[Eugenia] removing separator line before compartment [message #549858] |
Wed, 28 July 2010 04:44  |
Originally posted by: jan.vandenbergh.uhasselt.be
I am using Eugenia to generate a graphical editor. The graphical
representation of the main nodes consists of a label and a compartment
that can contain other nodes. By default a line is generated that
separates the label and the compartment.
For my notation (just as for Activities in UML 2.0), this line is not
needed.
Is there any way to remove this line (or to change its color so that it
is effectively invisible) using Epsilon/Eugenia as e.g. discussed in
http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-poli shing/?
Many thanks for your answer!
Kind regards,
Jan
Re: [Eugenia] removing separator line before compartment [message #549872 is a reply to message #549858] |
Wed, 28 July 2010 05:49  |
Hi Jan,
You'll first need to figure out how to achieve this by modifying the
..gmfgraph model manually. Once you've found this, you can write a
polishing transformation that does the same every time you run Eugenia
on your metamodel.
Dimitris
Jan Van den Bergh wrote:
> Hello,
> needed.
> Kind regards,
> Jan
Re: [Eugenia] removing separator line before compartment [message #590974 is a reply to message #549858] |
Hi Jan,
on your metamodel.
Dimitris
> Hello,
> needed.
> Kind regards,
> Jan
FUDForum. Page generated in 0.03794 seconds
