plugins found here -
http://download.eclipse.org/webtools/jpa/downloads/drops/R-0 .5-200606282232/.
Also make sure you have the appropriate WTP prereqs installed. That
should do it.
Neil
> Hello,
> What is wrong?
> Gereon
Re: Dali Installation [message #434364 is a reply to message #434362] Mon, 02 April 2007 12:46 Go to previous message
Hello Jacek, hello Neil,
thanks for your help! I tried wtp-sdk-S-2.0M5-200702230758.zip now and
it worked. It was a bit confusing that it still didn't contained Dali.
But I found the separate wtp-jpa-sdk download which did.
Gereon
> should do it.
> Neil
>> Hello,
>> What is wrong?
>> Thanks,
>> Gereon
Re: Dali Installation [message #593353 is a reply to message #434355] Sat, 31 March 2007 16:32 Go to previous message
> Hello,
> What is wrong?
available for it.
Jacek
Jacek Laskowski
Re: Dali Installation [message #593377 is a reply to message #434355] Mon, 02 April 2007 11:28 Go to previous message
should do it.
Neil
> Hello,
> What is wrong?
> Gereon
Re: Dali Installation [message #593389 is a reply to message #434362] Mon, 02 April 2007 12:46 Go to previous message
Gereon
> should do it.
> Neil
>> Hello,
>> What is wrong?
>> Thanks,
>> Gereon
Previous Topic:Attribute Names in Generated EJB
Next Topic:Basic architecture question
Current Time: Fri Jul 25 06:27:57 EDT 2025
Powered by FUDForum. Page generated in 0.08344 seconds
