Home » Modeling » Epsilon » [Eugenia] Problem with tool.name annotation detail by using different metamodel
[Eugenia] Problem with tool.name annotation detail by using different metamodel [message #547112] Thu, 15 July 2010 09:27 Go to next message
Originally posted by: mario28988.yahoo.de
Hi newsgroup,
I have created the following metamodel which extends the general ecore
metamodel:
example
|- DiagramElement -> EClass
|- ModelElement -> EClass
|- EditorProject -> EPackage
Based on this metamodel I have created a model with gmf annotations:
Editor Project TestProject
|- gmf
|- Model Element AModelElement
|- name : String
|- gmf.node
|- label -> name
|- tool.name -> NewToolName
|- Diagram Element ADiagramElement
|- gmf.diagram
|- ownedModelElements : AModelElement
|- gmf.link
|- tool.name
My Problem is, that if I generate the gmf models via eugenia only the
tool name of the link element will be changed (not the node tool name).
Referring to this I checked the Ecore2GMF.eol script of the
org.eclipse.epsilon.eugenia plugin and located the problem in the
createCreationTool operation. The condition of the if statement 'if
(element.isTypeOf(ECore!EClass) and element.isNode())' always returns
false, because the element type isn't exactly EClass but AModelElement
(which is derived from EClass). However, the isTypeOf method returns
false. :-(
Is this behaviour a problem of the isTypeOf method or should the
implementation of the Ecore2GMF.eol be different? Does anyone know the
location of the eol api reference according to this?
What would you advise me in this issue? What's a 'good' solution for
this problem?
Thanks in advance.
Mario
Re: [Eugenia] Problem with tool.name annotation detail by using different metamodel [message #547122 is a reply to message #547112] Thu, 15 July 2010 11:39 Go to previous messageGo to next message
I think this may work when you replace isTypeOf with isKindOf.
Steffen
On 15/07/2010 14:27, Mario Sänger wrote:
> Hi newsgroup,
> metamodel:
> example
> |- gmf
> |- name : String
> |- gmf.node
> |- label -> name
> |- gmf.diagram
> |- gmf.link
> |- tool.name
> name). Referring to this I checked the Ecore2GMF.eol script of the
> false. :-(
> this problem?
> Thanks in advance.
> Mario
Re: [Eugenia] Problem with tool.name annotation detail by using different metamodel [message #547291 is a reply to message #547122] Fri, 16 July 2010 03:39 Go to previous messageGo to next message
That works fine. Nevertheless I have to change the
org.eclipse.epsilon.eugenia plugin :-(
Mario
Am 15.07.2010 17:39, schrieb Steffen Zschaler:
> Steffen
>> Hi newsgroup,
>> metamodel:
>> example
>> |- gmf
>> |- name : String
>> |- gmf.node
>> |- label -> name
>> |- gmf.diagram
>> |- gmf.link
>> |- tool.name
>> false. :-(
>> this problem?
>> Thanks in advance.
>> Mario
Re: [Eugenia] Problem with tool.name annotation detail by using different metamodel [message #547292 is a reply to message #547291] Fri, 16 July 2010 04:38 Go to previous messageGo to next message
You may wish to file a feature request/bug report. Dimitrios et al
will then be able to look at it and decide whether it makes sense to
include this fix into the official version.
Steffen
> Regards
> Mario
>> Steffen
>>> Hi newsgroup,
>>> metamodel:
>>> example
>>> |- gmf
>>> |- name : String
>>> |- gmf.node
>>> |- label -> name
>>> |- gmf.diagram
>>> |- gmf.link
>>> |- tool.name
>>> false. :-(
>>> this problem?
>>> Thanks in advance.
>>> Mario
Re: [Eugenia] Problem with tool.name annotation detail by using different metamodel [message #547344 is a reply to message #547292] Fri, 16 July 2010 07:46 Go to previous messageGo to next message
Hi Mario,
I'm not convinced that extending Ecore with new classes is the best solution but as Steffen suggested, I'm happy to make this change in Eugenia (isTypeOf->isKindOf). Could you please file an enhancement request for this in the bugzilla using the link below?
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=GMT& component=Epsilon
Dimitris
Re: [Eugenia] Problem with tool.name annotation detail by using different metamodel [message #590687 is a reply to message #547112] Thu, 15 July 2010 11:39 Go to previous messageGo to next message
Steffen
> Hi newsgroup,
> metamodel:
> example
> |- gmf
> |- name : String
> |- gmf.node
> |- label -> name
> |- gmf.diagram
> |- gmf.link
> |- tool.name
> false. :-(
> this problem?
> Thanks in advance.
> Mario
Re: [Eugenia] Problem with tool.name annotation detail by using different metamodel [message #590713 is a reply to message #547122] Fri, 16 July 2010 03:39 Go to previous messageGo to next message
Mario
> Steffen
>> Hi newsgroup,
>> metamodel:
>> example
>> |- gmf
>> |- name : String
>> |- gmf.node
>> |- label -> name
>> |- gmf.diagram
>> |- gmf.link
>> |- tool.name
>> false. :-(
>> this problem?
>> Thanks in advance.
>> Mario
Re: [Eugenia] Problem with tool.name annotation detail by using different metamodel [message #590719 is a reply to message #547291] Fri, 16 July 2010 04:38 Go to previous messageGo to next message
Steffen
> Regards
> Mario
>> Steffen
>>> Hi newsgroup,
>>> metamodel:
>>> example
>>> |- gmf
>>> |- name : String
>>> |- gmf.node
>>> |- label -> name
>>> |- gmf.diagram
>>> |- gmf.link
>>> |- tool.name
>>> false. :-(
>>> this problem?
>>> Thanks in advance.
>>> Mario
Re: [Eugenia] Problem with tool.name annotation detail by using different metamodel [message #590729 is a reply to message #547292] Fri, 16 July 2010 07:46 Go to previous message
Hi Mario,
Dimitris
Previous Topic:[Eugenia] Problem with tool.name annotation detail by using different metamodel
Next Topic:[Epsilon] Revisiting problems with examples.friends.
Current Time: Sun Jul 27 15:51:02 EDT 2025
Powered by FUDForum. Page generated in 0.05974 seconds
