Home » Language IDEs » AspectJ » Eclipse 3.2M6
Eclipse 3.2M6 [message #63557] Mon, 03 April 2006 10:53 Go to next message
Support for Eclipse 3.2M6 is now available with the latest development
build of AJDT (build id 1.4.0.20060403091136 or later). This is available
via the 3.2 dev Update Site:
http://download.eclipse.org/technology/ajdt/32/dev/update
or as a zip file from the downloads page:
http://www.eclipse.org/ajdt/downloads/
Please report any bugs as usual.
Matt.
Re: Eclipse 3.2M6 [message #63923 is a reply to message #63557] Wed, 05 April 2006 12:06 Go to previous messageGo to next message
Originally posted by: vranganath.sbcglobal.net
I had raised this issue earlier (bug report #131012) -- "AspectJ Tool"
menu is missing in the pop-up menu for projects in the Package Explorer in
3.2M5a. This persists in 3.2M6 as well. Can others confirm this
behavior? If confirmed, it would be great if the AJDT team could address
this as "__generated_src" folder is created for every project in the
workspace. If others are able to view the menu then any suggestions about
how to fix this anomaly?
- Venkatesh Prasad Ranganath
> Matt.
Re: Eclipse 3.2M6 [message #63993 is a reply to message #63923] Thu, 06 April 2006 03:56 Go to previous messageGo to next message
Originally posted by: hawkinsh.uk.ibm.com
Hi Venkatesh,
I have Eclipse 3.2M6 with AJDT build 1.4.0.20060403091136. When I right
click on both a java project and an aspectj project there is an "AspectJ
Tools" entry on the context menu. The only other time this entry appears
on the context menu is when a class or aspect is selected in an AspectJ
project. I believe this is the expected behaviour. Your post was a little
unclear - what are you selecting in the package explorer when you expect
to see the "AspectJ Tools" context menu entry? Also, I'm not sure I
understand your reference to "_generated_src" folder.
Thanks, Helen
Re: Eclipse 3.2M6 [message #64016 is a reply to message #63993] Thu, 06 April 2006 14:30 Go to previous messageGo to next message
On Thu, 06 Apr 2006 07:56:08 +0000, Helen Hawkins wrote:
> Hi Venkatesh,
I'm selecting the project in the package explorer. Even more interesting is
that all aspectj related properties are visible when I view the properties
of a Java project.
AspectJ related sources are configured to be dumped into __generated_src
folder. Interestingly, all Java projects have this folder. I'm guessing
this and the above issue is because "aspectj" nature is enabled on these
projects. The question is how do disable it without having access to
"AspectJ Tools" menu?
Venkatesh Prasad Ranganath,
Dept. Computing and Information Science,
Kansas State University, US.
web: http://www.cis.ksu.edu/~rvprasad
Re: Eclipse 3.2M6 [message #64039 is a reply to message #64016] Thu, 06 April 2006 16:19 Go to previous messageGo to next message
Originally posted by: eclipse.codex.NOSPAM.de
On Thu, 06 Apr 2006 13:30:29 -0500, Venkatesh Prasad Ranganath
>> Hi Venkatesh,
>of a Java project.
Do you have WTP installed? Maybe you ran into
https://bugs.eclipse.org/bugs/show_bug.cgi?id=130571
Michael
Re: Eclipse 3.2M6 [message #64062 is a reply to message #64039] Thu, 06 April 2006 17:52 Go to previous message
>>> Hi Venkatesh,
>>of a Java project.
I believe that's it.
Re: Eclipse 3.2M6 [message #593145 is a reply to message #63557] Wed, 05 April 2006 12:06 Go to previous message
> Matt.
Re: Eclipse 3.2M6 [message #593189 is a reply to message #63923] Thu, 06 April 2006 03:56 Go to previous message
Hi Venkatesh,
Thanks, Helen
Re: Eclipse 3.2M6 [message #593201 is a reply to message #63993] Thu, 06 April 2006 14:30 Go to previous message
> Hi Venkatesh,
of a Java project.
Re: Eclipse 3.2M6 [message #593210 is a reply to message #64016] Thu, 06 April 2006 16:19 Go to previous message
>> Hi Venkatesh,
>of a Java project.
Michael
Re: Eclipse 3.2M6 [message #593220 is a reply to message #64039] Thu, 06 April 2006 17:52 Go to previous message
>>> Hi Venkatesh,
>>of a Java project.
Previous Topic:RAD 6.0 (eclipse 3.0) with / AJDT 1.2.1 & AspectJ 1.5.1
Next Topic:AJDT 1.3.1 Release Candidate
Current Time: Mon Oct 20 00:11:43 EDT 2025
Powered by FUDForum. Page generated in 0.06078 seconds
