Home » Eclipse Projects » Plugin Development Environment (PDE) » Can I use ant build rcp product?Anybody has correct example?
Can I use ant build rcp product?Anybody has correct example? [message #43628] Mon, 02 February 2009 03:58 Go to next message
Originally posted by: jiaoxw.css.com.cn
hi:
I want to use a ant script to build my RCP product,but i tried many
days .I get the errors now follows,I used eclipse Version: 3.4.0
Build id: I20080617-2000.when I executed build.xml,i find it has been
deleted .Anybody knows how I can build rcp with ant,or tell me the
principle rcp product export ?
Thanks a lot..
Re: Can I use ant build rcp product?Anybody has correct example? [message #43714 is a reply to message #43628] Mon, 02 February 2009 09:53 Go to previous messageGo to next message
here is a tutorial:
http://www.vogella.de/articles/EclipsePDEBuild/article.html
Best regards, Lars
sunway wrote:
> hi:
> Thanks a lot..
Lars Vogel
http://www.vogella.de/eclipse.html - Tutorials about Eclipse
http://www.vogella.de/articles/RichClientPlatform/article.ht ml - Eclipse
RCP Tutorial
Re: Can I use ant build rcp product?Anybody has correct example? [message #43816 is a reply to message #43714] Mon, 02 February 2009 12:20 Go to previous messageGo to next message
Lars,
Do you have any suggestion on how to build a headless RCP product
outputting an executable on Windows?
-Tim
Re: Can I use ant build rcp product?Anybody has correct example? [message #43879 is a reply to message #43816] Mon, 02 February 2009 15:11 Go to previous messageGo to next message
Hi Tim,
yes, this is what the tutorial is about.
Best regards, Lars
Tim Dawson wrote:
> Lars,
> -Tim
Re: Can I use ant build rcp product?Anybody has correct example? [message #44484 is a reply to message #43879] Tue, 03 February 2009 21:59 Go to previous messageGo to next message
于 2009-2-3 4:11, Lars Vogel 写道:
> Hi Tim,
> Best regards, Lars
> Tim Dawson wrote:
>> Lars,
>> outputting an executable on Windows? -Tim
Hi Lars,
I study your tutorial ,but my rcp includes three other plug-ins and
doesn't has your elipse feature project.How can I use ant build the
correct executable rcp applicaion? I run the
http://aniefer.blogspot.com/2008/06/example-headless-build-f or-rcp-product.html
example successfully,but my own project build with exception as follows:
Caused by:
D:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\productBuild\productBuild.xml:21:
The following error occurred while executing this line:
D:\eclipse\plugins\org.eclipse.pde.build_3.4.1.R34x_v2008080 5\scripts\productBuild\productBuild.xml:53:
Problems parsing the product file
D:\workspace-workflow\RcpBuilder\default1.product.
at
org.apache.tools.ant.ProjectHelper.addLocationToBuildExcepti on(ProjectHelper.java:541)
Can you help me?and I will try your tutorial .....
Re: Can I use ant build rcp product?Anybody has correct example? [message #44514 is a reply to message #44484] Wed, 04 February 2009 02:34 Go to previous messageGo to next message
于 2009-2-4 10:59, sunway 写道:
>> Hi Tim,
>> Best regards, Lars
>> Tim Dawson wrote:
>>> Lars,
> Hi Lars,
> Caused by:
> at
Thanks Lars ,I am successed in building my rcp using ant build
script.I have beend worked more than a week,O(∩_∩)O~。but I got much
WARNING
e.g "Discouraged access: The type IDEInternalWorkbenchImages is not
"accessible due to restriction on classpath entry D:\eclipse\plugins
\org.eclipse.ui.ide_3.4.1.M20080903-2000.jar",I have not got the exe
file until I set failonerror="false" .
Best Regards sunway
Re: Can I use ant build rcp product?Anybody has correct example? [message #44545 is a reply to message #44514] Wed, 04 February 2009 04:19 Go to previous messageGo to next message
Hi Sunway,
i got my rcp build running by follow the tutorial by Andrew
( http://aniefer.blogspot.com/2008/06/example-headless-build-f or-rcp-product.html)
without the p2 things :)
But i had problems by getting a exe packed to my rcp. The hints at
http://codescale.wordpress.com/2008/11/15/no-executable-afte r-headless-pde-product-build
helped me by the way.
Also i run into the Bug in Eclipse 3.4.0 at branding the exe with an icon
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=237922) this is solved in
3.4.1
-Matthias
>>> Hi Tim,
>>> Best regards, Lars
>>> Tim Dawson wrote:
>>>> Lars,
>> Hi Lars,
>> Caused by:
D:eclipsepluginsorg.eclipse.pde.build_3.4.1.R34x_v20080805sc riptsproductBuildproductBuild.xml:21:
D:eclipsepluginsorg.eclipse.pde.build_3.4.1.R34x_v20080805sc riptsproductBuildproductBuild.xml:53:
>> D:workspace-workflowRcpBuilderdefault1.product.
>> at
> WARNING
> "accessible due to restriction on classpath entry D:eclipseplugins
> Best Regards sunway
Re: Can I use ant build rcp product?Anybody has correct example? [message #45006 is a reply to message #44545] Wed, 04 February 2009 20:29 Go to previous messageGo to next message
于 2009-2-4 17:19, Matthias Kappeller 写道:
> Hi Sunway,
> icon (https://bugs.eclipse.org/bugs/show_bug.cgi?id=237922) this is
> solved in 3.4.1
> -Matthias
> sunway wrote:
>> � 2009-2-4 10:59, sunway ��:
>>> � 2009-2-3 4:11, Lars Vogel ��:
>>>> Hi Tim,
>>>> Best regards, Lars
>>>> Tim Dawson wrote:
>>>>> Lars,
>>> Hi Lars,
>>> Caused by:
>>> at
>> script.I have beend worked more than a week,O(�_�)O~�but I got much
>> WARNING
>> Best Regards sunway
Hi Matthias:
I can't open the url
,so I don't know what happened about you.I don't understand what's the
"without the p2 things" means.I succed in 3.4.1 ,if you had problems by
getting a exe packed,I wonder if you used the 3.4.1 rcp deltapack ?
Best Regards
sunway
Re: Can I use ant build rcp product?Anybody has correct example? [message #45133 is a reply to message #45006] Thu, 05 February 2009 01:54 Go to previous messageGo to next message
>> Hi Sunway,
>> solved in 3.4.1
>> -Matthias
>> sunway wrote:
>>> Àºᅵ 2009-2-4 10:59, sunway åᅵᅵéᅵᅵ:
>>>> Àºᅵ 2009-2-3 4:11, Lars Vogel åᅵᅵéᅵᅵ:
>>>>> Hi Tim,
>>>>> Best regards, Lars
>>>>> Tim Dawson wrote:
>>>>>> Lars,
>>>> Hi Lars,
>>>> Caused by:
>>>> at
week,O(âᅵ©_âᅵ©)O~ãᅵᅵbut I got much
>>> WARNING
>>> Best Regards sunway
> Hi Matthias
Hmm i can open this url. Maybe you find the topic on browsing through
> I don't understand what's the "without the p2 things" means.I succed in
> 3.4.1 ,if you had problems by getting a exe packed,I wonder if you used
Andrew describes '2: Generate p2 metadata' and '3: Perform p2 installs and
archive the results' to build an archive with an exe. There he also
requires the delta pack. I certainly don't you the delta pack.
> Best Regards
> sunway
Re: Can I use ant build rcp product?Anybody has correct example? [message #45252 is a reply to message #45133] Thu, 05 February 2009 03:05 Go to previous message
于 2009-2-5 14:54, Matthias Kappeller 写道:
> build a
If you use the eclipse 3.4.1 and the rcp delta pack 3.4.1 you will got
the exe file.
Re: Can I use ant build rcp product?Anybody has correct example? [message #590991 is a reply to message #43628] Mon, 02 February 2009 09:53 Go to previous message
here is a tutorial:
Best regards, Lars
sunway wrote:
> hi:
> Thanks a lot..
Lars Vogel
RCP Tutorial
Re: Can I use ant build rcp product?Anybody has correct example? [message #591025 is a reply to message #43714] Mon, 02 February 2009 12:20 Go to previous message
Lars,
-Tim
Re: Can I use ant build rcp product?Anybody has correct example? [message #591046 is a reply to message #43816] Mon, 02 February 2009 15:11 Go to previous message
Hi Tim,
Best regards, Lars
Tim Dawson wrote:
> Lars,
> -Tim
Re: Can I use ant build rcp product?Anybody has correct example? [message #591248 is a reply to message #43879] Tue, 03 February 2009 21:59 Go to previous message
> Hi Tim,
> Best regards, Lars
> Tim Dawson wrote:
>> Lars,
Hi Lars,
Caused by:
at
Re: Can I use ant build rcp product?Anybody has correct example? [message #591254 is a reply to message #44484] Wed, 04 February 2009 02:34 Go to previous message
>> Hi Tim,
>> Best regards, Lars
>> Tim Dawson wrote:
>>> Lars,
> Hi Lars,
> Caused by:
> at
WARNING
Best Regards sunway
Re: Can I use ant build rcp product?Anybody has correct example? [message #591260 is a reply to message #44514] Wed, 04 February 2009 04:19 Go to previous message
Hi Sunway,
3.4.1
-Matthias
>>> Hi Tim,
>>> Best regards, Lars
>>> Tim Dawson wrote:
>>>> Lars,
>> Hi Lars,
>> Caused by:
>> at
> WARNING
> Best Regards sunway
Re: Can I use ant build rcp product?Anybody has correct example? [message #591398 is a reply to message #44545] Wed, 04 February 2009 20:29 Go to previous message
> Hi Sunway,
> solved in 3.4.1
> -Matthias
>>>> Hi Tim,
>>>> Best regards, Lars
>>>> Tim Dawson wrote:
>>>>> Lars,
>>> Hi Lars,
>>> Caused by:
>>> at
>> WARNING
>> Best Regards sunway
Hi Matthias:
Best Regards
sunway
Re: Can I use ant build rcp product?Anybody has correct example? [message #591442 is a reply to message #45006] Thu, 05 February 2009 01:54 Go to previous message
>> Hi Sunway,
>> solved in 3.4.1
>> -Matthias
>>>>> Hi Tim,
>>>>> Best regards, Lars
>>>>> Tim Dawson wrote:
>>>>>> Lars,
>>>> Hi Lars,
>>>> Caused by:
>>>> at
>>> WARNING
>>> Best Regards sunway
> Hi Matthias
> Best Regards
> sunway
Re: Can I use ant build rcp product?Anybody has correct example? [message #591474 is a reply to message #45133] Thu, 05 February 2009 03:05 Go to previous message
> build a
the exe file.
Previous Topic:Target Definition and deployed plugins = class path problem in build.xml
Next Topic:pde.exportPlugins failed
Current Time: Fri Jul 25 23:54:33 EDT 2025
Powered by FUDForum. Page generated in 0.30663 seconds
