Home » Eclipse Projects » Nebula » Memory leak during GalleryTreeViewer.refresh() method?
Memory leak during GalleryTreeViewer.refresh() method? [message #54898] Wed, 25 June 2008 02:14 Go to next message
Overview: Memory is leaked when refresh() method is called for
GalleryTreeViewer. It only happens if one or more gallery tree nodes are
expanded.
Steps to Reproduce:
1) Expand one or more gallery tree nodes. The more images under the nodes
the bigger the memory leak.
2) call GalleryTreeViewer.refresh() method several times and monitor (e.g.
with Task Manager) how the memory usage grows.
Build Date & Platform:
CVS head revision 2008-06-24 on Windows XP Professional (SP2)
Should this happen or am I possibly doing something wrong?
Niko
Re: Memory leak during GalleryTreeViewer.refresh() method? [message #55198 is a reply to message #54898] Thu, 26 June 2008 11:44 Go to previous messageGo to next message
Hi Niko,
Gallery, like Table or Tree does not dispose item's images when you
dispose an item. In SWT, if you created an Image, you're responsible of
disposing it.
I think the problem is in your label provider which probably returns a
new Image each time you call getImage();
Nicolas
Niko Kumpu a écrit :
> expanded.
> Steps to Reproduce:
> Niko
Re: Memory leak during GalleryTreeViewer.refresh() method? [message #55765 is a reply to message #55198] Tue, 08 July 2008 03:41 Go to previous message
Thanks Nicolas,
you are absolutely right. I had missed checking the whole label provider and
it is indeed creating a new image each time getImage() is called. I was sick
for a while here but I will now look into it...
br,
Niko
"Nicolas Richeton" <nicolas.richeton@gmail.com> wrote in message
news:4863B94F.2040407@gmail.com...
> Hi Niko,
> disposing it.
> I think the problem is in your label provider which probably returns a new
> Regards
> Nicolas
> Niko Kumpu a
Re: Memory leak during GalleryTreeViewer.refresh() method? [message #590750 is a reply to message #54898] Thu, 26 June 2008 11:44 Go to previous message
Hi Niko,
disposing it.
Nicolas
> expanded.
> Steps to Reproduce:
> Niko
Re: Memory leak during GalleryTreeViewer.refresh() method? [message #590981 is a reply to message #55198] Tue, 08 July 2008 03:41 Go to previous message
Thanks Nicolas,
br,
Niko
> Hi Niko,
> disposing it.
> Regards
> Nicolas
> Niko Kumpu a
Previous Topic:GridViewer - CheckBoxCellEditor - Databinding
Next Topic:Gantt -> Java 5.0?
Current Time: Fri Nov 07 02:36:46 EST 2025
Powered by FUDForum. Page generated in 0.05755 seconds
