Home » Eclipse Projects » Plugin Development Environment (PDE) » Providing Images
Providing Images [message #43657] Mon, 02 February 2009 05:33 Go to next message
i just realized that the swt group is actually a better place for this,
so here goes the cross-post.
As I got my plugin mostly working, now there is a desire for some sleek
looks. Thus, I need to add some images. I came across the interesting
article at
http://www.eclipse.org/articles/Article-Using%20Images%20In% 20Eclipse/Using%20Images%20In%20Eclipse.html
which mentions, that each AbstractUIPlugin has an ImageRegistry built-in
and all I need to do is initialize it.
However, attempting to do this yielded some trouble. I tried
initializing the ImageRegistry in
AbstractUIPlugin#initializeImageRegistry(ImageRegistry) as recommended
in the JavaDoc but got stuck when I discovered that ImageDescriptor is
abstract and no implementation is available.
There is an Implementation FileImageDescriptor, but its Package-Private.
Is there any reason for this? The class appears to be rather
straugt-forward, copying it to my own plugin showed no errors. Can this
class be made public?
Additionally, I gave some thought to this image-situation. Is there any
particular reason, why there is no extension point to add Images
declaratively to the platform ImageRegistry or at least the plugin
ImageRegistry? An ID, the plugin ID (in case of platform registry) and
the path within the plugin should be sufficient to be able to
automatically create an ImageDescriptor for every Image specified.
When implemented in
AbstractUIPlugin#initializeImageRegistry(ImageRegistry) this should not
break any existing functionality. Anyone wishing to use the new
extension point just has to add a call to super.
Specifying a few icons seems like a fairly common use-case, especially
since eclipse doesn't provide much of its own Icons. (Every once in a
while I come across a site offering all the current eclipse icons for
download and inclusion in custom plugins - most IDE-Icons are missing
from API).
Damian Philipp
Re: Providing Images [message #43686 is a reply to message #43657] Mon, 02 February 2009 08:03 Go to previous messageGo to next message
ImageDescriptor has some static methods to load images.
Tom
Damian Philipp schrieb:
> Hello,
> article at
> When implemented in
> from API).
> Regards
> Damian Philipp
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Providing Images [message #43748 is a reply to message #43686] Mon, 02 February 2009 11:11 Go to previous messageGo to next message
Whops, sorry. I should have seen that.
I still think that specifying images for the ImageResigtry declaratively
would be a good idea though.
Damian Philipp
Re: Providing Images [message #43792 is a reply to message #43748] Mon, 02 February 2009 11:48 Go to previous messageGo to next message
By the way you can easily load images using the
AbstractUIPlugin#imageDescriptorFromPlugin!
Tom
> Hello,
> Regards
> Damian Philipp
Re: Providing Images [message #44001 is a reply to message #43748] Tue, 03 February 2009 00:52 Go to previous messageGo to next message
There is a bug open already to add images to SharedImages thru plugin.xml.
Hopefully it should make it into 3.5 M6
- Prakash
http://blog.eclipse-tips.com
"Damian Philipp" <damian.philipp@flexis.de> wrote in message
news:gm75vg$nbq$1@build.eclipse.org...
> Hello,
> Regards
> Damian Philipp
Re: Providing Images [message #44029 is a reply to message #43792] Tue, 03 February 2009 02:10 Go to previous messageGo to next message
judging from the JavaDoc, if I create images from ImageDescriptors
obtained this way, I have to dispose of them myself. I was trying to
avoid having to do that by using the ImageRegistry.
Damian Philipp
Re: Providing Images [message #44061 is a reply to message #44029] Tue, 03 February 2009 04:09 Go to previous message
You load the descriptor and put it into the registery you obtained
previously.
Tom
> Hello,
> Regards
> Damian Philipp
Re: Providing Images [message #590976 is a reply to message #43657] Mon, 02 February 2009 08:03 Go to previous message
Tom
> Hello,
> article at
> When implemented in
> from API).
> Regards
> Damian Philipp
Re: Providing Images [message #591003 is a reply to message #43686] Mon, 02 February 2009 11:11 Go to previous message
Damian Philipp
Re: Providing Images [message #591016 is a reply to message #43748] Mon, 02 February 2009 11:48 Go to previous message
Tom
> Hello,
> Regards
> Damian Philipp
Re: Providing Images [message #591099 is a reply to message #43748] Tue, 03 February 2009 00:52 Go to previous message
- Prakash
> Hello,
> Regards
> Damian Philipp
Re: Providing Images [message #591109 is a reply to message #43792] Tue, 03 February 2009 02:10 Go to previous message
Damian Philipp
Re: Providing Images [message #591114 is a reply to message #44029] Tue, 03 February 2009 04:09 Go to previous message
previously.
Tom
> Hello,
> Regards
> Damian Philipp
Previous Topic:How do I update an Eclipse template variable at runtime?
Next Topic:PDE-Build against a target platform
Current Time: Tue Nov 04 20:43:35 EST 2025
Powered by FUDForum. Page generated in 1.12709 seconds
