Problems with SCA HelloWorld example. [message #374216] |
Tue, 28 August 2007 11:34  |
I've been trying to build the HelloWorld RMI demo on Europa.
http://www.eclipse.org/stp/sc/demos/sca_rmi_movie.swf
Most of my problems (annotations and classpaths) have been down to the
fact that I've been getting my STP plugins from the stp update site:
http://download.eclipse.org/stp/updates/
If, instead, I drop the contents of:
http://www.eclipse.org/downloads/download.php?file=/stp/down loads/drops/I-I200707260606-200707260606/stp-all-in-one-I-I2 00707260606-200707260606.zip
onto a fresh copy eclipse-SDK-3.3-win32 everything proceeds as per the demo.
My problem now is that when I try running up the HelloWorld server as
per the demo I get the following error:
org.apache.tuscany.spi.loader.UnrecognizedElementException:
{http://incubator.apache.org/tuscany/xmlns/binding/rmi/1.0-i ncubator-M2}binding.rmi
[ {http://incubator.apache.org/tuscany/xmlns/binding/rmi/1.0-i ncubator-M2}binding.rmi]
Context stack trace: [application]
at
org.apache.tuscany.core.loader.LoaderRegistryImpl.load(Loade rRegistryImpl.java:90)
at org.apache.tuscany.core.loader.ServiceLoader.load(ServiceLoa der.java:84)
at org.apache.tuscany.core.loader.ServiceLoader.load(ServiceLoa der.java:51)
at
org.apache.tuscany.core.loader.LoaderRegistryImpl.load(Loade rRegistryImpl.java:92)
at
org.apache.tuscany.core.implementation.composite.CompositeLo ader.load(CompositeLoader.java:81)
at
org.apache.tuscany.core.implementation.composite.CompositeLo ader.load(CompositeLoader.java:55)
at
at
org.apache.tuscany.core.loader.LoaderRegistryImpl.load(Loade rRegistryImpl.java:109)
at
org.apache.tuscany.core.implementation.composite.CompositeCo mponentTypeLoader.loadFromSidefile(CompositeComponentTypeLoa der.java:65)
at
org.apache.tuscany.core.implementation.composite.CompositeCo mponentTypeLoader.load(CompositeComponentTypeLoader.java:57)
at
org.apache.tuscany.core.implementation.composite.CompositeCo mponentTypeLoader.load(CompositeComponentTypeLoader.java:39)
at
org.apache.tuscany.core.loader.LoaderRegistryImpl.loadCompon entType(LoaderRegistryImpl.java:159)
at
org.apache.tuscany.core.deployer.DeployerImpl.load(DeployerI mpl.java:101)
at
org.apache.tuscany.core.deployer.DeployerImpl.deploy(Deploye rImpl.java:76)
at
org.apache.tuscany.core.runtime.AbstractRuntime.deployApplic ationScdl(AbstractRuntime.java:136)
at
org.apache.tuscany.runtime.standalone.host.StandaloneRuntime Impl.initialize(StandaloneRuntimeImpl.java:87)
at
org.apache.tuscany.launcher.MainLauncherBooter.main(MainLaun cherBooter.java:83)
Exception in thread "main" java.lang.NullPointerException
at
org.apache.tuscany.launcher.MainLauncherBooter.main(MainLaun cherBooter.java:90)
Any suggestions would be appreciated.
Thanks, Steve.
Re: Problems with SCA HelloWorld example. [message #374222 is a reply to message #374216] |
Fri, 14 September 2007 02:31  |
Hi Steve,
Which SCA runtime are you using?
The one with Europa release only supports tuscany 1.0M1, which was released
last year.
We have updated the sca integration to support tuscany sca java 0.91, which
is based on sca 1.0 spec.
We plan to release the stp 0.7.0 M1 release next Friday.
Johnson
"Steve Jones" <steve@istech.demon.co.uk> wrote in message
news:fb1f9c$lqs$1@build.eclipse.org...
> demo.
> My problem now is that when I try running up the HelloWorld server as per
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks, Steve.
Re: Problems with SCA HelloWorld example. [message #593038 is a reply to message #374216] |
Hi Steve,
last year.
Johnson
> demo.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Thanks, Steve.
FUDForum. Page generated in 0.29093 seconds
