Home » Archived » XML Schema Definition (XSD) » attribute reference unresolved - must be basic answer
| attribute reference unresolved - must be basic answer [message #59230] |
Wed, 20 April 2005 10:54  |
Originally posted by: spam.no-thanks.org
during installation of the eclipse subversion plugin, I 'inherited' the
XSD plugin too. Now my eclipse 'problems' list is showing errors in
schemas in my project.
I have googled and searched this mailing list without finding a
solution. Perhaps someone can recognise what basic mistake I'm making -
and I'm sure it must be basic :(
XSD: Attribute reference 'http://www.w3.org/XML/1998/namespace#lang' is
unresolved
comes from this line of schema:
<xs:attribute ref="xml:lang" default="en"/>
which imports the schema mentioned in the error msg like so:
<xs:import namespace="http://www.w3.org/XML/1998/namespace"
schemaLocation="http://www.w3.org/2001/xml.xsd"/>
I have actually downloaded the xml.xsd schema and placed it in the same
directory, and I have this directory loaded as a class folder resource
in the .classpath for my project like so:
<classpathentry kind="lib" path="docs/Design/schemas"/>
Adam
| Re: attribute reference unresolved - must be basic answer [message #59736 is a reply to message #59713] |
Tue, 26 April 2005 11:24   |
Adam,
When you open the editor, the editor will validate your schema. When I
try a sample schema with your example in it, I don't get errors, so I
can't reproduce the problem. You'll just have to take my word for the
fact that I've not written anything that will automatically validate the
schema as part of a build and that I know nothing about that. If you
want to send a complete schema example for me to try, I can do that...
adam wrote:
> OK, truth is, I can work fine with the schema, but these errors in
> Eclipse (which seem to be invalid) are bugging me. I would like to get
> rid of them without filtering out errors XML errors.
> There are warnings too:
> XSD: The location 'http://www.w3.org/2001/xml.xsd' has not been
> resolved
> I can't see from looking in the help why XSD is outputting any errors
> or warnings at all or what exactly Eclipse is doing when it finds .xsd
> files while building the project.
> Eclipse has associated .xsd file with the Sample XSD Editor and
> looking at the schema, Ecilpse shows the warnings and errors at the
> appropriate lines.
> This seems to contradict your statement about XSD providing no
> autmoated validator, surely?
> Adam
> Ed Merks wrote:
>> That's certainly a message created by the XSD model, but XSD provides
>> no automated validator that produces this message. Opening a .xsd
>> with the Sample XML Schema Editor will do such validation, but when I
>> try to do that with your example, it works fine. Have you tried
>> opening the example with the Sample editor provided by XSD?
>> adam wrote:
>>> But it's an XSD error in my Eclipse 'Problems' view with the text:
>>> is unresolved
>>> Is this not the XSD plugin in action?
| Re: attribute reference unresolved - must be basic answer [message #60094 is a reply to message #60070] |
Thu, 28 April 2005 07:49   |
Adam,
You mentioned "the eclipse subversion" plugin. I would assume that
"they" are providing this behavior. I am certainly willing to try out
your schemas (feel free to send them directly to my e-mail) but I can do
little about the way other plugins use XSD, so your question should
really be directed to the folks who implemented this automatic
validation support. It's sometimes the case that a schema in isolation
is invalid but when included in some context becomes valid, or vice
versa, so simply validating schemas by scanning for them and validating
each separately is a design with some issues... Your problem really
sounds like an inability to fetch the schema from the http location...
adam wrote:
> Ed,
> I totally believe you when you say you didn't code it, but what I am
> trying to elucidate is why it is doing that validation OR why it isn't
> including the other schemas as it should when it does validate.
> Unfortunately I am completely in the dark about the way that Eclipse
> is behaving and I'm hoping to get the info from you or someone here!
> Do you think I would have more success on the eclipse user list?
> Id gladly send you the complete schema set just to test it quickly but
> I think the problem is probably not with the schema. My email address
> (once you remove the anti-spam bits) is
> adam dot hardy :) bbc dot co dot uk
> Thanks!
> Ed Merks wrote:
>> Adam,
>> I try a sample schema with your example in it, I don't get errors, so
>> I can't reproduce the problem. You'll just have to take my word for
>> the fact that I've not written anything that will automatically
>> validate the schema as part of a build and that I know nothing about
>> that. If you want to send a complete schema example for me to try, I
>> can do that...
| Re: attribute reference unresolved - must be basic answer [message #60142 is a reply to message #60118] |
Thu, 28 April 2005 09:02   |
Adam,
Did you disable the XSD plugin as well? A bundleentry scheme is
Eclipse's way to referencing something in an installed plugin. XSD uses
this access the cached schemas...
adam wrote:
> OK, Ed, I just disabled the subversion plugin.
> I then cleaned my project and got all problem entries to disappear. I
> then opened one of my schemas, and Eclipse gave me the progress bar
> with the status message "bundleentry://169/ xxxxxxx" and then it
> failed and showed the XSD errors.
> I didn't recognise the URL in the status message, not even the protocol!
> Does this tell you anything?
> Thanks
> Adam
> Ed Merks wrote:
>> Adam,
>> out your schemas (feel free to send them directly to my e-mail) but I
>> can do little about the way other plugins use XSD, so your question
>> should really be directed to the folks who implemented this automatic
>> isolation is invalid but when included in some context becomes valid,
>> or vice versa, so simply validating schemas by scanning for them and
>> validating each separately is a design with some issues... Your
>> problem really sounds like an inability to fetch the schema from the
>> http location...
| Re: attribute reference unresolved - must be basic answer [message #60165 is a reply to message #60142] |
Thu, 28 April 2005 09:49  |
I just disabled Subversion. I didn't see any way in the 'Product
Configuration' menu to disable XSD. Right from the start I could have
just removed the xsd plugin, but I was kind of hoping I would get some
benefit from it later.
I got rid of XMLSpy on the basis that it was a memory hog and not open
source, and then I discovered that the xsd plugin had the editor. Did
those schemas arrive again properly?
Ed Merks wrote:
> Adam,
| Re: attribute reference unresolved - must be basic answer [message #594779 is a reply to message #59230] |
Wed, 20 April 2005 14:49  |
Adam,
I tried this in a sample and it loaded fine. It sure looks correct.
Maybe the problem is that your application doesn't have access to the
web in order to load the schema...
adam wrote:
> the XSD plugin too. Now my eclipse 'problems' list is showing errors
> in schemas in my project.
> - and I'm sure it must be basic :(
> is unresolved
> same directory, and I have this directory loaded as a class folder
> resource in the .classpath for my project like so:
> Thanks
> Adam
| Re: attribute reference unresolved - must be basic answer [message #594805 is a reply to message #59282] |
Thu, 21 April 2005 07:31  |
Hi Ed,
I'm definitely online all the time - but I do have a firewall - what
protocol does the import use? If it's HTTP then there's no problem. I
know I have problems with stuff like instant messenger.
How can I force a try in Eclipse? Will a refresh do it?
Adam
Ed Merks wrote:
> Adam,
| Re: attribute reference unresolved - must be basic answer [message #594816 is a reply to message #59336] |
Thu, 21 April 2005 07:41  |
Adam,
Your schema location was http.
I'm really not sure what's doing causing your schema to be validated
automatically (XSD doesn't provide such support) nor what would make it
try again. Certainly changing the time stamp of the file and refreshing
should do the trick...
adam wrote:
> Hi Ed,
> Adam
> Ed Merks wrote:
>> Adam,
| Re: attribute reference unresolved - must be basic answer [message #594941 is a reply to message #59597] |
Mon, 25 April 2005 16:27  |
Adam,
That's certainly a message created by the XSD model, but XSD provides no
automated validator that produces this message. Opening a .xsd with the
Sample XML Schema Editor will do such validation, but when I try to do
that with your example, it works fine. Have you tried opening the
> is unresolved
> Ed Merks wrote:
>> Adam,
>> it try again. Certainly changing the time stamp of the file and
>> refreshing should do the trick...
| Re: attribute reference unresolved - must be basic answer [message #594985 is a reply to message #59619] |
Tue, 26 April 2005 08:40  |
XSD: The location 'http://www.w3.org/2001/xml.xsd' has not been resolved
I can't see from looking in the help why XSD is outputting any errors or
Eclipse has associated .xsd file with the Sample XSD Editor and looking
at the schema, Ecilpse shows the warnings and errors at the appropriate
lines.
This seems to contradict your statement about XSD providing no autmoated
validator, surely?
Adam
>> is unresolved
| Re: attribute reference unresolved - must be basic answer [message #594992 is a reply to message #59713] |
Adam,
> resolved
> appropriate lines.
> Adam
>>> is unresolved
| Re: attribute reference unresolved - must be basic answer [message #595141 is a reply to message #59736] |
Thu, 28 April 2005 07:17  |
Ed,
Unfortunately I am completely in the dark about the way that Eclipse is
behaving and I'm hoping to get the info from you or someone here! Do you
Id gladly send you the complete schema set just to test it quickly but I
Thanks!
Ed Merks wrote:
> Adam,
| Re: attribute reference unresolved - must be basic answer [message #595152 is a reply to message #60070] |
Adam,
adam wrote:
> Ed,
> Thanks!
> Ed Merks wrote:
>> Adam,
>> can do that...
| Re: attribute reference unresolved - must be basic answer [message #595163 is a reply to message #60094] |
Thu, 28 April 2005 08:56  |
then opened one of my schemas, and Eclipse gave me the progress bar with
the status message "bundleentry://169/ xxxxxxx" and then it failed and
Adam
Ed Merks wrote:
> Adam,
| Re: attribute reference unresolved - must be basic answer [message #595167 is a reply to message #60118] |
Adam,
> Thanks
> Adam
> Ed Merks wrote:
>> Adam,
>> http location...
| Re: attribute reference unresolved - must be basic answer [message #595177 is a reply to message #60142] |
Ed Merks wrote:
> Adam,
Current Time: Mon Nov 03 06:22:13 EST 2025
Powered by FUDForum. Page generated in 0.25548 seconds
