Home » Eclipse Projects » Mylyn » Mylyn 3.0 is available
Mylyn 3.0 is available [message #50775] Wed, 25 June 2008 20:33 Go to next message
We are very pleased to announce that Mylyn 3.0 is now available for
Eclipse 3.4 and 3.3. Please see the last section of the New &
Noteworthy for changes in update site structure.
http://eclipse.org/mylyn/new/
You can get Mylyn 3.0 from our update sites:
http://eclipse.org/mylyn/downloads/
Or as part of the Eclipse download packages:
http://eclipse.org/downloads/
The release story is at:
http://tasktop.com/blog/?p=32
Thanks, and stay in touch!
The Mylyn Team
Re: Mylyn 3.0 is available [message #50922 is a reply to message #50775] Fri, 27 June 2008 01:53 Go to previous messageGo to next message
"Mik Kersten" <mik.kersten@tasktop.com> wrote in message
news:g3uo5m$b8t$1@build.eclipse.org...
Great job, thank you!
I'm having a bit of trouble getting Mylyn 3 installed into Ganymede.
I downloaded this: eclipse-SDK-3.4-win32.zip (for my XP Pro rig)
Unzipped it.
In the available software tab of the Software Updates and Add-ons dialog I
select Collaboration Tools
Click install
Get these errors:
Cannot complete the request. See the details.
Unsatisfied dependency: [org.eclipse.mylyn.ide.ui 3.0.0.v20080619-1900]
requiredCapability: osgi.bundle/org.eclipse.ui.ide/[3.3.0,3.4.0)
Cannot find a solution where both Match[requiredCapability:
osgi.bundle/org.eclipse.ui.ide/[3.4.0,4.0.0)] and Match[requiredCapability:
osgi.bundle/org.eclipse.ui.ide/[3.3.0,3.4.0)] can be satisfied.
Unsatisfied dependency: [org.eclipse.mylyn.pde.ui 3.0.0.v20080619-1900]
requiredCapability: osgi.bundle/org.eclipse.pde.ui/[3.3.0,3.4.0)
osgi.bundle/org.eclipse.pde.ui/[3.4.0,4.0.0)] and Match[requiredCapability:
osgi.bundle/org.eclipse.pde.ui/[3.3.0,3.4.0)] can be satisfied.
Unsatisfied dependency: [org.eclipse.mylyn.ide.ant 3.0.0.v20080619-1900]
requiredCapability: osgi.bundle/org.eclipse.mylyn.ide.ui/[3.0.0,4.0.0)
Unsatisfied dependency: [org.eclipse.mylyn.java_feature.feature.group
3.0.0.v20080619-1900] requiredCapability:
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.ide.ui/[3.0.0,4. 0.0)
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.java.ui/[3.0.0.v 20080619-1900,3.0.0.v20080619-1900]
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.ide.ui/[3.0.0.v2 0080619-1900,3.0.0.v20080619-1900]
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.ide.ant/[3.0.0.v 20080619-1900,3.0.0.v20080619-1900]
requiredCapability: osgi.bundle/org.eclipse.mylyn.java.ui/0.0.0
requiredCapability: osgi.bundle/org.eclipse.mylyn.java.ui/[3.0.0,4.0.0)
Unsatisfied dependency: [org.eclipse.mylyn.ide_feature.feature.group
Unsatisfied dependency: [org.eclipse.mylyn.java.ui 3.0.0.v20080619-1900]
Unsatisfied dependency: [org.eclipse.mylyn.pde_feature.feature.group
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.java.ui/[3.0.0,4 .0.0)
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.pde.ui/[3.0.0.v2 0080619-1900,3.0.0.v20080619-1900]
org.eclipse.equinox.p2.iu/org.eclipse.mylyn.java_feature.fea ture.group/[3.0.0.v20080619-1900,3.0.0.v20080619-1900]
I get similar results when I go to my previous eclipse installation and try
to update from Mylyn 2.3.0
Is there a work around?
Re: Mylyn 3.0 is available [message #50950 is a reply to message #50922] Fri, 27 June 2008 02:18 Go to previous messageGo to next message
> Unzipped it.
> Click install
Actually, in this description of what I did, left out some other plug
installs. If I start from a clean Ganymede install, the installation goes
perfectly.
Re: Mylyn 3.0 is available [message #51035 is a reply to message #50950] Fri, 27 June 2008 16:24 Go to previous message
>> Unzipped it.
>> I select Collaboration Tools
>> Click install
> perfectly.
Tom, do you have a sense which plug-ins caused the conflict? For most
integrations such as Subversive, Subclipse or Spring IDE updates have been
released that support Mylyn 3.0 but you may need to update those as well
when updating Mylyn.
Steffen
Re: Mylyn 3.0 is available [message #590432 is a reply to message #50775] Fri, 27 June 2008 01:53 Go to previous message
Unzipped it.
Click install
Get these errors:
Re: Mylyn 3.0 is available [message #590442 is a reply to message #50922] Fri, 27 June 2008 02:18 Go to previous message
> Unzipped it.
> Click install
perfectly.
Re: Mylyn 3.0 is available [message #590473 is a reply to message #50950] Fri, 27 June 2008 16:24 Go to previous message
>> Unzipped it.
>> Click install
> perfectly.
Steffen
Previous Topic:Screenshot api for Mylyn.
Next Topic:Problem creating query
Current Time: Tue Oct 28 03:02:33 EDT 2025
Powered by FUDForum. Page generated in 0.05388 seconds
