Home » Archived » EPF » Databinding and rich text editor
| Databinding and rich text editor [message #53364] |
Tue, 09 September 2008 03:12  |
Originally posted by: mcervera.integranova.com
Hi.
I am trying to use databinding with the rich text editor. I've managed
to make it work by simply returning an instance of
RichTextObservableValue the same way observeText returns
TextObservableValue. RichTextObservableValue is a class I've implemented
which inherites from AbstractVetoableValue. Everything is ok but I have
problems with the modify listener, that is, the ModifyEvent is not fired
when I write in the RichTextEditor, therefore my editor is not set as
dirty. To my surprise, this event is fired when pressing keys like
delete, back space... but not when I press simple characters. I don't
understand what is going on. Has anyone experienced anything similar?
Has anyone got to make databinding work with this editor?
Thanks in advance.
Mario
| Re: Databinding and rich text editor [message #53470 is a reply to message #53392] |
Wed, 10 September 2008 03:03   |
Hi Eric,
that's the class I'm using but the method modifyText is not invoked as
much as I'd like to. It's strange but it's invoked when I either use the
toolbar or press Del, back space... but not when I write simple
characters :S. The problem of this is that I have problems to set my
model as dirty. I could use the focus out event but the listener I use
doesn't get called either.
Mario
Eric Rizzo escribió:
> Mario Cervera wrote:
>> Hi.
>> implemented which inherites from AbstractVetoableValue. Everything is
>> ok but I have problems with the modify listener, that is, the
>> ModifyEvent is not fired when I write in the RichTextEditor, therefore
>> my editor is not set as dirty. To my surprise, this event is fired
>> when pressing keys like delete, back space... but not when I press
>> simple characters. I don't understand what is going on. Has anyone
>> experienced anything similar? Has anyone got to make databinding work
>> with this editor?
> We use a custom RichTextObservableValue and it works correctly on
> Eclipse 3.3. I have not yet started testing our stuff on 3.4, however.
> The class is in this package:
> < https://www.skywayperspectives.org/fisheye/browse/CVS_OpenSo urce/skyway/common/plugins/org.skyway.ui/src/org/skyway/ui/r ichtext>
> Hope this helps,
> Eric
| Re: Databinding and rich text editor [message #53497 is a reply to message #53470] |
Wed, 10 September 2008 09:41   |
> Hi Eric,
> model as dirty.
Are you trying it on Eclipse 3.4? I know our class works on 3.3 - we get
modify events as expected.
Eric
>>> Hi.
>>> managed to make it work by simply returning an instance of
>>> therefore my editor is not set as dirty. To my surprise, this event
>>> is fired when pressing keys like delete, back space... but not when I
>>> press simple characters. I don't understand what is going on. Has
>>> anyone experienced anything similar? Has anyone got to make
>> Hope this helps,
>> Eric
| Re: Databinding and rich text editor [message #53524 is a reply to message #53497] |
Wed, 10 September 2008 10:19   |
Yes I am using eclipse 3.4.0, maybe that's the reason :(
>> Hi Eric,
>> the toolbar or press Del, back space... but not when I write simple
>> model as dirty.
> Eric
>>>> Hi.
>>>> is ok but I have problems with the modify listener, that is, the
>>>> I press simple characters. I don't understand what is going on. Has
>>> Hope this helps,
>>> Eric
| Re: Databinding and rich text editor [message #485886 is a reply to message #53524] |
Tue, 15 September 2009 08:49   |
Hello
I'm using Eclipse 3.5.0 having the same problem, the ModifyListener is not
notified after text was tipped.
Was there any work done on this issue? Does a bug report exists? Should I
report one? Is there a workaround available?
greets
Flavio
>>> Hi Eric,
>>> model as dirty.
>> Eric
>>>>> Hi.
>>>> Hope this helps,
>>>> Eric
| Re: Databinding and rich text editor [message #485942 is a reply to message #53524] |
Tue, 15 September 2009 11:18   |
hello
I kind of patched the "rte.js" and it kind of works now :-).
One strange behavior, the first key tip is not forwarded as modify event
and
some modify events will now probably be fired twice, but I don't care :-).
But here part of the org.eclipse.epf.richtext_1.5.0.x/rte/rte.js script:
var excludeModify = new Array(16, KEY_ARROW_DOWN, KEY_ARROW_LEFT,
KEY_ARROW_RIGHT, KEY_ARROW_UP, KEY_END, KEY_HOME, KEY_PAGE_DOWN,
KEY_PAGE_UP, KEY_TAB);
// Handles the key events.
function keyPressed(event) {
var keyCode = event.keyCode;
if (keyCode == 0 && !document.all) {
keyCode = event.charCode;
switch (keyCode) {
case 99:
keyCode = KEY_C;
break;
case 102:
keyCode = KEY_F;
break;
case 115:
keyCode = KEY_S;
break;
case 118:
keyCode = KEY_V;
break;
case 120:
keyCode = KEY_X;
break;
case 122:
keyCode = KEY_Z;
break;
var ctrlKey = event.ctrlKey;
var shiftKey = event.shiftKey;
var altKey = event.altKey;
if ( !ctrlKey && !altKey ) {
var modified = true;
for (var i = 0; i < excludeModify.length; i++ ) {
if ( keyCode == excludeModify[i] ) {
modified = false;
if ( modified == true ) {
setStatus(STATUS_MODIFIED, keyCode);
Maybe this can be a starting point to resolve this issue?
| Re: Databinding and rich text editor [message #590493 is a reply to message #53392] |
Hi Eric,
Mario
>> Hi.
>> with this editor?
> Hope this helps,
> Eric
| Re: Databinding and rich text editor [message #590519 is a reply to message #53470] |
> Hi Eric,
> model as dirty.
Eric
>>> Hi.
>> Hope this helps,
>> Eric
| Re: Databinding and rich text editor [message #590546 is a reply to message #53497] |
>> Hi Eric,
>> model as dirty.
> Eric
>>>> Hi.
>>> Hope this helps,
>>> Eric
| Re: Databinding and rich text editor [message #598854 is a reply to message #53524] |
Hello
greets
Flavio
>>> Hi Eric,
>>> model as dirty.
>> Eric
>>>>> Hi.
>>>> Hope this helps,
>>>> Eric
| Re: Databinding and rich text editor [message #598863 is a reply to message #53524] |
hello
and
switch (keyCode) {
case 99:
keyCode = KEY_C;
break;
case 102:
keyCode = KEY_F;
break;
case 115:
keyCode = KEY_S;
break;
case 118:
keyCode = KEY_V;
break;
case 120:
keyCode = KEY_X;
break;
case 122:
keyCode = KEY_Z;
break;
modified = false;
Current Time: Sat Nov 01 00:15:55 EDT 2025
Powered by FUDForum. Page generated in 0.06997 seconds
