Home » Modeling » Epsilon » Accessing MapInfo structure from ECL(Writing data from within a compare)
Accessing MapInfo structure from ECL [message #541771] Tue, 22 June 2010 09:42 Go to next message
Hi guys,
I can't figure out how to put a value into a match's info map after a successful compare. I can see the (empty) structure in the debugger, but can't access it from ECL.
The Epsilon Book states that it is possible to do so from within the do part of a compare for the established match. Trouble is, I don't know how to get a hold of the "established match".
Many thanks,
--Stephen
Re: Accessing MapInfo structure from ECL [message #541791 is a reply to message #541771] Tue, 22 June 2010 10:00 Go to previous messageGo to next message
Hi Stephen,
You should be able to access the map using the implicit matchInfo
variable (and I should probably update the book :) ).
Dimitris
Stephen Barrett wrote:
> Hi guys,
> Many thanks,
> --Stephen
Re: Accessing MapInfo structure from ECL [message #541797 is a reply to message #541791] Tue, 22 June 2010 10:39 Go to previous messageGo to next message
Yep Dimitris, that was the missing piece! Thanks again.
Is there a list of these implicit variables? Or a place to look in the code to find one? I knew this was a simple matter, I just didn't know the magic word.
--Stephen
Re: Accessing MapInfo structure from ECL [message #541962 is a reply to message #541797] Wed, 23 June 2010 07:30 Go to previous messageGo to next message
Hi Stephen,
The book/documentation should really mention these as there's not a
single place in the code where all these implicit variables are defined
defined (e.g. matchInfo is added to the context in line 329 of
https://dev.eclipse.org/svnroot/modeling/org.eclipse.gmt.eps ilon/trunk/plugins/org.eclipse.epsilon.ecl.engine/src/org/ec lipse/epsilon/ecl/MatchRule.java)
Dimitris
> the magic word.
> --Stephen
Re: Accessing MapInfo structure from ECL [message #544888 is a reply to message #541962] Mon, 05 July 2010 17:52 Go to previous messageGo to next message
Okay,
I am now passing values back to my application from match rules by adding do-parts of the following form to each rule:
  do {
    matchInfo.put("mirador", 0.7);
with the key being the name of my application. Do you think that this robust enough, or are there some gotchas I may be unaware of?
Also, Dimitirs you mentioned to me that after matching a pair of model elements with ECL, that I might want to recalculate overall similarity measures for the remaining element pairs in my model. Trouble is, I can't remember why this is so. Could you please refresh my memory?
Many thanks,
--Stephen
Re: Accessing MapInfo structure from ECL [message #544891 is a reply to message #544888] Mon, 05 July 2010 18:20 Go to previous messageGo to next message
Hi Stephen,
On 05/07/2010 22:52, Stephen Barrett wrote:
> Okay,
> do {
That should be fine indeed.
I think I was referring to recalculating matches whenever the user
establishes an explicit (i.e. manual) match - if that's supported by
Mirador.
> Many thanks,
> --Stephen
Dimitris
Re: Accessing MapInfo structure from ECL [message #545160 is a reply to message #544891] Tue, 06 July 2010 16:07 Go to previous messageGo to next message
> Mirador.
Yes, that's what you were referring to. So, I suppose, my real question is, why do you think a recalculation might be needed? And by recalculation, I assume you mean redoing all the element similarity measures, and then rematching the elements based on the new measures. Is that accurate?
--Stephen
Re: Accessing MapInfo structure from ECL [message #545164 is a reply to message #545160] Tue, 06 July 2010 16:24 Go to previous messageGo to next message
Hi Stephen,
Suppose that you're comparing trees and you have the following sample trees:
[a]
-- [b]
and
[c]
-- [b]
and the following rule
rule MatchTrees
match l : Left!Tree
with r : Right!Tree {
compare : l.label = r.label and
l.parent.matches(r.parent)
In the initial comparison, the two [b]'s won't match because their
parents don't match ([a] <> [c]). However, if the user explicitly
declares that [a] matches with [c] then the two [b]'s should now match.
Does this make any sense?
Dimitris
>> Mirador.
> that accurate?
> Regards,
> --Stephen
Re: Accessing MapInfo structure from ECL [message #545618 is a reply to message #545164] Thu, 08 July 2010 08:55 Go to previous messageGo to next message
Ah. The light goes on. Thanks Dimitris!
Re: Accessing MapInfo structure from ECL [message #590273 is a reply to message #541791] Tue, 22 June 2010 10:39 Go to previous messageGo to next message
--Stephen
Re: Accessing MapInfo structure from ECL [message #590331 is a reply to message #541797] Wed, 23 June 2010 07:30 Go to previous messageGo to next message
Hi Stephen,
Dimitris
> the magic word.
> --Stephen
Re: Accessing MapInfo structure from ECL [message #590439 is a reply to message #541962] Mon, 05 July 2010 17:52 Go to previous messageGo to next message
Okay,
do {
Many thanks,
--Stephen
Re: Accessing MapInfo structure from ECL [message #590450 is a reply to message #544888] Mon, 05 July 2010 18:20 Go to previous messageGo to next message
Hi Stephen,
> Okay,
> do {
Mirador.
> Many thanks,
> --Stephen
Dimitris
Re: Accessing MapInfo structure from ECL [message #590508 is a reply to message #544891] Tue, 06 July 2010 16:07 Go to previous messageGo to next message
> Mirador.
--Stephen
Re: Accessing MapInfo structure from ECL [message #590512 is a reply to message #545160] Tue, 06 July 2010 16:24 Go to previous messageGo to next message
Hi Stephen,
[a]
-- [b]
and
[c]
-- [b]
rule MatchTrees
match l : Left!Tree
Dimitris
>> Mirador.
> that accurate?
> Regards,
> --Stephen
Re: Accessing MapInfo structure from ECL [message #590524 is a reply to message #545164] Thu, 08 July 2010 08:55 Go to previous message
Previous Topic:[eol] problem with creating a native java String
Next Topic:EWL Guard Querying Stereotype
Current Time: Sun Jul 27 14:27:29 EDT 2025
Powered by FUDForum. Page generated in 0.04714 seconds
