Home » Language IDEs » AspectJ » around advice question
around advice question [message #61290] Tue, 24 January 2006 11:40 Go to next message
I'm testing the usage of Aspectj and encountered a problem.
I wrote the following code:
public aspect myAspect{
pointcut publicMethods() : execution(public * myMain.func(..));
pointcut logObjectCalls() : execution(* Logger.*(..));
pointcut loggableCalls() : publicMethods(); //l&& ! logObjectCalls();
before() : loggableCalls(){
Logger.entry(thisJoinPoint.getSignature().toString());
after() : loggableCalls(){
Logger.exit(thisJoinPoint.getSignature().toString());
void around(): call(public void myMain.func(String)){
if(Math.random() > .5){
System.out.println("> 0.5");
proceed(); //go ahead with the method call
else{
System.out.println("< 0.5");
The function FUNC of MYMAIN class has only one argument which is of String
type.
What I would like to achieve is that I will be able to check the input
parameters in the AROUND advice.
Thanks in advance,
Asaf Lahav
Re: around advice question [message #61345 is a reply to message #61290] Wed, 25 January 2006 10:35 Go to previous messageGo to next message
Hi Asaf,
My first attempt at an AspectJ solution, so hopefully this is right!
Think what looking for is the args designator. Heres a snip for you
public class AnObject {
public String doSomethingStringy (String string){
return string+"added by method";
public static void main(String[] args){
AnObject obj = new AnObject();
System.out.println(obj.doSomethingStringy("Original"));
public aspect AnAspect {
pointcut effectDoSomething(String string) : call(public String
AnObject.doSomethingStringy (String)) && args(string);
String around(String string) : effectDoSomething(string){
string = string+" added before ";
string = proceed(string);
string = string+" added after";
return string;
Outputs:
Original added before added by method added after
As you can see this makes the parameters availible in your advice block
for manipulation/testing. Hopfully thats what your looking for!
Enjoy
Tom
Re: around advice question [message #61369 is a reply to message #61345] Thu, 26 January 2006 03:54 Go to previous message
Thanks tom...
it helped allot.
Re: around advice question [message #591978 is a reply to message #61290] Wed, 25 January 2006 10:35 Go to previous message
Hi Asaf,
return string;
Outputs:
Enjoy
Tom
Re: around advice question [message #591982 is a reply to message #61345] Thu, 26 January 2006 03:54 Go to previous message
Thanks tom...
it helped allot.
Previous Topic:pointcut all method calls on an object that implements an interface
Next Topic:Newbie on Book
Current Time: Sat Jul 19 01:02:56 EDT 2025
Powered by FUDForum. Page generated in 0.06552 seconds
