Home » Modeling » Epsilon » Problems declaring a Float variable
Problems declaring a Float variable [message #552634] Thu, 12 August 2010 17:57 Go to next message
I try to declare a float variable as follows:
var workload : Float = 0.0;
I get the following error message:
Type 'Float' not found
Hallvard
Re: Problems declaring a Float variable [message #552685 is a reply to message #552634] Fri, 13 August 2010 03:53 Go to previous messageGo to next message
Hi Hallvard,
EOL defines four primitive types: Boolean, String, Integer and Real. The latter should be used for representing floating point numbers.
There's some more information about EOL's types in Section 3.3 of the Epsilon book, here: http://www.eclipse.org/gmt/epsilon/doc/book
Louis.
Re: Problems declaring a Float variable [message #552733 is a reply to message #552685] Fri, 13 August 2010 05:59 Go to previous messageGo to next message
On 13.08.10 09.53, Louis Rose wrote:
> Hi Hallvard,
OK. It's confusing that the 'Float' literal is colored green, so it
looks like it's recognized as a valid type.
Hallvard
Re: Problems declaring a Float variable [message #554192 is a reply to message #552733] Fri, 20 August 2010 09:31 Go to previous message
Hi Hallvard,
Yes, I can see why the syntax highlighting of Float and Double would be confusing! I've opened the following bug to cover this, and will fix the syntax highlighting now:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=323248
Thanks for reporting this.
Louis.
Re: Problems declaring a Float variable [message #593052 is a reply to message #552634] Fri, 13 August 2010 03:53 Go to previous message
Hi Hallvard,
Louis.
Re: Problems declaring a Float variable [message #593078 is a reply to message #593052] Fri, 13 August 2010 05:59 Go to previous message
> Hi Hallvard,
Hallvard
Re: Problems declaring a Float variable [message #593089 is a reply to message #552733] Fri, 20 August 2010 09:31 Go to previous message
Hi Hallvard,
Louis.
Previous Topic:Problems declaring a Float variable
Next Topic:[HUTN] Syntax for EDataType values
Current Time: Sat Jul 26 21:09:38 EDT 2025
Powered by FUDForum. Page generated in 0.04236 seconds
