Home » Language IDEs » AspectJ » J2ME
J2ME [message #62477] Fri, 03 March 2006 21:09 Go to next message
Originally posted by: hunt2.cs.clemson.edu
I am having difficulty getting aspectj to work with a J2ME project. I
have tried a number of ways. The way that came the closest was:
Start with a working J2ME project
Right click on project and select convert to aspectj project
The result seems to build correctly.
If I run the J2ME code without making changes it comes up correctly in the
emulator.
If a create a sample aspectj app in the same project as the J2ME code, it
builds and runs correctly.
BUT, when I add an aspect to my J2ME code it:
Builds although it does indicate a problem with the project by showing a
red X on the project folder, but does not flag any of the files making up
the project with an X.
It runs the app in the emulator.
It recognizes a match specified by the pointcut.
When it attempts to execute the advice associated with the pointcut it
gives a runtime error:
java.lang.NoClassDefFoundError: org/aspectj/lang/NoAspectBoundException
Interestingly if I leave the pointcut but comment out the advice the
application runs fine in the emulator.
This is creating a major crimp in progress on my dissertation. Would
greatly appreciate advice on how to get J2ME and AspectJ to work together
in Eclipse.
BTW: I updated all the Eclipse packages in my enviroment yesterday. So I
believe I am latest and greatest for my Eclipse environment
Re: J2ME [message #62542 is a reply to message #62477] Sat, 04 March 2006 04:29 Go to previous messageGo to next message
Originally posted by: clemas.uk.ibm.com
Hello John,
Code built with the AspectJ compiler has a dependency on the
aspectjrt.jar file. This contains some classes that support the runtime
operation of the aspect - for example the NoAspectBoundException you are
seeing. You must ensure this runtime jar is available in the
environment where you execute the application.
Now ... we know there are certain issues with the current aspectjrt.jar
classes where they use some types not available in certain J2ME
environments (for example, cflow support may need ThreadLocal). Please
see https://bugs.eclipse.org/bugs/show_bug.cgi?id=92933 for more
discussion on it.
Also... the latest aspectjrt.jar shipped with Java5 is quite large - we
are looking to ship multiple variants depending on the target
environment as much of the contents probably supports features you
aren't using (eg. reflection support for AspectJ code). We just haven't
done it yet.
Andy.
> have tried a number of ways. The way that came the closest was: Start
> the emulator.
> it builds and runs correctly.
> up the project with an X.
> gives a runtime error: java.lang.NoClassDefFoundError:
> together in Eclipse.
> I believe I am latest and greatest for my Eclipse environment
Re: J2ME [message #62566 is a reply to message #62542] Sat, 04 March 2006 17:17 Go to previous message
Thanks so much Andy. You are quite right. So it is, basically, a
classpath problem. I have it a bit easier than most in that I can live
with it working in emulation, and don't care much about memory (its a long
story). So my ultimate fix is to change the run configuration on the
emulation tab to add an extra emulator parameter of "-classpath
c:\aspectj1.5\lib\aspectjrt.jar"
I don't think I would have gotten this with out help.
So thanks again.
John
Re: J2ME [message #592463 is a reply to message #62477] Sat, 04 March 2006 04:29 Go to previous message
Hello John,
discussion on it.
done it yet.
Andy.
> the emulator.
Re: J2ME [message #592474 is a reply to message #62542] Sat, 04 March 2006 17:17 Go to previous message
So thanks again.
John
Previous Topic:Using weaved plugin in eclipse
Next Topic:Using weaved plugin in eclipse
Current Time: Fri Sep 19 01:51:07 EDT 2025
Powered by FUDForum. Page generated in 0.06077 seconds
